mainer311 Posted June 18, 2021 Author Report Share Posted June 18, 2021 Thanks! 1 Quote Link to comment
mainer311 Posted June 18, 2021 Author Report Share Posted June 18, 2021 (edited) Been re-teaching myself how to TIG. It’s been almost 13 years since I last touched a torch. I took the money I saved from having a stainless exhaust put on and bought a small welder. It’s been a lot of fun. Edited June 18, 2021 by mainer311 5 Quote Link to comment
greenthumb Posted June 18, 2021 Report Share Posted June 18, 2021 Nice! Did the same thing. Opens up a whole new realm of possibilities for fabricating. Mild steel, Stainless, Aluminum… great investment 2 Quote Link to comment
d.p Posted June 19, 2021 Report Share Posted June 19, 2021 What welder did you buy? I always thought about learning to weld. 1 Quote Link to comment
mainer311 Posted June 19, 2021 Author Report Share Posted June 19, 2021 10 hours ago, d.p said: What welder did you buy? I always thought about learning to weld. A “cheap” one from Harbor Freight. Most of their higher end welders actually get decent reviews. It’s a Vulcan ProTig 165. For about $100 extra, you can get yourself setup really well with a glass cup and super flexible hose. 1 Quote Link to comment
mainer311 Posted June 19, 2021 Author Report Share Posted June 19, 2021 Some progress. Cars and coffee is tomorrow so it looks like the roadster will make an appearance because there’s no way I’m finishing this today. Reshaping the stock clamp for the 2” tubing. This is the mid pipe. It will have quick collars on both ends. The downpipe will be it’s own removable piece to snake it around the torsion bar. 4 Quote Link to comment
mainer311 Posted June 20, 2021 Author Report Share Posted June 20, 2021 (edited) Man it’s tight in here. I notched out the inspection plate/transmission flange a little bit to make room for the flange clamp. It just barely fits. Downpipe is mocked up. Edited June 20, 2021 by mainer311 5 Quote Link to comment
d.p Posted June 20, 2021 Report Share Posted June 20, 2021 Is that 2.25”? If so and you ever go to a 5 speed that pipe may not fit past the trans and torsion bars. looks good though. 2 Quote Link to comment
mainer311 Posted June 20, 2021 Author Report Share Posted June 20, 2021 (edited) 2”. It’s plenty big enough, especially considering the exhaust that was on there is 1.5” It’s 56% bigger than what is on there in terms of flow area. Edited June 20, 2021 by mainer311 2 Quote Link to comment
mainer311 Posted June 21, 2021 Author Report Share Posted June 21, 2021 Also, I thought about the clearance already, and decided to go to the outside of the torsion bar and along the frame rail: 4 Quote Link to comment
d.p Posted June 21, 2021 Report Share Posted June 21, 2021 Looks good, here is mine inside the torsion bar albeit a terrible picture. 3 Quote Link to comment
mainer311 Posted June 21, 2021 Author Report Share Posted June 21, 2021 34 minutes ago, d.p said: Looks good, here is mine inside the torsion bar albeit a terrible picture. Nice. That looks good. 1 Quote Link to comment
mainer311 Posted June 25, 2021 Author Report Share Posted June 25, 2021 Last piece of the puzzle going in: the fart pipe. I’m making the last mount for it right now. It will utilize one of the factory weld nuts from the axle bump stop. 3 Quote Link to comment
mainer311 Posted June 25, 2021 Author Report Share Posted June 25, 2021 All finished: 3 Quote Link to comment
thisismatt Posted June 25, 2021 Report Share Posted June 25, 2021 No isolation hangers? 😬 1 Quote Link to comment
Charlie69 Posted June 25, 2021 Report Share Posted June 25, 2021 (edited) Rigid mount to the frame? Would not last two days on the chuck holes (I mean streets) in Phoenix. Edited June 25, 2021 by Charlie69 1 Quote Link to comment
mainer311 Posted June 25, 2021 Author Report Share Posted June 25, 2021 6 hours ago, thisismatt said: No isolation hangers? 😬 I used the factory one on the crossmember. Rigid on the tailpipe. Should be fine. 1 Quote Link to comment
Stoffregen Motorsports Posted June 25, 2021 Report Share Posted June 25, 2021 Isolators help with noise from resonance and vibration. I predict cracks at the spot where it is solid mounted. 2 Quote Link to comment
d.p Posted June 25, 2021 Report Share Posted June 25, 2021 Yeah you would be amazed at what vibration can do to an exhaust. With my M3 BMW had a titanium m-performance exhaust that cracked on the welds on sides where it met the can. That was with rubber hangers and BMW level of design and production. 1 Quote Link to comment
mainer311 Posted June 25, 2021 Author Report Share Posted June 25, 2021 2 hours ago, Stoffregen Motorsports said: Isolators help with noise from resonance and vibration. I predict cracks at the spot where it is solid mounted. I hear you're a crack expert. 2 1 Quote Link to comment
Stoffregen Motorsports Posted June 25, 2021 Report Share Posted June 25, 2021 Crack kills. Just say no. 1 1 Quote Link to comment
datzenmike Posted June 25, 2021 Report Share Posted June 25, 2021 If it were hanging straight down, it would be fine. Supported from the side like that exerts a lot of leverage on just a single bolt head. On bumps the pipe and muffler can easily double their weight. This will work.... till it fails. I predict you will change this long before that. 2 Quote Link to comment
Charlie69 Posted June 25, 2021 Report Share Posted June 25, 2021 12 hours ago, mainer311 said: I used the factory one on the crossmember. Rigid on the tailpipe. Should be fine. You are wrong. 1 Quote Link to comment
mainer311 Posted July 16, 2021 Author Report Share Posted July 16, 2021 Switching my Goodyear Eagle RS-A’s out for these. That should do the trick. 4 Quote Link to comment
mainer311 Posted July 21, 2021 Author Report Share Posted July 21, 2021 My Jakes Makes clear tail lenses came in tonight, along with his steering column grommet. Great parts! And my rear 225’s are in as well. 5 Quote Link to comment
