Bory Posted June 1, 2014 Author Report Share Posted June 1, 2014 So I pull up to my buddy's shop to check the progress, and not only have they not touched it in two weeks, but they pushed outside cus it's in the way. So I got a few sick shots. Quote Link to comment
Bory Posted June 1, 2014 Author Report Share Posted June 1, 2014 Def have to have a plate frame that reads CAUTION FREQUENTLY SIDEWAYS Quote Link to comment
izzo Posted June 1, 2014 Report Share Posted June 1, 2014 A few years ago there was an autocross the friday before canby. IDK if they still do it or not. Contact DVBoth here on ratsun. He is part of the group that puts on the show and would know more info if they still do it or not. Quote Link to comment
Bory Posted June 1, 2014 Author Report Share Posted June 1, 2014 Ok cool thanks Izzo. Quote Link to comment
Bory Posted June 1, 2014 Author Report Share Posted June 1, 2014 Here is good view of the rear fender area, if you look at the bottom edge you can see the slight flare on this angle. Quote Link to comment
KlassicMotion Posted June 4, 2014 Report Share Posted June 4, 2014 The Mustang wheels look better on your truck than they do on the Mustang! Is there enough backspacing to be able to run a lug adapter and put the other Mustang wheels up front?.... Or maybe you have other plans? Quote Link to comment
Bory Posted June 4, 2014 Author Report Share Posted June 4, 2014 I'm trying to swing that but I might have to do a re drill. I'm in tenn at the moment at a good friends wedding. Till sun. But the datstangs wiring is done and I'm doing an initial fire up on Monday. So dang excited!! One of you guys will have to let me know how to post video. Quote Link to comment
BlackBird620 Posted June 5, 2014 Report Share Posted June 5, 2014 Upload to YouTube and share player link in text like so you might have to quote me to see exactly Quote Link to comment
Bory Posted June 5, 2014 Author Report Share Posted June 5, 2014 Tits! Thanks BB6 Quote Link to comment
BlackBird620 Posted June 5, 2014 Report Share Posted June 5, 2014 Tits! Thanks BB6 no problem man keep up the good work Quote Link to comment
Bory Posted June 11, 2014 Author Report Share Posted June 11, 2014 Good and bad, so I did an initial fire up and it started right up and sounds super bitchin. Top off Trans with about 12 quarts, with lines and cooler. But never went into gear. Had to pull the dang thing out. Took me 7 frickin hours. There was so much shit to disconnect with cooling lines exhaust cooling lines fluid lines. Just sucks. I did a bench job on it so no clue what's up. Trans guys said he thinks it's the pump. Pics to follow. Quote Link to comment
Ranman72 Posted June 11, 2014 Report Share Posted June 11, 2014 this is one of those trucks you pull the body to change the tranny Quote Link to comment
Bory Posted June 11, 2014 Author Report Share Posted June 11, 2014 I almost had to, had to disconnect one side and lift it up to get the Trans x member I made out. Half the battle was trying to save work and have to do it anyway. Super frustrating day. I should be doing burnouts Right now. Quote Link to comment
datsunfreak Posted June 12, 2014 Report Share Posted June 12, 2014 I should be doing burnouts Right now. If you had used a manual trans, you would be... :rofl: I keed. B) Quote Link to comment
Bory Posted June 13, 2014 Author Report Share Posted June 13, 2014 I wish the doner car was a T5 car. I got the Trans back the same day and reinstalled. So smokys Coming up!! 1 Quote Link to comment
Bory Posted June 16, 2014 Author Report Share Posted June 16, 2014 Why in the trunk of a focus? Quote Link to comment
Bory Posted June 16, 2014 Author Report Share Posted June 16, 2014 Found out that the shifter used In the foxbody is a hammer ratchet b&m. It's hard to adjust and burns clutches out if not so I'm looking for a stock foxbody aod shifter. Quote Link to comment
Redboxracing Posted June 18, 2014 Report Share Posted June 18, 2014 I know when I put the aod in my 82 mustang I had to buy an adapter tv cable to use with carb or else you won't have any pressure rise when you step on the gas and trans will burn up real fast Quote Link to comment
Bory Posted June 18, 2014 Author Report Share Posted June 18, 2014 Was it the kick down cable? Quote Link to comment
Redboxracing Posted June 19, 2014 Report Share Posted June 19, 2014 It is a TV cable not a kickdown cable. It controls shift timing and pressure. If not hooked up and adjusted you will burn your trans up. Google it to understand better Quote Link to comment
Bory Posted June 19, 2014 Author Report Share Posted June 19, 2014 Oh ya I have that cable all worked out, had to cut a section off the throttle body linkage from the fox, and weld it to the holly I'm using, to get the right angle for the cable, plus had to make a special bracket to mount the cable to the carb. Quote Link to comment
