Bory Posted January 29, 2014 Report Share Posted January 29, 2014 70 521 with 5.0 conversion. Been working on it pretty hard since last march. Can you give me a heads up on how to transfer pics off my iPhone to share here? 1 Quote Link to comment
TENDRIL Posted January 29, 2014 Report Share Posted January 29, 2014 not sure you can do it on the mobile site.. welcome tho 1 Quote Link to comment
wayno Posted January 29, 2014 Report Share Posted January 29, 2014 You have to use a photo hosting service as far as I know, one like photobucket or picasa. 1 Quote Link to comment
Busta Nut Posted January 29, 2014 Report Share Posted January 29, 2014 photobucket has an app..... upload oics......copy image code by touching it........paste to Ratsun.... 1 Quote Link to comment
Bory Posted January 29, 2014 Author Report Share Posted January 29, 2014 Ok I'll try that 1 Quote Link to comment
wayno Posted January 29, 2014 Report Share Posted January 29, 2014 Give it a try, if you cannot figure it out, PM me and we will get the photos posted. 1 Quote Link to comment
Bory Posted January 29, 2014 Author Report Share Posted January 29, 2014 Ok I'll try to figure it out, stand by- 1 Quote Link to comment
Eagle_Adam Posted January 29, 2014 Report Share Posted January 29, 2014 :rofl: ^^ 1 Quote Link to comment
KlassicMotion Posted January 30, 2014 Report Share Posted January 30, 2014 Welcome. Are you shoving the engine back into the fire wall, or just doping it straight down? Can't wait to see pics. 1 Quote Link to comment
Bory Posted January 30, 2014 Author Report Share Posted January 30, 2014 thats a real good Q, cus i wanted to have a pretty good looking interior, not an astro van looking hump with no room for feet to be the boss of some peddles.. i went with the 90 mustang motor and 4 speed trans..auto that is, lost the fuel injection to simplify the install. going with a holly 600. to answer your Q, straight drop. im retaining the heater box and firewall. i was trippin on a guy who started the same project, with a 289, and was putting the carb under the firewall, that thing was deep in the cab, but then like many others his progress stopped, and God only knows what happen with his project. basic design is pulleys right on grill and a mustang 4 core in the bed. i used the torsion tunnels to run the 1- 1/2" coolant pipes to the rear. the 521 road real low with no suspension resistance, so i converted the shock tower to a coil over system. this called for a 3-1/4" tower stretch to get the ride height right where i want it. runnin 3" block and 2" de-arch on stock rear springs.runnin the stock fuel tank behind the axle turned a 1/4 turn. exhaust is 3 chamber flowmasters located in the bed behind the wheel wells. im trying to keep the air as cool as i can under the truck due to the fact, that is where my air intake is. im running two 10" fans as pullers, my headers are swapped from left to right so now they point forward, so they will loop forward and under the cross member just past the cab and thru the bed floor to the outside edge and over the wheelwells and into the fm's. one of the coolest mods i did was run 245/16 in the rear, but they stuck out, so i split the entire length of the bed from front to back on both sides, directly in the center of the wheelwell, 7/8" so now the bed has a wider look, but suttle. 9 out of 10 guys wont notice but real datsun guys will. i have some bitchin pics of all of this shite, but my kids are gonna show me how to get them on tonight.. wish me luck. 2 Quote Link to comment
KlassicMotion Posted January 30, 2014 Report Share Posted January 30, 2014 Can't wait to see the pics! 1 Quote Link to comment
Eagle_Adam Posted January 30, 2014 Report Share Posted January 30, 2014 no pics yet?........ 2 Quote Link to comment
Busta Nut Posted January 30, 2014 Report Share Posted January 30, 2014 Pics or it doesn't exist......... :P ............poor word to oic ratio..... 2 Quote Link to comment
Bory Posted January 30, 2014 Author Report Share Posted January 30, 2014 Down loaded to photobucket but still having issues 1 Quote Link to comment
Eagle_Adam Posted January 30, 2014 Report Share Posted January 30, 2014 paste the IMG link from photobucket here 1 Quote Link to comment
Bory Posted January 30, 2014 Author Report Share Posted January 30, 2014 Ok I got this. That was a test. 3 Quote Link to comment
Bory Posted January 31, 2014 Author Report Share Posted January 31, 2014 So this is what it looked like The day I got it at Pomona. The only mod it had was 4 wheel disc. Pathfinder front trooper rear. 1 Quote Link to comment
Bory Posted January 31, 2014 Author Report Share Posted January 31, 2014 Pretty boned out! Quote Link to comment
Bory Posted January 31, 2014 Author Report Share Posted January 31, 2014 Oops the middle. One is the parts getter. Quote Link to comment
Bory Posted January 31, 2014 Author Report Share Posted January 31, 2014 The day it puked its factory goods out. The doner. 90 5.0 4 speed auto. Mild build. Quote Link to comment
Bory Posted January 31, 2014 Author Report Share Posted January 31, 2014 Just checking to see if they can get along. Quote Link to comment
Bory Posted January 31, 2014 Author Report Share Posted January 31, 2014 Pretty close but doable. Quote Link to comment
