Bory Posted March 26, 2014 Author Report Share Posted March 26, 2014 That's all sold at Home Depot and just so you know that crimping tool is about 18" long it does 1/64-3/16 cable. My cable was a tad bigger than 3/16" so I drilled out the 3/16 retainer to the next size up it worked tits. 2 Quote Link to comment
Bory Posted March 27, 2014 Author Report Share Posted March 27, 2014 Finally got my steering shaft measured and off to my welding shop. After that is figuring out brake pedal and gas pedal. Brake pedal will be the clutch pedal shifted to the right a bit. Gas pedal will be the mustang. This is gonna be a two feet gas and brake drive, much like a go cart. My leg hits the steering wheel if I try to brake with my right foot. So well see 1 Quote Link to comment
Bory Posted March 30, 2014 Author Report Share Posted March 30, 2014 Finally got my steering done! Quote Link to comment
Bory Posted March 30, 2014 Author Report Share Posted March 30, 2014 Hard to see the shaft but it's in there Quote Link to comment
BlackBird620 Posted March 30, 2014 Report Share Posted March 30, 2014 How much longer till we see a start up video Quote Link to comment
Bory Posted March 30, 2014 Author Report Share Posted March 30, 2014 Funny you asked, just thinking this morning that my next few steps is wiring the starter carb and easy non conversion and fab work So I'm hoping within 4 weeks. Quote Link to comment
Bory Posted March 30, 2014 Author Report Share Posted March 30, 2014 Took some of the day off from wrenching on Datstang 521, to get this little guy ready for eBay 2 Quote Link to comment
Bory Posted March 30, 2014 Author Report Share Posted March 30, 2014 Oh ya, and got this one fired up after 12 years in storage also on eBay 2 Quote Link to comment
Bory Posted March 31, 2014 Author Report Share Posted March 31, 2014 So messin with Britts. Quote Link to comment
Bory Posted March 31, 2014 Author Report Share Posted March 31, 2014 Here is the clutch pedal that I'm using as the brake pedal, I'm spacing it over to the right a little, but it will give me a little more room for work type shoes I use often. This shoulder bolt and hardware I picked up at ace which has a pretty good pick of this stuff. You can also see a bit of the ford brake booster I'm using. 1 Quote Link to comment
Bory Posted March 31, 2014 Author Report Share Posted March 31, 2014 So this is the view of the pedals and steering shaft base. Notice the ford gas pedal. Will use the ford throttle cable as well as the kickdown cable. 1 Quote Link to comment
Bory Posted April 1, 2014 Author Report Share Posted April 1, 2014 Bolted the cab down for good, and now running cooling lines to the rear 1 Quote Link to comment
Bory Posted April 1, 2014 Author Report Share Posted April 1, 2014 Remote oil filter, engine oil lines, fuel line,and brake lines on for this afternoon. Quote Link to comment
Bory Posted April 2, 2014 Author Report Share Posted April 2, 2014 1/2" oil cooling lines 1 Quote Link to comment
Bory Posted April 2, 2014 Author Report Share Posted April 2, 2014 Here are the oil cooling lines heading towards the bed that house the cooling coils. Quote Link to comment
Bory Posted April 2, 2014 Author Report Share Posted April 2, 2014 Next step, mount Bed and hook up all radiators Quote Link to comment
Bory Posted April 3, 2014 Author Report Share Posted April 3, 2014 I put a protective film on the 1/2" aluminum oil cooler lines, much like a clear bra that is being installed on late model cars. Should really help on vibration and corrosion control Quote Link to comment
Bory Posted April 4, 2014 Author Report Share Posted April 4, 2014 With a double flare tool, I put a barb fitting end on it to make a stop for the hose. Double hose clamps will also help. 1 Quote Link to comment
Bory Posted April 7, 2014 Author Report Share Posted April 7, 2014 Added this to the collection but might just flip it. Quote Link to comment
Bory Posted April 8, 2014 Author Report Share Posted April 8, 2014 Looking like a truck again! Quote Link to comment
Bory Posted April 10, 2014 Author Report Share Posted April 10, 2014 Factory steering shaft hole at firewall, made custom plate that is removable for service. Stay tuned. Quote Link to comment
Bory Posted April 14, 2014 Author Report Share Posted April 14, 2014 Top view of steering shaft painted and complete. Quote Link to comment
