1200 autocross project Texas
  • Replies 969
More detail shots
Surface rust on lower drivers windshield molding.
Passengers sun visor
Loose wire in trunk. Looks like a ground wire maybe. anybody have an idea where this goes?
The spare tire cover is warped. At least I have an intact pattern for a new one.
DSCN1462_zps5c6f2935.jpgN
Next Service Due.....12 YEARS AGO! Also minimal surface rust on drivers A post.
Drivers door panel got all the use. much worse shape than the passengers panel.
Oh, and sorry for my tardiness to the thread. I tend to stick to the 1200 and 610 forums...    :thumbup:
Not sure, It runs into the wiring harness in the upper left side of the trunk.
The car is still in storage in Childress TX. I have only had time to push the car out, take pictures and do some minor stuff since I decided to go ahead with this. I go there visit my elderly Mother, do some shopping for her and refill her prescription dispenser every other Friday. Then I rush back to Denton to take care of everything else. Hopefully next week I will replace the hydraulics on the clutch so I can drive it on the trailer and bring it back to the shop a couple of weeks later. Hope your new shop is going well.
Doesn't look factory to me, that's why I asked.
Dad liked to tinker with the car. I helped him a lot when I was young but I don't remember that. He installed an electric trunk release in '74. Might be connected to that. Got a new battery and am going to do an electrical systems check next week. I am taking a spare 20 lb fire extinguisher from the airport to do this. Just in case.
This one is going to be restored as original as possible since it is in unmodified, unrestored condition and has been in the family since new. I'll find something else to do the wild stuff to.
If you want to have the proper original grill for it, let me know. I have a spare.  :thumbup:
You the pilot or you refueling her.
With planes like this, the ground crew does the fueling and I can walk around and take pictures. This is also the reason I will be able to run 14:1 compression ratio. An unlimited supply of 100 octane AvGas!
Here are the original documents I found.
Owner's Manual
Original Window Sticker. Brand new car for $2172.13
Clean Air System Maintenance Manual
Emissions Maint. Manual Cont.
More Emissions Manual
Emissions Warranty Notice
Warranty and Service Booklet
Warranty and Service Booklet documentation.
Warranty Card
