q-tip Posted September 17, 2014 Report Share Posted September 17, 2014 I've received that look before in my 510, its a good feeling isn't it Quote Link to comment
Bory Posted September 17, 2014 Author Report Share Posted September 17, 2014 They so under estimate you, it's not even funny, I like it that way, thus the reason we build em- SLEEPERS Quote Link to comment
q-tip Posted September 17, 2014 Report Share Posted September 17, 2014 Yours at least has a burly sound when it just sitting, mine you can hear all of the body panels rattling and that's it. :lol: 3 Quote Link to comment
Bory Posted September 19, 2014 Author Report Share Posted September 19, 2014 That made me laugh Quote Link to comment
Bory Posted September 22, 2014 Author Report Share Posted September 22, 2014 Do I see a for sale sign on the Datstang? Quote Link to comment
q-tip Posted September 22, 2014 Report Share Posted September 22, 2014 Well that would suck Quote Link to comment
Bory Posted September 30, 2014 Author Report Share Posted September 30, 2014 Was down for a week, the hybrid dist,, which is a ford bottom end and HEI top end, used from 75 to about 86 or so, on GM cars, failed, summit racing sent me a new one, up and smokin tires again!! Quote Link to comment
q-tip Posted September 30, 2014 Report Share Posted September 30, 2014 Good to hear! Quote Link to comment
datsunfreak Posted September 30, 2014 Report Share Posted September 30, 2014 Was down for a week, the hybrid dist,, which is a ford bottom end and HEI top end, used from 75 to about 86 or so, on GM cars, failed, summit racing sent me a new one, up and smokin tires again!! A bit worried as that's what's in the V8 B210 we're building... Seems to be a common problem with the non-OEM dizzies though. Most guys I've talked to that ran into this problem just bought all GM stuff for the top end and it worked fine. So there's a chance you might run into this problem again down the road... Quote Link to comment
Bory Posted September 30, 2014 Author Report Share Posted September 30, 2014 Ya what I found was the retainer clip holding down the coil pickup fell off on the main shaft and the pickup had wiggle room, the shaft starts to contact the dist body causing ware and friction on the shaft, creating heat and cooking the pick up, then it lost spark. So this is my second go around, but at least summit sent me an other right quick. For free. Quote Link to comment
Jester Posted October 2, 2014 Report Share Posted October 2, 2014 Good on them for standing behind what they sell. Try getting that treatment on ebay. Quote Link to comment
Bory Posted October 2, 2014 Author Report Share Posted October 2, 2014 Ya it was quick too, like 3 days, and I Havnt even sent the old part back yet. Feel kinda bad about that tho, waiting on them to see if I need any paper work to send it back Quote Link to comment
jrock4224 Posted October 2, 2014 Report Share Posted October 2, 2014 is this a jet boat or a truck build ? Quote Link to comment
Bory Posted October 3, 2014 Author Report Share Posted October 3, 2014 I was thinking of mounting a dummy Berkeley Jet housing on the back just to continue to trip peeps out -ha Quote Link to comment
Bory Posted October 7, 2014 Author Report Share Posted October 7, 2014 I'm in the middle of making a trade for a T-5 Trans That will really fin this build off. Notrealhappywith this AOD. Shoot, looks like I need #, In front of those run on words. Quote Link to comment
ratsun73 Posted October 14, 2014 Report Share Posted October 14, 2014 are you running a pump in the coolant line anywhere or is it just the one on the engine? Quote Link to comment
Bory Posted October 14, 2014 Author Report Share Posted October 14, 2014 Water pump only, I'm running the factory 90 serpentine system, so the water pump runs in reverse to the engine rotation, but it keeps up well. Runs at 200 on freeway but in traffic it drops it down to 185 with the two 12" fans running. Quote Link to comment
ratsun73 Posted October 15, 2014 Report Share Posted October 15, 2014 great thanks...you probably already covered this but what radiator and fans are you running? Quote Link to comment
Bory Posted October 15, 2014 Author Report Share Posted October 15, 2014 I'm running flex a light 2 -12" fans which were a 90 mustang aftermarket app. Also a no name aluminum rad with cross flow with same app. Both aftermarket. Quote Link to comment
Bory Posted October 24, 2014 Author Report Share Posted October 24, 2014 At a local car show, plus I can't stand when I roll into page 3- over here Quote Link to comment
Bory Posted October 24, 2014 Author Report Share Posted October 24, 2014 Pulled the Yenko out too! Quote Link to comment
Bory Posted October 24, 2014 Author Report Share Posted October 24, 2014 I did an engine bay temp test, Lowered engine bay 5 degrees, by spacing the hood up at hinges, 1-1/4". Now the heat under the truck is 5 degrees cooler, which lowered engine temp, due to air exchanging thru rad, 5 D lower. Quote Link to comment
q-tip Posted October 24, 2014 Report Share Posted October 24, 2014 We used to do that on the circle track cars all the time, it makes just enough of a difference sometimes. Quote Link to comment
Bory Posted October 24, 2014 Author Report Share Posted October 24, 2014 Ya it does, it got me under 200, on the freeway in 100 degree day Quote Link to comment
