Bory Posted October 24, 2014 Author Report Share Posted October 24, 2014 Before- and after a complete 5.0 mustang drive train!! 3 Quote Link to comment
Jester Posted October 25, 2014 Report Share Posted October 25, 2014 There are a couple different ways to go 5 lug on the front. :poke: just say'n. :thumbup: Quote Link to comment
datsunfreak Posted October 26, 2014 Report Share Posted October 26, 2014 I think his back is 4-lug though... ^_^ Quote Link to comment
Jester Posted October 26, 2014 Report Share Posted October 26, 2014 Yep. My bad. Quote Link to comment
Bory Posted October 27, 2014 Author Report Share Posted October 27, 2014 I have the mustang rotor, I tried to get bearings that would work on the 521 spindle, to run the ford rotor, but I had no success. I still think it could be done, but I need a real good bearing builder to spend a little time with it Quote Link to comment
q-tip Posted October 27, 2014 Report Share Posted October 27, 2014 Maybe machine some sleeves for the rotor to fit the 521 bearings, if that could be done at all. I don't know what the two parts you're working with look like so I'm just throwing out ideas. 1 Quote Link to comment
Bory Posted October 27, 2014 Author Report Share Posted October 27, 2014 Ya I guess what it would be. Is, I would have to cut my own race. Best thing would be to take both rotors to a machinist and we would need 521 inside diameter, and ford outside diameter, on both inside and outside bearings. Offset of rotor to caliper is important too. Quote Link to comment
q-tip Posted October 27, 2014 Report Share Posted October 27, 2014 Yeah, it would be some math and measuring for sure but making the sleeves themselves would not be too difficult. You could even use the 521 bearings and races so the parts will always be as close to stock spec as you can get. Quote Link to comment
Bory Posted October 28, 2014 Author Report Share Posted October 28, 2014 It would be sick to run the pony wheels on all corners Quote Link to comment
Bory Posted October 31, 2014 Author Report Share Posted October 31, 2014 Gonna do trunk or treat tonight, with Datstang and his buddy Yenko. Pics to come. Quote Link to comment
Bory Posted October 31, 2014 Author Report Share Posted October 31, 2014 At trunk or treat at CCV 2 Quote Link to comment
Bory Posted October 31, 2014 Author Report Share Posted October 31, 2014 Look at the number of my replies For all you 5 dimers out there! Quote Link to comment
Bory Posted November 3, 2014 Author Report Share Posted November 3, 2014 Just can't get enough of this power train!! 1 Quote Link to comment
Bory Posted November 4, 2014 Author Report Share Posted November 4, 2014 Hei issues, if you don't run a pcv valve oil residue works it's way int the dist. and spark failure is the result. Installed the pcv, but not before it gummed up the pick up, so I hope contact cleaner will help get back to the house and wait till summit sends me a new one. 1 Quote Link to comment
jeremy_crager Posted November 5, 2014 Report Share Posted November 5, 2014 Bory, you wouldn't happen to know the part# of the seal you used on your steering shaft would you? Quote Link to comment
Bory Posted November 5, 2014 Author Report Share Posted November 5, 2014 Let me check Quote Link to comment
Bory Posted November 5, 2014 Author Report Share Posted November 5, 2014 I have to check my hard copy receipts The guy at my mom and pops, is a Dino, and not on computer Quote Link to comment
jeremy_crager Posted November 5, 2014 Report Share Posted November 5, 2014 Cool man. If its any problem don't worry about it. I was just wondering. Cause I'm doing something similar Quote Link to comment
Bory Posted November 6, 2014 Author Report Share Posted November 6, 2014 I got two that day but don't know which one I used 1. Is national brand part number 221720 2. Is national brand part number 8660S Hope this helps, now both of these still needs the base of the shaft to be machined out to receive these seals. They don't just fit right in. Just so you know. Quote Link to comment
jeremy_crager Posted November 7, 2014 Report Share Posted November 7, 2014 Thanks a ton man I really really appreciate it. Quote Link to comment
Bory Posted November 7, 2014 Author Report Share Posted November 7, 2014 You got it JC! Quote Link to comment
Bory Posted November 7, 2014 Author Report Share Posted November 7, 2014 Well I found out what's causing me to be on my 3rd HEI dist. Looks like I have a high volume oil pump, and they seam to be a tad longer, so when I snug my dist. Down it pushes the shaft up so it has no end play, which wares the retainer clip out and creates all the shavings that the magnet on the pick up grabs on to. Then with all that steel wool in there it burns out the module. So I spaced it out by installing a shim about 30 K of an inch. Got my end play back, and now I should be tits! 2 Quote Link to comment
