Bory Posted February 18, 2014 Author Report Share Posted February 18, 2014 Welded and sealed with 3-M body seal Quote Link to comment
Bory Posted February 18, 2014 Author Report Share Posted February 18, 2014 Then undercoating 1 Quote Link to comment
Bory Posted February 18, 2014 Author Report Share Posted February 18, 2014 Part of the Trans hump that had some cancer Quote Link to comment
Bory Posted February 18, 2014 Author Report Share Posted February 18, 2014 New piece made and rolled into shape Quote Link to comment
Bory Posted February 18, 2014 Author Report Share Posted February 18, 2014 Welded into place Quote Link to comment
Jester Posted February 18, 2014 Report Share Posted February 18, 2014 I love the carpet. Very attractive! Haha 1 Quote Link to comment
Bory Posted February 18, 2014 Author Report Share Posted February 18, 2014 Good Eye, makes for a nice butt pad! Quote Link to comment
denmarkboy Posted February 19, 2014 Report Share Posted February 19, 2014 Good Eye, makes for a nice butt pad! thats pretty funny, i use old cushions from the kitchen chairs. movin right along here. before you know it you will be out scaring the neighborhood honda punks back into there driveways.. Quote Link to comment
Bory Posted February 19, 2014 Author Report Share Posted February 19, 2014 Ya DB, can't wait. Quote Link to comment
Bory Posted February 23, 2014 Author Report Share Posted February 23, 2014 16D68340DD3D_zps2iagswwy.jpg[/img][/url] Here I have the steering box shaft flange in the lathe. Cutting it back to lower it as close to the box as possible. Quote Link to comment
JoeCool Posted February 23, 2014 Report Share Posted February 23, 2014 That thing is going to be awesome when it is finished, and props for using a GOOD motor instead of an ugly GM LSPOS! Quote Link to comment
Bory Posted February 23, 2014 Author Report Share Posted February 23, 2014 Couple of months I hope. New length Quote Link to comment
Bory Posted February 23, 2014 Author Report Share Posted February 23, 2014 Cutting the groove for the new oil seal Quote Link to comment
Bory Posted February 23, 2014 Author Report Share Posted February 23, 2014 After lathe Quote Link to comment
Bory Posted February 23, 2014 Author Report Share Posted February 23, 2014 Seal installed 1 Quote Link to comment
Bory Posted February 23, 2014 Author Report Share Posted February 23, 2014 Here is the gear after I cut a double d on the shaft. Notice the set screw seats. Quote Link to comment
Ranman72 Posted February 23, 2014 Report Share Posted February 23, 2014 wow I am loving this truck nice work Quote Link to comment
Bory Posted February 23, 2014 Author Report Share Posted February 23, 2014 So here is the new look of the steering box with the first universal joint in place. Now I will be able to avoid contact with the header. 2 Quote Link to comment
Bory Posted February 23, 2014 Author Report Share Posted February 23, 2014 So from that u- joint I will use double - D shaft to the second u- joint that will connect to the shaft that is coming out of the plastic bushing at the firewall I showed earlier. Quote Link to comment
Bory Posted February 24, 2014 Author Report Share Posted February 24, 2014 After reassembly new seals and a fresh squirt of semi gloss black. 3 Quote Link to comment
Bory Posted March 10, 2014 Author Report Share Posted March 10, 2014 So I pulled the 3rd member to ckeck the gearing, and found 39:8, that's 4:87. A tad low. So now I'm forced to change the rear end out to the 8.8. From the mustang. It has 3:73 and it's a posi. Only thing is I have to narrow it and convert from coil springs to leaf. The 8.8 is C clip type so hard to shorten. I found a place in LA that does it, and I will shorten the housing. A total of 5.5" is coming off. 2 Quote Link to comment
Bory Posted March 10, 2014 Author Report Share Posted March 10, 2014 Factory 521 rear end is for sale now and it comes with the disc brake conversion. If you know anyone. Quote Link to comment
Bory Posted March 10, 2014 Author Report Share Posted March 10, 2014 This is stock mustang 8.8. Notice all the hangers and junk for coil system Quote Link to comment
Bory Posted March 10, 2014 Author Report Share Posted March 10, 2014 Here it is all free of the coil spring set up and off to my housing shop Quote Link to comment
