q-tip Posted July 31, 2015 Report Share Posted July 31, 2015 It's a good thing that there's not covered parking at jrocks, there wouldn't be room for your high horse Naner..... 3 Quote Link to comment
skyblue Posted July 31, 2015 Report Share Posted July 31, 2015 Come on naner everybody has moved on. Enough of your negative attitude. ;) And your leaky house comparison is textbook apples and oranges. You're better than that and you know it. And for the record both my Datsuns leak in the rain, but I ain't complaining. And I paid for those suckers!!! 1 Quote Link to comment
Phixius Posted July 31, 2015 Report Share Posted July 31, 2015 I just wanna see pictures... 2 Quote Link to comment
jrock4224 Posted July 31, 2015 Report Share Posted July 31, 2015 naner chill the fuck out .. u don't need to be everyone's super defender ... ....... health concerns have nothing to do with this truck and why people were speaking up ... and yes i would take that house leaky roof and fix it cause that's what i do anyway, so having a free initial investment i s a bonus .. dont make this about u cause u pay for a house with a leaky roof... lets drop it .. lol 1 Quote Link to comment
Busta Nut Posted August 1, 2015 Report Share Posted August 1, 2015 Does the shifter still smell like Jester?? 7 Quote Link to comment
Charlie69 Posted August 1, 2015 Report Share Posted August 1, 2015 I have no beef with any of you personally just did not like how it was turned that Rick was personally attacking us. I personally was not able to do as much as I would have liked to for the truck and the cause but I did what I could and I am happy I did it. I will continue helping when and where I can. Many of you put countless hours in the truck and opened your wallets way above what any one could have expected. This was a good thing we all did and I am happy Rick has the truck. It is a beautiful truck. I thank all that made this happen. Rick you sir have one truck in a billion. Now more pictures please. 2 Quote Link to comment
dat521gatherer Posted August 1, 2015 Report Share Posted August 1, 2015 Rick I can't wait to see this truck at some meets. I'll show you how to critique the fuck out of that thing. Great truck. Great build. What do you expect from a 620 owner. Sheesh :) 3 Quote Link to comment
tdaaj Posted August 1, 2015 Report Share Posted August 1, 2015 I'm just glad I didn't get it. I would have changed a bunch on it and sold the extra parts 2 Quote Link to comment
Loren O Posted August 1, 2015 Report Share Posted August 1, 2015 If I had won it, I would have talked my dealership manager into having it on display out in our showroom. 2 Quote Link to comment
Guest Rick-rat Posted August 2, 2015 Report Share Posted August 2, 2015 I would post what I got done on the truck, but some would misconstrue it as bitching, complaining, whining, etc. All I can say is if the front end was aligned it would be at Jrocks BBQ tomorrow Busta, Great engine builder ,runs awesome, getting ready to start driving, ,when would you recommend changing the oil? And what weight? Anyone. put in an aftermarket tach, wired as the directions said. Red wire to power when key is on, black to ground , green to negative side of coil, white to lights. Tach will read for a few seconds and then go to zero. Shut off the engine and restart and it will work again for a few seconds and then back to zero, the truck is equipped with a matchbox dizzy, any ideas? Thank you 1 Quote Link to comment
dat521gatherer Posted August 2, 2015 Report Share Posted August 2, 2015 Take that thing over to Daves (pumpkin210) he'll show you how to dress it up real nice. Seriously though I got to see it at Canby but I kept my dirty paws off of it. Maybe look at the 4 cylinder setting on the back of the tach if it has one. I've seen lots of tachs just not work. Sounds like you have it hooked up correctly. It's a new tach right? Maybe play with the wires a little, move the ground ect. 1 Quote Link to comment
Guest Rick-rat Posted August 2, 2015 Report Share Posted August 2, 2015 Yes have it set to 4 cylinder, new tach, second one Redid the ground, connection was not very good where the wires were hooked together, checked other connections, all good ???????????? still doing the same thing 2 Quote Link to comment
q-tip Posted August 3, 2015 Report Share Posted August 3, 2015 The tach might be bad. 1 Quote Link to comment
Guest Rick-rat Posted August 3, 2015 Report Share Posted August 3, 2015 I borrowed an old Mac tools tester for RPM, dwell, and volts. unhooked tach wire from the coil and made a short wire to put on the coil. Hooked that to one of the clips on the tester and clipped the other lead from the tester to the wire to the tach. Worked fine with the tester hooked up. It's an old tester he would probably sell me cheap but it is good sized and can't find a place to mount it. Any ideas anyone???? I am baffled by this. 1 Quote Link to comment
jrock4224 Posted August 4, 2015 Report Share Posted August 4, 2015 well if i won it .... i would have lowered the fuck out of it on some baby blue titans... and no i have no idea about tach ......oh and removed the datslocos sticker 3 Quote Link to comment
Guest Rick-rat Posted August 4, 2015 Report Share Posted August 4, 2015 Lowering it 2 inches with the wheels I put on, the front tires extend past the fenders 1 Quote Link to comment
bilzbobaggins Posted August 4, 2015 Report Share Posted August 4, 2015 Spitballing but if you hook up the tester to the wiring you have run to the cab does it still work? 1 Quote Link to comment
Guest Rick-rat Posted August 4, 2015 Report Share Posted August 4, 2015 The only time it works is when it goes through the tester, 1 wire from the tach in the cab to one lead on the tester, and the other lead to the coil If hooked up w/out the tester the tach will work 4 to 5 seconds and then drop to zero Ran it 10 minutes through the tester and no problems with the tach, worked as it should 1 Quote Link to comment
q-tip Posted August 4, 2015 Report Share Posted August 4, 2015 I would still point my finger at the tach. 1 Quote Link to comment
Guest Rick-rat Posted August 5, 2015 Report Share Posted August 5, 2015 Not going to be mine anymore, truck going back to Al 2 Quote Link to comment
q-tip Posted August 5, 2015 Report Share Posted August 5, 2015 Point your finger dammit, and do it out if anger! 1 Quote Link to comment
jrock4224 Posted August 5, 2015 Report Share Posted August 5, 2015 What, serious ? 1 Quote Link to comment
]2eDeYe Posted August 5, 2015 Report Share Posted August 5, 2015 Lowering it 2 inches with the wheels I put on, the front tires extend past the fenders Any pics with your old/new wheels? :) 1 Quote Link to comment
