Anderson521 Posted April 30, 2016 Report Share Posted April 30, 2016 Thats some sweet glass, the flush mount will look tits 1 Quote Link to comment
mrbigtanker Posted April 30, 2016 Report Share Posted April 30, 2016 Wow where did you get the glass 1 Quote Link to comment
finney Posted April 30, 2016 Report Share Posted April 30, 2016 Glass looks real nice. I plan on replacing my long side windows in my V520 with a single piece glued in. Looks like the glass is stamped? Did you go with tempered safety glass or just laminated? Any further info on the front 1 piece conversion? 1 Quote Link to comment
Bory Posted April 30, 2016 Author Report Share Posted April 30, 2016 No it's tempered, and tinted, full safety glass, Good news I'm gonna offer the one piece as a kit form 5 Quote Link to comment
Bory Posted May 4, 2016 Author Report Share Posted May 4, 2016 The diff mounts look a little thin compared to the robust frame end. Here are the new brackets I made 1 Quote Link to comment
Bory Posted May 4, 2016 Author Report Share Posted May 4, 2016 Back to 1/4" bar stock 3 Quote Link to comment
Jester Posted May 5, 2016 Report Share Posted May 5, 2016 That's more like it. 1 Quote Link to comment
Bory Posted May 8, 2016 Author Report Share Posted May 8, 2016 Made a body rack out of a piano dolly 7 Quote Link to comment
Bory Posted May 9, 2016 Author Report Share Posted May 9, 2016 Getting better at my beads! Kinda- 4 Quote Link to comment
Draker Posted May 9, 2016 Report Share Posted May 9, 2016 That weld looks pretty good. Nice work 2 Quote Link to comment
Bory Posted May 10, 2016 Author Report Share Posted May 10, 2016 All my boxing and weld clean up on step side mounts and 4 link is almost ready for powder coating 2 Quote Link to comment
Jester Posted May 11, 2016 Report Share Posted May 11, 2016 I really like all the little details throughout this truck. Like the holes in the body mount gussets. 1 Quote Link to comment
Bory Posted May 12, 2016 Author Report Share Posted May 12, 2016 So I'm getting started on the flush mount windshield, which will allow the bonding method rather than the rubber gasket, there is 2 ways of getting this done, 1. Cut a larger ws, 2. Make the receptacle smaller. I Have been quoted up to 7000 bucks for a bigger ws. So I'm gonna do the latter. 2 Quote Link to comment
Bory Posted May 12, 2016 Author Report Share Posted May 12, 2016 After removing rubber, I let the glass slide down till it bottomed out, I used Popsicle sticks for the proper gap. Here you can see how much I have to close up the opening. 2 Quote Link to comment
Bory Posted May 12, 2016 Author Report Share Posted May 12, 2016 The first thing I'm doing is building the new flange, I'm using vertical blinds as a pattern, traced the radius of the top edge, then cut it out and transfer on to some 18 G sheet metal 1 Quote Link to comment
Bory Posted May 12, 2016 Author Report Share Posted May 12, 2016 Here you can see the gap is not consistent 1 Quote Link to comment
mklotz70 Posted May 12, 2016 Report Share Posted May 12, 2016 I think I'd be more tempted to raise the glass to the top and fill in the bottom. I think it would be a lot less noticeable at the bottom and wouldn't affect your field of vision. 2 Quote Link to comment
Bory Posted May 12, 2016 Author Report Share Posted May 12, 2016 Actually it's only 1/2" of fill I have to do, and I actually want a subtle body mod that you can see if you have a good eye for it, kinda like the 63 bugs had slightly smaller side glass than the later ones. Glass is gonna have a 1" of black paint on the edge to hide the butyl bond, with a polished edge. Using the stock glass as a pattern, and have a grey smoke one coming. 1 Quote Link to comment
mklotz70 Posted May 12, 2016 Report Share Posted May 12, 2016 You have a new windshield coming? Why not have it made a 1/2" bigger? It will look pretty sweet with a glued in windshield.....looking forward to seeing it. 1 Quote Link to comment
