What I'm working with!
uberkevin
General Engine Specs(1990)
Displacement 146 cu. in. (2.4L, 2389cc)
Bore 89mm
Stroke 96mm
Compression Ratio:
-Axxess, Stanza & Pickup 8.6:1
-240sx 9.0:1(that's not right...)
Fuel system - Port Fuel Injection
HP@RPM:
-134@5200(pickup)
-140@5600(240sx)
Torque@RPM:
-154@3600(pickup)
-152@4400(240sx)
Crankshaft, main and connecting rod bearings specs(millimeters)
Crankshaft:
-End play - .05-.18
-Runout - .10
Main Bearings:
-Journal Diameter(Axxess,Stanza,240sx):
--Grade 0 - 59.967-59.975
--Grade 1 - 59.959-59.967
--Grade 2 - 59.951-59.959
-(Pickup)
--Grade 0 - 63.645-63.652
--Grade 1 - 63.652-63.663
--Grade 2 - 63.663-63.672
-Journal Out-of-Round and Taper .010mm
-Oil Clearance .020-.047
Connecting Rod Bearings
--Grade 0 - 49.968-49.974
--Grade 1 - 49.962-49.968
--Grade 2 - 49.956-49.962
-(Pickup) - 59.951-59.975
-Journal Out-of-Round and Taper .005
-Oil Clearance .010-.035
Connecting Rod Specifications(mm)
Bore Diameter
-Pin Bore:
--Axxess,Stanza,240sx 21.000-21.012
--Pickup 20.948-20.978
-Crankpin Bore:53.000-53.013
Center-to-Center Length 164.950-165.050
Maximum Bend .150
Maximum Twist .30
Side Play .20-.40
Pistons, Pins and Rings Specifications(mm)
Pistons
-clearance .020-.040
-diameter
--Grade 1 88.970-88.980
--Grade 2 88.980-88.990
--Grade 3 88.990-89.000
Pins
-Diameter
--Axxess,Stanza,240sx 20.989-21.000
--Pickup 20.994-20.996
-Piston Fit
--Axxess,stanza,240sx (interference fit or negative clearance)0-.005
--Pickup .008-.012
-Rod Fit
--Axxess,Stanza,240sx .005-.017
--Pickup (interference fit or negative clearance).015-.033
Rings
-No. 1
--End gap .280-.430
--Side Clearance .040-.080
-No. 2
--End gap
---Axxess,Stanza,240sx
----Marked "R" or "T" .
Cylinder Block Specifications(mm)
Cylinder Bore
-Standard Diameter
--Grade 1 - 89.000-89.010
--Grade 2 - 89.010-89.020
--Grade 3 - 89.020-89.030
-Maximum Taper .010
-Maximum Out-of-Round .015
Minimum Deck height 246.95-247.05
Maximum Deck Warpage .10
(max. resurfacing limit of cylinder block and cylinder head combined is .20mm)
Cylinder Head Specifications(mm)
Cylinder Head Height 98.80-99.00
Maximum Warpage .10
Valve Seats
-Intake Valve
--Seat Angle 45*
--Seat Width 1.6-1.7
--Seat Bore Diameter 36.00-36.016
-Exhaust Valve
--Seat Angle 45*
Valve Guides
-Intake Valve
--Valve guide cylinder head bore I.D. 10.975-10.996
--Oversize guide hole diameter 11.175-11.196
--Valve guide I.D. 7.000-7.018
--Valve guide installed height 14.9-15.1
--Valve stem-to-guide oil clearance .020-.053
-Exhaust Valve
--Valve guide cylinder head bore I.D. 11.975-11.996
--Oversize guide hole diameter 12.175-12.196
--Valve guide I.D. 8.000-8.018
--Valve Stem-to-guide oil clearance .040-.070
Camshaft Specifications(mm)
Bore Diameter 33.000-33.025
End play .07-.15
Journal Diameter 32.935-32.9555
Journal Runout .02
Lobe Height 44.839-45.029
Lobe Lift 10.4
Oil Clearance .045-.090
TORQUE SPECS(FT.LBS.):
alternator bracket bolt 12-15
alternator pivot bolt 33-44
camshaft sprocket bolt 87-116
connecting rod nut
step 1 10-12
step 2 28-33
crankshaft pulley 105-112
cylinder block drain plug 25-33
cylinder head bolt
step 1 22
step 2 58
step 3 loosen all bolts
step 4 22
step 5 54-61
egr tube nut 29-36
exhaust manifold bolt/nut 12-15
flexplate mount bolt (A/T) 69-76
flywheel mount bolt (M/T) 105-112
intake manifold bolt/nut 12-15
intake plenum bolt/nut 12-15
main bearing cap bolt 34-38
oil drain plug 22-29
oil strainer bolt 12-15
rocker arm shaft bolt 27-30
starter motor bolt 22-30
transmission-to-cylinder block bolt 30
oil filter adapter-to-block bolt 12-15
water pump bolt 12-15
INCH LBS.
cam chain guide bolt 108-126
cam chain tensioner bolt 61-70
cylinder head-to-front cover bolt 35-86
front cover bolt 61-70
oil pan bolt 61-70
oil pump bolt 96-132
rear oil seal retainer bolt 61-70
rocker arm cover bolt 61-86
water pump pulley nut 51-86
  • Replies 3.2k
Well I'm building both. truck,240sx
I was just curious if the girdle for the car would fit the truck bblock.
Haven't looked into it yet he'd to go to work..
Gotta get the truck block honed and clened, it was a beat ass motor. Crank is good. Pistons not so much.
It won't fit with the pan.
From what I have read, one of the pans will not fit the other block.
But the other pan will fit the other block.
Since you have both, you can compare.
It would be a great bit of info to add to the differences thread.
