What I'm working with!
uberkevin
  • Replies 3.2k
Small problem.
720 short 5 speed. Picked it up from wayno. We put a 620 L front case on the front of it. I'm trying to put the ring you see in the photo back around the bearing. After putting the Z case back on As you can see there isn't anything groove so that the ring sits in..
The case is bolted on.
Fixed.
I needed to take the case off and put it back on as I hold the input shaft from going down..
It wouldn't just pull up like I thought it should but now that it's on right it moves up and down a little. Like it should right. Haha
Janksun just came thru for some s13 engine brackets, and made me realize the s13 and s14 engine brackets differ, i hav. Been using s14 ka engine mount/bracket on the driver side for ka swap, i always thought they were the same, i was wrong...heres the brackets next to each other
The one i sent in the prior page was s13 from konigs engine, and all look different than the truck ka mount aswell
  • Like 4
