KiloTango1200 Posted February 12, 2014 Author Report Share Posted February 12, 2014 Looks like its just surface rust. Looks like its just surface rust. Lots of surface rust but very little structural or rust through on this car. Quote Link to comment
KiloTango1200 Posted February 12, 2014 Author Report Share Posted February 12, 2014 The right rear Datsun emblem looked like it was covering a lot of rust. Yep, I was right. It came off in 3 pieces. Back of the right side emblem. Left side rear emblem looks OK. Wow, no rust, just dirt and grime. This shows 1 of the 3 very minor dents on the whole car. A little time with a hammer and dolly will make it as good as new. Left emblem top. Right emblem with all the rust, metal and paint sticking to it, bottom. I now need to pull the emblems off the trunk lid. It looks like they must be pried off the trunk lid since there is no access to the back of the emblem. Once again, They gotta come off but I don't want to screw anything up. Any info is appreciated. 1 Quote Link to comment
KELMO Posted February 12, 2014 Report Share Posted February 12, 2014 KT, I used what is called a bone tool (insert joke here), to remove my badges. It is a flat tool with sort of a chisel type design only with a longer slope to the chisel part. I would post a pic but not currently at the house. I would look for a interior trim removal tool kit possibly harbor freight. Also a little PBlaster to soak in as the deck lid badge is held on in the same manner as the side badges using those annoying metal clamp/spring thingamajiggys 1 Quote Link to comment
KiloTango1200 Posted February 12, 2014 Author Report Share Posted February 12, 2014 KT, I used what is called a bone tool (insert joke here), to remove my badges. It is a flat tool with sort of a chisel type design only with a longer slope to the chisel part. I would post a pic but not currently at the house. I would look for a interior trim removal tool kit possibly harbor freight. Also a little PBlaster to soak in as the deck lid badge is held on in the same manner as the side badges using those annoying metal clamp/spring thingamajiggys KT, I used what is called a bone tool (insert joke here), to remove my badges. It is a flat tool with sort of a chisel type design only with a longer slope to the chisel part. I would post a pic but not currently at the house. I would look for a interior trim removal tool kit possibly harbor freight. Also a little PBlaster to soak in as the deck lid badge is held on in the same manner as the side badges using those annoying metal clamp/spring thingamajiggys Thanks KELMO Quote Link to comment
ggzilla Posted February 12, 2014 Report Share Posted February 12, 2014 Removing the rear quarter panel badges can be done by tapping the pins from behind. So then the badge won't break. Quote Link to comment
KiloTango1200 Posted February 12, 2014 Author Report Share Posted February 12, 2014 Removing the rear quarter panel badges can be done by tapping the pins from behind. So then the badge won't break. That's the way I removed the quarter panel badges, The one on the right was already cracked. Quote Link to comment
Dirttrack510 Posted February 17, 2014 Report Share Posted February 17, 2014 I would be interested in the price and pictures of the shell. New Mexico is doable. I figured if I found a shell it would be in Cali, but that would be a stretch to pick up. If the windshield is shot then we could fab one out of Plexi. Don't use plexi, buy some Lexan, it won't crack on you. Much more durable for a little more money. :) 2 Quote Link to comment
KiloTango1200 Posted February 17, 2014 Author Report Share Posted February 17, 2014 Don't use plexi, buy some Lexan, it won't crack on you. Much more durable for a little more money. :) Got a good engine less car from Dimlight65 that has all the glass. But good to know. Quote Link to comment
KiloTango1200 Posted February 20, 2014 Author Report Share Posted February 20, 2014 Finally, after 2 months of almost nightly work, wheel # 3 is finished for the Sedan. I would use 180,220,400,600,800,1000,1500, 2000 sandpaper then Flitz metal polish. When I got to the Flitz you could see all the low spots. For about 20 rounds of work you could barely see the bad spots at the end of the 1500 grit work. 2000 grit work the low spots showed up a little more. When I hit it with Flitz It looked like Shitz. I finally got it smooth and shiny as the other wheels. I don't have any fingerprints left. They are all sanded away! I hope wheel # 4 doesn't kick my ass the way wheel # 3 did. Wheel # 2 left, wheel # 3 right. [/url] 1 Quote Link to comment
datsunfreak Posted February 21, 2014 Report Share Posted February 21, 2014 Those are gorgeous! :thumbup: 1 Quote Link to comment
KiloTango1200 Posted February 21, 2014 Author Report Share Posted February 21, 2014 Something else to add to the pile of parts. GX double valve spring seats and retainers for the Sedan's A-14. From Japan 1 Quote Link to comment
datsunfreak Posted February 21, 2014 Report Share Posted February 21, 2014 Excellent. B) Quote Link to comment
KiloTango1200 Posted February 23, 2014 Author Report Share Posted February 23, 2014 New valve stem seals for the Coupe's A-14. Nickle and dime stuff, but you still need it when you take the package of goodies to the machine shop. Quote Link to comment
KiloTango1200 Posted February 26, 2014 Author Report Share Posted February 26, 2014 I visited the Coupe to get the ashtray for Datsunfreak. I took the grille out of the passenger's seat to give it a little TLC. Quote Link to comment
ggzilla Posted February 26, 2014 Report Share Posted February 26, 2014 Try the Tokyo look: cut out the center and fit black mesh 2 Quote Link to comment
KiloTango1200 Posted February 26, 2014 Author Report Share Posted February 26, 2014 Try the Tokyo look: cut out the center and fit black mesh The grille looks good but the fender mirrors look awesome.Gotta get me some. Quote Link to comment
KiloTango1200 Posted February 26, 2014 Author Report Share Posted February 26, 2014 The Coupe's grille was in the front passenger's seat and needed some TLC. It is kinda beat up. I will do some work to see what looks best. [/url] Quote Link to comment
KiloTango1200 Posted February 27, 2014 Author Report Share Posted February 27, 2014 I moved the Coupe's grille home to work over. I had no attachments holding the grille to the car. When I made the Childress trip, I checked out the attachments on the Sedan's grille. Long self tapping metal screws hold the grille on. I removed the Sedan's grille to restore it too. Dad installed the GTI badge on the Sedan's grille when I took it off my VW Golf GTI. He was looking for a GX badge in the 80's but couldn't find one. Quote Link to comment
datsunfreak Posted February 27, 2014 Report Share Posted February 27, 2014 I ain't your mom, but I'd put the old grill from your sedan on the coupe, and then get a proper sedan grill for your dad's car. :thumbup: Sedan needs a sedan grill. B) 1 Quote Link to comment
ggzilla Posted February 27, 2014 Report Share Posted February 27, 2014 Plastic is better than stainless, or is it? Quote Link to comment
datsunfreak Posted February 27, 2014 Report Share Posted February 27, 2014 Plastic is better than stainless, or is it? Not when it gets hot. Or gets bumped. Or basically any endurance scenario. :rofl: 1 Quote Link to comment
Z chopper Posted February 28, 2014 Report Share Posted February 28, 2014 The grille looks good but the fender mirrors look awesome.Gotta get me some. ya those fender mirrors run around $300 Quote Link to comment
ggzilla Posted February 28, 2014 Report Share Posted February 28, 2014 Those are 510 SSS mirrors. Yes genuine Nissan are about $300 but knockoffs are half the price but still look shiny for 2-3 years The 1200 GX mirrors look better IMO. 2 Quote Link to comment
KiloTango1200 Posted February 28, 2014 Author Report Share Posted February 28, 2014 I ain't your mom, but I'd put the old grill from your sedan on the coupe, and then get a proper sedan grill for your dad's car. :thumbup: Sedan needs a sedan grill. B) I agree that the Sedan will ultimately need a Sedan grille. Just need to modify the Coupe radiator support to accept a Sedan grille. At least I still have the original Sedan grille emblem that is in very good shape. Right now I just need to get the Sedan back on the road. Quote Link to comment
KiloTango1200 Posted February 28, 2014 Author Report Share Posted February 28, 2014 Redneck traction device to help broken plastic heal. The break was so warped that I couldn't physically hold it in place with my hands long enough for it to set up. Even with 5 minute epoxy. I have built many radio controlled aircraft and sometimes you have to use unconventional methods to make things work. 4 Quote Link to comment
