FrankRizzo Posted October 7, 2020 Report Share Posted October 7, 2020 5 hours ago, 5t341tH said: Can you link me to that sway bar? Also you said that shop can make it too? http://www.futofab.com/ Look under Datsun Truck Parts, they have rear bars also. Sal told me he could make one and that he does it all the time...but when mine fit, I did not have to take it any further. His link is above, you can call and say you saw Kevin's green datsun truck...he'll know. . 1 Quote Link to comment
Crashtd420 Posted November 5, 2020 Report Share Posted November 5, 2020 On 9/11/2020 at 11:58 PM, 5t341tH said: i used these. not exact but it spaced it 2" Just wanted to say thanks again for this... I bought the 1" extension and just got them installed the other day.... so happy with the end results, the ride height ended up exactly where I wanted it.... 1 Quote Link to comment
5t341tH Posted November 7, 2020 Report Share Posted November 7, 2020 On 11/5/2020 at 7:01 AM, Crashtd420 said: Just wanted to say thanks again for this... I bought the 1" extension and just got them installed the other day.... so happy with the end results, the ride height ended up exactly where I wanted it.... nice. I'm going with the 1" extensions too. The 2" was a bit too high. Also I have a set of DS404 with springs if you are interested 1 Quote Link to comment
Crashtd420 Posted November 7, 2020 Report Share Posted November 7, 2020 5 hours ago, 5t341tH said: nice. I'm going with the 1" extensions too. The 2" was a bit too high. Also I have a set of DS404 with springs if you are interested Im not sure but If I can use them I'll let you know... I plan to setup my rear coilover system first, then measure for a length that suits the ride height..... 1 Quote Link to comment
FrankRizzo Posted November 7, 2020 Report Share Posted November 7, 2020 Crash, sorry if I missed it, but what are those ^ ? . 1 Quote Link to comment
Crashtd420 Posted November 8, 2020 Report Share Posted November 8, 2020 20 hours ago, FrankRizzo said: Crash, sorry if I missed it, but what are those ^ ? . Basically an extension for the shock shaft.... 1 Quote Link to comment
5t341tH Posted November 8, 2020 Report Share Posted November 8, 2020 3 hours ago, Crashtd420 said: Basically an extension for the shock shaft.... hey that is actually the wrong part. You need to get 3096-202 for the 1" extension. It replaces the whole eyelet Quote Link to comment
Crashtd420 Posted November 8, 2020 Report Share Posted November 8, 2020 3 hours ago, 5t341tH said: hey that is actually the wrong part. You need to get 3096-202 for the 1" extension. It replaces the whole eyelet Oh.. I tried looking for something like that and couldn't find it, this is why I bought what I did... it worked out really good... Quote Link to comment
Crashtd420 Posted November 8, 2020 Report Share Posted November 8, 2020 Actually just looked that up, I'm using the bearing end so that wont work, that is a bushing end... Quote Link to comment
5t341tH Posted November 9, 2020 Report Share Posted November 9, 2020 9 hours ago, Crashtd420 said: Actually just looked that up, I'm using the bearing end so that wont work, that is a bushing end... I talked with qa1 directly about the part. they dont make the 1" bare without the bushing. they said just cut off the bushing and slide the bearing in as normal Quote Link to comment
Crashtd420 Posted November 9, 2020 Report Share Posted November 9, 2020 5 hours ago, 5t341tH said: I talked with qa1 directly about the part. they dont make the 1" bare without the bushing. they said just cut off the bushing and slide the bearing in as normal Well that makes some sense..... They must have machined the groove for the clips that hold the bearings in regardless... Wish that was in the description.... Oh well I'm still happy with what I used.. seems solid and I'm at the ride height i want and seems to be at all working properly.... Do you see in issue with it? Quote Link to comment
5t341tH Posted November 17, 2020 Report Share Posted November 17, 2020 On 11/9/2020 at 4:25 AM, Crashtd420 said: Well that makes some sense..... They must have machined the groove for the clips that hold the bearings in regardless... Wish that was in the description.... Oh well I'm still happy with what I used.. seems solid and I'm at the ride height i want and seems to be at all working properly.... Do you see in issue with it? I don’t see an issue really but I’m no expert. If your spring is long enough or compressed enough to fill that gap it should be fine. I just received my part today 1 Quote Link to comment
Crashtd420 Posted November 17, 2020 Report Share Posted November 17, 2020 7 minutes ago, 5t341tH said: I don’t see an issue really but I’m no expert. If your spring is long enough or compressed enough to fill that gap it should be fine. I just received my part today Well thats good to know for the future, I kind of wanted that for more clearance up top but what I got did work out.... Thanks Quote Link to comment
Crashtd420 Posted November 17, 2020 Report Share Posted November 17, 2020 Oh I figured I'd throw this up for others using the bearing type end..... I accidentally figured out a 5/8 heater hose( pretty sure it was 5/8) fits the end of the bearing and can be cut to fit to make a dust seal.... 2 Quote Link to comment
Wildcat Walker Posted July 31, 2023 Report Share Posted July 31, 2023 On 10/4/2020 at 3:59 PM, Farmer said: I dont see being able to get a sway bar in there unless moving thehole of some type of bracket. Heres a pic where it should mount. shock in the way.. As for measuring. got to do it old school. What part # is this coil over? Quote Link to comment
Farmer Posted August 1, 2023 Report Share Posted August 1, 2023 (edited) 12 hours ago, Wildcat Walker said: What part # is this coil over? Its been yrs, Dont remember, ill try and find Found it, went back through my build thread https://www.summitracing.com/parts/hal-aln4855b Edited August 1, 2023 by Farmer 1 Quote Link to comment
