Bory Posted April 15, 2014 Author Report Share Posted April 15, 2014 Here's a look up at the radiator intake from under the truck. Got the cooling lines hooked up, had to cross them so they flow the correct direction thru the radiator notice the 1/2" cooling lines for the oil cooler. Quote Link to comment
southern620 Posted April 16, 2014 Report Share Posted April 16, 2014 this is a very nice build. Quote Link to comment
Bory Posted April 16, 2014 Author Report Share Posted April 16, 2014 Thanks S6, as you can see, I left the entire belly of the truck in its original patina finish, by design. Quote Link to comment
Bory Posted April 20, 2014 Author Report Share Posted April 20, 2014 So I always wanted a rt hand drive car. So I came up with this idea. Quote Link to comment
Bory Posted April 20, 2014 Author Report Share Posted April 20, 2014 I did not want a big tach and bolt on gauges so I pushed the factory speedo cluster to the right side. Quote Link to comment
Bory Posted April 20, 2014 Author Report Share Posted April 20, 2014 Using the glove box door as a gauge panel for a nice big tach and oil & temp gauge Quote Link to comment
Bory Posted April 20, 2014 Author Report Share Posted April 20, 2014 Integrated shift light, with room for a volt gauge on the right. Quote Link to comment
Bory Posted April 20, 2014 Author Report Share Posted April 20, 2014 Back of cluster bezel has a missing and broken mount area Quote Link to comment
Bory Posted April 20, 2014 Author Report Share Posted April 20, 2014 So I made this little pod out of 2 part epoxy, that I will drill and tap for the new retainer I made out of hose clamp. Quote Link to comment
Bory Posted April 21, 2014 Author Report Share Posted April 21, 2014 A look at the retainer clip I made Quote Link to comment
Bory Posted April 21, 2014 Author Report Share Posted April 21, 2014 Moving to detailing the cluster. Quote Link to comment
Jester Posted April 21, 2014 Report Share Posted April 21, 2014 I totally forgot the 520/521 had a GLASS gauge panel. Quote Link to comment
Bory Posted April 21, 2014 Author Report Share Posted April 21, 2014 Jester that was gonna be my next post. Talk about a hard time replacing it. It's so dang thin!! But good eye jester. Quote Link to comment
datsunfreak Posted April 22, 2014 Report Share Posted April 22, 2014 This is awesome. :thumbup: Kinda wishing we had done a rear mounted radiator on ours now... :rofl: Quote Link to comment
