Bory Posted February 2, 2014 Author Report Share Posted February 2, 2014 Here it's kinda hard to see how close the steering box is to the remote oil filter fitting. The oil filter would stick out towards the box by at least 5". So the filter will be mounted on the fender well and the return line will run to the oil cooler at the bed. Quote Link to comment
mrbigtanker Posted February 2, 2014 Report Share Posted February 2, 2014 Is that how the cooling water lines are going to be mounted,cant you go under the headers,at least on the drivers side instead of over the top. Quote Link to comment
Jester Posted February 2, 2014 Report Share Posted February 2, 2014 Subscribed and waiting for this answer too. I'm having a hard time finding this idea looking good when you lift the hood to show off your skills. Not judging, just saying. Regardless, COOL BUILD! :thumbup: :thumbup: 1 Quote Link to comment
denmarkboy Posted February 2, 2014 Report Share Posted February 2, 2014 Here it's kinda hard to see how close the steering box is to the remote oil filter fitting. The oil filter would stick out towards the box by at least 5". So the filter will be mounted on the fender well and the return line will run to the oil cooler at the bed. by the time you get done your middle name will be "tight fit" beleive me i know Quote Link to comment
Bory Posted February 3, 2014 Author Report Share Posted February 3, 2014 Lets not forget about the steering shaft boys. I'll have to run 2 universal joints to get past the header. Thus the reason for over the top. Quote Link to comment
Bory Posted February 3, 2014 Author Report Share Posted February 3, 2014 One man show, getting ready to marry the two. 1 Quote Link to comment
Bory Posted February 3, 2014 Author Report Share Posted February 3, 2014 A little closer 1 Quote Link to comment
Bory Posted February 3, 2014 Author Report Share Posted February 3, 2014 There we go. 4 Quote Link to comment
wayno Posted February 3, 2014 Report Share Posted February 3, 2014 This all looks vaguely familiar. :) Quote Link to comment
KlassicMotion Posted February 3, 2014 Report Share Posted February 3, 2014 Nice stance! Quote Link to comment
Jester Posted February 3, 2014 Report Share Posted February 3, 2014 Engine shot please. Quote Link to comment
denmarkboy Posted February 3, 2014 Report Share Posted February 3, 2014 I LIKE THOSE THAT DO !! Quote Link to comment
Bory Posted February 5, 2014 Author Report Share Posted February 5, 2014 So heres what the new engine bay looks like, I hope I don't have to lift the cab off again you can only imagine how many times I did that Notice how close the bolt is off the pulley tensioner, it's actually partly under the core support 1 Quote Link to comment
Bory Posted February 5, 2014 Author Report Share Posted February 5, 2014 Freewheel pulley, formerly known as smog pump. Alt pulley Quote Link to comment
Bory Posted February 5, 2014 Author Report Share Posted February 5, 2014 This is all I cut out of the floor and it almost fits right back in. I'm gonna have to raise it a bit tho cus the shifter actually mounts to the trans. Quote Link to comment
Bory Posted February 5, 2014 Author Report Share Posted February 5, 2014 This view is from above looking at the steering shaft, that is the u-joint at the firewall This is thru the fender well, and you can also see the second u-joint off the steering box. I'm using 1-2" copper pipe to mock up the length of shaft. 1 Quote Link to comment
Bory Posted February 5, 2014 Author Report Share Posted February 5, 2014 Now as you know the factory shaft is a solid pipe that runs all the way up to the wheel, then it has the inner shaft that the wheel actually turns. I cut the outer pipe 2" from the flange that bolts or to the box. And I cut the steering shaft (inner) 3/4" longer than the outer. The u-joint will mount to the inner shaft from there. One other thing I have to keep in mind is I need to make a seal that fits over the outer tube and seals against the shaft to keep the gear oil in. Ok so stay with me, the inner shaft locates at two points at the steering box and with a plastic bushing way at the top just behind the wheel. After I cut and welded a flange on the outer shaft to mount to the firewall, I had to figure out a way to keep the slop out of the shaft at the base of the outer tube at the firewall. So this is what I came up with. Quote Link to comment
Bory Posted February 5, 2014 Author Report Share Posted February 5, 2014 Middle and right is scrap left over from the two shafts cus I shortened it a bit cus I'm 6'-1". On the left is the bushing that I cut out of some real hard plastic used for bushing on aircraft. Notice that it's off center to help cheat it down some. So when mounted like so it will look like this. These are just to show you guys. The actual one has a flange that will screw to the firewall Quote Link to comment
Jester Posted February 5, 2014 Report Share Posted February 5, 2014 Nice idea. Looking great. Keep it up. Quote Link to comment
Bory Posted February 5, 2014 Author Report Share Posted February 5, 2014 Thanks jester! Quote Link to comment
Eagle_Adam Posted February 6, 2014 Report Share Posted February 6, 2014 Bravo !!! Attention to detail here is awesome Quote Link to comment
Bory Posted February 6, 2014 Author Report Share Posted February 6, 2014 Thanks E_A!! Quote Link to comment
Bory Posted February 18, 2014 Author Report Share Posted February 18, 2014 [/url Well messing with rust repair now Quote Link to comment
Bory Posted February 18, 2014 Author Report Share Posted February 18, 2014 [url=" New panel tacked in 1 Quote Link to comment
