Project Datstang
Bory
  • Replies 1.7k
So its different but why not just stay with all aftermarket gauges,Now it looks like you were going for a right hand drive and after the dash was made you quit.
Also make sure you did not bend the needle for the speedometer, they are fragile and when putting back together they can hang up,ask me how I know.
Is there a way or did you find a way to make the factory speedo work with the Mustang tranny?
Ya I got that figured out, the ford cable drives the speedo just perfect, I just need to use a hose clamp to retain it. I liked the look of the factory cluster so I moved it over a bit. I won't see another dash like mine, and that's the what I'm after. See it first here! You copy?
