Canby 2015 10th anniversary, No Excuses June 13th-14th
Janksun
  • Replies 1.6k
Have replaced the pinion gear back in and will live with the 6.5 MPH fast at 50 MPH. Transmission full of that 'new' GM AC Delco Synchromesh Transmission Fluid. So far it runs about the same as the semi-synthetic I originally had but I wasn't sure if it was totally compatible with the brass rings. Feel better now. Down shifts are maybe a little easier. There was never any grinding just a firm push needed to get into first if rolling around a corner. Now it 'feels' a bit easier. (maybe) Bet this stuff would be the tits in the cold of winter, but I don't drive mine then.
Heater fan switch was totally rusted/frozen and a bitch to get it out. Took apart cleaned and greased and now have a 4th speed!!
Cleaned out leaves plugging fan.
One hose to defrost is missing will try to find something.
man, that sounds like such a good idea but I really don't need that attention.
Depending on when your leaving and if you caravan you would probably blend right in with the rest of the riffraff. :lol:
  • Like 3
