Datsunville's Commando PT 2
  • Replies 113
Time to clean things up, lined out the battery cable
Bought a new RHD upper hood latch but didnt fit, used parts from the new one and an old one to make work great
Opened up the holes to help with adjusting
New shortened drive line, 37.5 inches center of yoke to center of yoke. long tail 5 speed
Had some help cleaning seats and bleeding clutch and breaks
  • Like 4
Put in some hours, still missing a few Coupe specific parts.
Installing rocker trim, something i almost never get around too. found some new and used clips
Used anti seize to keep them from rusting, These ends rust and snap, when you go to remove them.
Installed a super clean set of belt moldings and NOS rubber inner squeegees
Now deciding on grill to run with
Before installing the grill every hole needed to be cleaned of paint and debris
On to some interior work
Factory door pane;s cleaned and installed
Cleaned up some sill plates
Cleaned up and vinyl died visors
Installed a pathfinder day / night mirror
Back to the grill areas, Headlight bezels oh my
Step 1, polish a clean set of bezels, left and right, not 2 of one side
Step 2, Mask and scuff and paint black areas
Used this handy tool for masking and then wrapped a scotch bright around it and used it for scuffing
Hours of fun
While out on the trailer,  follow 510er BIG (owes The Datsunville Rat) took care of a full lube on the bird
Got behind with getting her together, so towed her to the Datsun Solvang Roadster show
I met this guy Tom, he imported this Bluebird Coupe in 1977 to California. Funny story we started talking. He mentioned he imported an orange coupe, then it got painted yellow. Light bulb over my head went off. This coupe was factory orange then repainted yellow. I thought it was imported in 1978. Nope 1977. and Tom use to own it.
No taillights, however I had been saving a set of NOS taillights, since 2002, (before i ever owned a coupe), and installed them in the parking lot. The ones i want to use on this car are back at the chrome shop.
Edited by the510keeper
  • Like 4
  • 1 month later...
Made it to Datsloco on a trailer
Then this happened taking it off the trailer, it took it self off the trailer. Right on
No terrible damage, the pompous glass was like a big cushion
Back to work, wiring 101 continues
Simple tranny hole cover
$300+ now temp registered
Decided to install some NOS mirrors
These little fucker straight  from Japan, rear seat hardware. allows rear seat to fold down
New shoes
1st test drive 1000 miles +++ Powerland Datsun show Thanks to Cody for the great pics
  • Like 4
  • 4 weeks later...
  • 1 month later...
We will see whats up very soon
trying to figure out if i want to do adjustable T/C rods and control arms stay tune
On to the noise, or trying to eliminate some of it any way.
Sanded the floors and opened up a drain hole for a plug.
Then LIZARD SKIN hahaha
  • Like 3
6 hours ago, BrothersGarage said:
Have you used the LIZARD SKIN before? What are your thoughts on it?
I was considering just raptor lining the floor as opposed to doing the dynomat stuff and having it be a PITA to ever remove.
Yes this is the 5th car ive used Lizard skin on. works great. none of these products will ever be easy to remove
  • Like 3
