Pic's of your Z
LAYEDOUTB2K
They're all spot welded.
If you have to find someone .. it'll cost moolah as you well know.
Find a big tree and borrow a chain come-a-long = rest is self explanatory :lol:
straighten it out as much as possible.
Drillout spot-welds or cut core-support
line up and tack-weld in ... check ... and final weld !
Even replace with tubing in main areas would be fine.
waaaalaaaa :D
If it's just your core support ... you shouldn't have to much trouble
just putting in time is all ;)
  • Replies 2k
If I had a welder and knew how to weld I'd be on it but that's not the case, the thing with these core supports there super thin. I've already tried the tree thing and this is a far as it would go even heated the core support. I'm sure it would be a one day job measure cut and weld.
That doesnt look too bad. The tree method prob wont pull it anymore because of where your pulling from. It looks like the rad side of the support is pretty close but the front is still crumpled up. You could use a slide hammer for that and JB up the holes.
Like DTP said its all time. It's def salvageable.
Its just a matter of time till I can get it fixed I got the parts car so thats it's all the matter when I talk to people I know that do good body work just need the money for it.
It's hasn't hurt the handling the only thing I wish I could put was the front bumper I know there this old technique using some type of tool that you put to spread the metal straight. It's just bent so to put the bumper it won't line up to bolt it up.
Hey These are few pics of my Z and wheels until i got the right wheels Ronal's
Ruff racing
18x8 225/40/18
18x9.5 285/30/18
Bsa
18x8
18x10
masitaly
18x9.5 all round
Works
15x8 195/55/15
15x10.5 225/50/15
Ronal racing with flares
15x11 225/50/15
15x13 265/50/15
Thanks bubbi just try to figure out my flares but the Ronals stay's on
There's another thread on here about one using VW Bug fenders for flares. Looks pretty good too. You may want to check it out and see if that may be an option. The Ronals are sick bro....
Bubbi,
The stands of your car nice man, I was going 5 bolt but rims was 18x9.5 all round, so i taking it a bit further and send pair in to get a bigger lip put on.
So the rims would be 18x15.5 with huge 6" lip but after finding ronals i stop.
Bubbi,
Thanks and :00000 wow! Cant wait to see the outcome! Keep us posted!
What is done to it? Errrrr what needed to be finished?
Installed engine, removed damaged head, installed fresh, good head, installed fresh 5spd tranny, removed rear sway bar, installed fuel pump and new hoses, installed S.U.s, rewired ignition system, rewired lighting, etc, etc,
