Stoffregen Motorsports Posted April 1, 2023 Report Share Posted April 1, 2023 3 hours ago, Duncan said: Funny, I did a Google search and couldn't turn anything up yesterday. Today, it's all over the place including ebay... Because they're spying on you. It's not paranoia if they really are after you. Quote Link to comment
datzenmike Posted April 1, 2023 Report Share Posted April 1, 2023 Yeah, sometimes a cigar is a cigar. 1 Quote Link to comment
datsunfreak Posted April 4, 2023 Report Share Posted April 4, 2023 On 3/31/2023 at 10:22 PM, KELMO said: Not gonna lie, I did touch myself a lil bit. I laughed a little too hard at you saying this, then the car winking at me... 2 Quote Link to comment
KELMO Posted April 6, 2023 Author Report Share Posted April 6, 2023 A lot of tedious cleaning and a boatload of tape. Not perfect but better than what I started with. Now I have to start on the other side. 3 Quote Link to comment
Stoffregen Motorsports Posted April 6, 2023 Report Share Posted April 6, 2023 I did the same to my Cherokee grille using a paint pen. Worked pretty good, but who knows how long the paint will last. Quote Link to comment
datsunfreak Posted April 6, 2023 Report Share Posted April 6, 2023 (edited) 4 hours ago, KELMO said: A lot of tedious cleaning and a boatload of tape. Not perfect but better than what I started with. I did that on my first 510, then swore to never do it again. 😋 Now I just mask off the rings and paint everything else black... Edited April 6, 2023 by datsunfreak 1 Quote Link to comment
iceman510 Posted April 6, 2023 Report Share Posted April 6, 2023 I had a few sets of these rechromed last fall ($$$$ too much), so now I have to paint a couple of them to match the grille pattern for my 73. Thanks for the ideas. Quote Link to comment
KELMO Posted April 7, 2023 Author Report Share Posted April 7, 2023 7 hours ago, datsunfreak said: Now I just mask off the rings and paint everything else black... Well, in for a penny in for a pound at this point. 4 hours ago, iceman510 said: I had a few sets of these rechromed last fall ($$$$ too much), so now I have to paint a couple of them to match the grille pattern for my 73. Thanks for the ideas. I did this with spray paint (rattle can), next time real little paint brush. Quote Link to comment
KELMO Posted April 7, 2023 Author Report Share Posted April 7, 2023 This took all day. If not for my cousin, it would have taken a week. It is hard to tell but we used the original filler tube for the bend part. I was always curious how this would come together. Different angle before we added hose and what not. 4 Quote Link to comment
KELMO Posted April 16, 2023 Author Report Share Posted April 16, 2023 Just to see what the H/L assy would look like put together. Also the OEM hardware holding the trim to the bucket. Screw: 08630-41620 Spring nut: 01241-01021 The spring nut can be used for the marker lights as well (and probably other places that I have not found yet). Almost positive those come in a QTY of 10. 4 Quote Link to comment
Stoffregen Motorsports Posted April 16, 2023 Report Share Posted April 16, 2023 Looks great. No need to buy that stuff OEM. McMaster Carr sells most of what you would ever need. Quote Link to comment
KELMO Posted April 17, 2023 Author Report Share Posted April 17, 2023 20 hours ago, Stoffregen Motorsports said: No need to buy that stuff OEM Well, I had it on hand so there is that. Also, it's funny things you can write off as "obsolete" when you run a Nissan parts department...or used to anyway. FWIW the spring nuts did not work on the side marker light as I had expected. 1 Quote Link to comment
datsunfreak Posted April 17, 2023 Report Share Posted April 17, 2023 4 hours ago, KELMO said: spring nuts did not work on the side marker light as I had expected. How come? Quote Link to comment
KELMO Posted April 17, 2023 Author Report Share Posted April 17, 2023 Not enough spring in the nut/ metal on the fender is too thin. I mean, they work but they don't slide over the hole and stay there. I just had to line everything up and screw it all together. Not enough spring in the nut...geeze louise I can't believe I typed that. 1 Quote Link to comment
datsunfreak Posted April 17, 2023 Report Share Posted April 17, 2023 1 hour ago, KELMO said: Not enough spring in the nut/ metal on the fender is too thin. I mean, they work but they don't slide over the hole and stay there. I just had to line everything up and screw it all together. FWIW, you can also just put them completely behind the fender. I do, saves scratching the paint. 😉 Quote Link to comment
KELMO Posted April 21, 2023 Author Report Share Posted April 21, 2023 (edited) Part 2 of the filler neck. This is just mocked up as well as the top side. I'm going to let it set a bit and see if the rubber hose forms in a bit. We used the original filler tube to get the proper bend and ended up cutting quite a bit off of it. Then used some reducers and some straight filler hose. Again, if not for my cousin, this would have taken me a week. Random lower moulding pic while I'm at it. Edited April 21, 2023 by KELMO 2 Quote Link to comment
KELMO Posted May 21, 2023 Author Report Share Posted May 21, 2023 More grille stuff. Not a whole lot getting done lately. Tripped and fell while on vacation and cracked a couple ribs so a bit limited on physical stuff. At least I didn't break a hip. 2 1 Quote Link to comment
KELMO Posted May 28, 2023 Author Report Share Posted May 28, 2023 Just because I wanted to see what it looked like. The badge will need some cleaning and paint. 4 Quote Link to comment
KELMO Posted June 1, 2023 Author Report Share Posted June 1, 2023 This may be a dumb question but... 5 SPD trans out of a 280ZX, the hole where the cover plate and the shaft for the T/O bearing collar..is that supposed to be there? Quote Link to comment
datzenmike Posted June 1, 2023 Report Share Posted June 1, 2023 Never noticed it before but I bet it's a drain for the front seal if it fails. Oil drips out there rather than running forward out that hollow shaft and dripping on the clutch disc. The oil will find it's way to the bottom front of bell housing and drip out another hole there for that purpose. I have a zx transmission (no surprise there) and it has the small hole though all 71B 4 and 5 speeds should have this. 1 1 Quote Link to comment
KELMO Posted June 12, 2023 Author Report Share Posted June 12, 2023 Still nothing major happening. Waiting on a clutch kit to arrive. Cleaning the intermediate plate up a little in the meantime. 1 Quote Link to comment
DARIN 510 Posted June 13, 2023 Report Share Posted June 13, 2023 On 4/6/2023 at 5:47 PM, KELMO said: This took all day. If not for my cousin, it would have taken a week. It is hard to tell but we used the original filler tube for the bend part. I was always curious how this would come together. Different angle before we added hose and what not. What’s it look like with the door closed ? And what did you use ? Quote Link to comment
KELMO Posted June 14, 2023 Author Report Share Posted June 14, 2023 We used the original filler neck that attached to the 1/4 panel, a metal reducer to straight rubber line, what was left of the filler tube in order to get the proper bend, more straight rubber line, and another reducer at the tank. I have yet to make this a permanent installation so I can take pics of the individual parts. I will have to take a pic of the fuel door closed. 1 Quote Link to comment
datsunfreak Posted June 14, 2023 Report Share Posted June 14, 2023 3 hours ago, KELMO said: We used the original filler neck that attached to the 1/4 panel, If that is the fill neck that came with the car, it's not techinically "original". Pretty sure I had it set up with the neck from the donor Subaru. 👍 Quote Link to comment
KELMO Posted June 15, 2023 Author Report Share Posted June 15, 2023 There was a flange on the tube that matched the hole in the wheel well as well as a metal mounting plate, so I assumed it to be original. Still need to snap that pic of the fuel door. Quote Link to comment
