Distributor rotors
Datsundude123
  • Replies 407
Did you watch the videos that Hainz posted?
Everything you need to know about timing your L motor is covered in his videos.
You're not even trying. One of these days that spoon will be gone.
I watched the whole video but I couldn't tell how the cam was set! Sorry for asking a simple question.
Look at cyl #1 when at TDC. Every cylinder will be on TDC when you adjust it.
Problem with that...has your crank/cam timing correct?
Not positive that had ever been verified.
Did you follow my steps to get timing set, so you can actually watch the spark at 10-15 BTDC?
If so, then you should be able to squirt fuel into the angled vent tubes inside the mouth of the carb, and it should fire and try to run.  I use a refillable restaurant style condiment bottle (clear ketchup bottle).
Right now they're trying to confirm the cam timing.
With all the assumptions and false starts it might be a good idea to have a posted picture of the crank pulley mark and the timing scale to confirm TDC..
What about that brake booster vacuum line that looks open???
I'll look at the brake booster vacuum line once I get to my shop
Thanks.
Next time use a spare plug for that. You're close. Anything connected to the intake must be closed to the outside air. The only air drawn into the engine should go through the carb.
Ok and shouldn't the spark plug be sparking all of the time cause it only sparks in a few different spots and those spots that it sparks in it won't start!
