demo243 Posted September 2, 2017 Author Report Share Posted September 2, 2017 In the process of tearing the wiring apart I decided it would be easier to upgrade to Speedhut Gauges and build my own dash then try to adapt all the 510 gauges. So I ordered a set of Speed huts and began work on a custom dash Speed huts are in Untitled by Devon Mitchell, on Flickr Started with cardboard templates Untitled by Devon Mitchell, on Flickr Then transferred it to metal. Ordered some metal from onlinemetals.com got some thin alum sheet metal. Untitled by Devon Mitchell, on Flickr Used the corner of a 2x4 and some clamps on the work bench to make the bends Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Then used the appropriate hole saws to cut holes in the dash Untitled by Devon Mitchell, on Flickr Got some universal 12v cig lighter and usb adapters, and painted it matte black Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr 6 Quote Link to comment
demo243 Posted September 3, 2017 Author Report Share Posted September 3, 2017 While all that was going on I had Ray at Garage Autohero fab up a custom rear sump pan and pick up for me. Really great work, the end result was pretty awesome--- big thanks to Trophy again for letting me borrow his block so Ray had something to fab it up on since I was down here in CA and Ray is up in WA... its a bit expensive to ship a block up.... Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr 2 Quote Link to comment
demo243 Posted September 3, 2017 Author Report Share Posted September 3, 2017 Then I began work on building the motor- Parts back from the machine shop... both heads were really bad... rolled the dice on a Rock auto head... its working now... but not without its trouble.... Untitled by Devon Mitchell, on Flickr Custom trigger wheel instal for the EDIS/MegaJolt Install Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Rock Auto Head Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Core Plugs installed and block painted Untitled by Devon Mitchell, on Flickr Fresh bearings Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Wiseco Pistons and Eagle Rods Untitled by Devon Mitchell, on Flickr Working on rings and bottom end install Untitled by Devon Mitchell, on Flickr Coming together Untitled by Devon Mitchell, on Flickr Timing done Untitled by Devon Mitchell, on Flickr Buttoned up Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Home work bench aluminum stock custom fab hahahah --- block offs and trigger wheel sensor mount Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Ready to drop in Untitled by Devon Mitchell, on Flickr 2 Quote Link to comment
demo243 Posted September 3, 2017 Author Report Share Posted September 3, 2017 Dropping it in did not come easy.... some issues I was expecting... but not as many as I encountered... Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr The biggest issues were with the motor mounts and trans bracket.... currently running the T3 trans bracket and McKinney motor mounts... not really happy with either.... Ray fabbed the pan up with a stock 510 xmember and stock 510 soft mounts... but when I went to mount it up something was different with the xmember.... so it didnt fit right. I ended up using the McKinney mounts to get the extra height to clear the pan from the xmember and the steering linkage.... not stoked... but they will work... Was having a hell of a time getting 510 soft mounts to work Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Also I felt the engine was really far forward... so with the help of Rag10 I got some custom hard mounts fabbed to set the motor back further into the bay Will need to get some shots of these... cant find em on my phone/flickr 1 Quote Link to comment
edekalil Posted September 3, 2017 Report Share Posted September 3, 2017 Then I began work on building the motor- Parts back from the machine shop... both heads were really bad... rolled the dice on a Rock auto head... its working now... but not without its trouble.... Untitled by Devon Mitchell, on Flickr Custom trigger wheel instal for the EDIS/MegaJolt Install Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Rock Auto Head Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Core Plugs installed and block painted Untitled by Devon Mitchell, on Flickr Fresh bearings Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Wiseco Pistons and Eagle Rods Untitled by Devon Mitchell, on Flickr Working on rings and bottom end install Untitled by Devon Mitchell, on Flickr Coming together Untitled by Devon Mitchell, on Flickr Timing done Untitled by Devon Mitchell, on Flickr Buttoned up Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Home work bench aluminum stock custom fab hahahah --- block offs and trigger wheel sensor mount Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Ready to drop in Untitled by Devon Mitchell, on Flickr That is sweet I want one for my car. 1 Quote Link to comment
demo243 Posted September 5, 2017 Author Report Share Posted September 5, 2017 Couple of other issues... The OBX 4-2-1 header wasnt even close to fitting... even with a big F'n hammer.... Ordered up a Megan 4-1 shorty and it fits great. If you are handy with a welder you could clock the flange on the lower pipe a few degrees and it would fit fine too... for me a temporary solution of a 2" exahust extension flange allowed me to clock the lower portion as needed... the rest of the exhaust is pretty hacked together but it works... definitely needs a visit to a good exhaust shop. Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Another issue I encountered was the trans bushing/isolator. Most said the 240/260/280 worked fine.. but with the T3 crossmember it sat realllly low.... ended up picking up this energy suspension one, Ill have to dig up the part number. fixes it well enough... although I did need to open up the trans mount holes to allow it to slot forward and backwards... Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Long story short... not impressed with the Mckinny Mounts or the T3 trans xmember... Still amazed someone hasnt "dialed" in this swap and offered mounts... but I guess there are alot of different routes people go. Once the engine and trans were in I had to sort out the drive shaft. --- the shaft that came with my car had seen better days, and rather then shorten it again and rebuild it, I called the guys up at the driveshaftshop.com and had them custom make a 3" aluminum driveshaft. Untitled by Devon Mitchell, on Flickr Fit in perfectly - great guys over there Radiator also needed to be taken care of. Really didnt like the CX racing one and had heard of people using the AFCO 80104N but without many photos... liked the dim's and price an pulled the trigger Untitled by Devon Mitchell, on Flickr This shows a comparisson to the Koyo 510 rad -- AFCO on left and Koyo on right Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Found some generic floor isolators on Grainger for the lower mounts and bent up some aluminum stock for the upper mounts Untitled by Devon Mitchell, on Flickr Then went to oreilly and politely asked the guys to let me browse their rad hose selection to see if I could find some that fit --- Part numbers still on hoses- they were cut down FYI so the ones off the shelf are longer with an extra bend or two Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Due to the rad inlet and outlet being bigger then the KA inlet and outlet I did need to use some hose shims that were aquired off of summit racing You will notice in this shot I had to go to an inline thermostat in the upper hose... more on that latter IMG_2198 by Devon Mitchell, on Flickr 2 Quote Link to comment
demo243 Posted September 5, 2017 Author Report Share Posted September 5, 2017 side note--- back to electrical... Oddessy PC680 using T3 bracket mounted to a piece of alum stock behind the passenger seat Untitled by Devon Mitchell, on Flickr Hard to see in this photo... but ran power to a 200amp circuit breaker mounted under the pass seat then goes to the started an a 175amp mega fuse in the engine bay Untitled by Devon Mitchell, on Flickr 1 Quote Link to comment
demo243 Posted September 5, 2017 Author Report Share Posted September 5, 2017 At this point we were good to fire. Cranked for oil pressure... nothing... pulled the filter back filled the pump from the filter adapter and pre filled the filter. Cranked again... OIL PRESSURE! Now we are good to fire... Go to start... no spark... first though was the edis coil and the plug wires thinking they werent contacting each other... swaped to a different coil... still no spark... a little more digging to relize that when the ignition was on the megajolt unit had power, but when I turned the igntion to start the megajolt unit would lose power --- hence no spark since I am running a hard limiter on the megajolt board, power to the coil is provided from megajolt. A few calls with Rag10 and we had that rewired and sorted out to provide constant power when cranking. Next issue... wont fire... keeps trying and backfire out of the carbs but wont run.... seems like timing is off... hand crank to TDC and check all the markings and the trigger wheel and sensor... everything is lined up perfect.... Did some reading on the Autosport forums (megajolt forum) and someone mentioned they crossed the coil wires and had to swap the plug wires.. Swap the plug wires... FIRES FIRST TRY! Untitled by Devon Mitchell, on Flickr Plugged in a straight 15 degree map and damn it is dead on with the timing light... 15 degrees does not budge. Shut it down to drive it the next day. 1 Quote Link to comment
demo243 Posted September 5, 2017 Author Report Share Posted September 5, 2017 Get home the next afternoon - fire it and let it idle (while varying the throttle and rpms) to warm it up and do a quick initail tune on the mikunis. Thanks to DUKE the mikunis are pretty close to dialed right off the bat Let it warm up and all seems fine. Take it for a quick spin around the block- 1/2 mile maybe? --- All is good around the first turn, second turn, third turn, and fourth. Go to pull in my drive way and get stuck 3 wheeled because of the angle, back up and glance down at the temp gauge and it had pegged... shit.... shut it down open the hood and can see the coolant pissing out of the back of the head.... well shit Let it cool and go out 2 hours later since I need to fire it again to get it in the garage... fire it , back it up so I can swing out to get into the drive, wait for traffic, get a break and pull in. Get out of the car to see a massive line of oil.... Do my best to mop up the oil and prep for the worst. Untitled by Devon Mitchell, on Flickr Untitled by Devon Mitchell, on Flickr Next night I go out to figure out where the oil came from.... Cant find anything... Finally pull the oil filter... the gasket gave on the filter Untitled by Devon Mitchell, on Flickr No more nissan filters for me... the gasket is super flimsy on these and I am surprised this doesnt happen more often.\ I have since swapped to Bosche filters as they have a nice big thick rubber gasket. Next step was to pull the head as I though the headgasket had popped. --- side note here, it did over heat, but I dont think it actually got that hot since the heat tabs on the head desinged to melt in an overheating situation to allow the machine shop to void the warranty did not melt Pulled the head, checked for flatness... thankfully still flat new head gasket installed, all torqued back up... go to fire... Still leaking..... now I am able to see that it is actually leaking out of the core plug at the back of the head.... Decide its easier to pull the whole engine instead of the head so get to work. Pulled the engine Untitled by Devon Mitchell, on Flickr Made a core plug remover with some spare alum stock and a self taping bolt Untitled by Devon Mitchell, on Flickr Pull the plug, clean the hole, replace it, and drop the engine back in Fire it up...leaking worse then before... I can now see a steady stream of coolant coming out Pull the engine, pull the plug, clean it, replace it and put it all back together --- used aircraft gasket maker both times to seal the plug... Before I even fire it, I can see it leaking.... At this point I decide its time to pull the head an take it to a machine shop, plan was to have them bore it out and put a new larger plug in. Called 3 machine shops.... none of them could do that... 4th one finally says yes they can, bring it on by. After talking with them in person they can see why the plug wouldnt hold... there were some small scuffs and a gouge but they were convinced that the plug should hold despite that... they offer to make an aluminum plug for a good chunk of change instead of boring the hole out or suggest that I just take it home use some sleeve retainer on the new plug (3rd one) and then epoxy the shit out of it..... not wanting to dump money into this rock auto head I follow their suggestion. Took it home, cleaned it really well, applied sleeve retainer to the hole and the plug, installed it, let the sleeve retainer set up, and then epoxied the plug in... long store short this plug is not coming out easily Untitled by Devon Mitchell, on Flickr Put it all back together Untitled by Devon Mitchell, on Flickr Let the epoxy cure Fire it! No LeakS!!!!!! Its is now running and driving. 2 Quote Link to comment
demo243 Posted September 5, 2017 Author Report Share Posted September 5, 2017 Also to be noted.... I could not get the stock KA thermostat to work. Very inconsistent temperature readings.... with a 160 thermostat in the stock location on the lower hose, I quickly saw 180+ at the sensor in the intake manifold ( coolant outlet for the engine) without the thermostat opening.... This is what I believe to be the issue of the over heating, plug popping, oil puking issue. Even when I was able to get the thermostat to open, it would quickly close and then not reopen... tried two different thermosats with the same issue At that point i went to an inline thermostat in the upper hose and have had zero issues since. Quote Link to comment
demo243 Posted September 5, 2017 Author Report Share Posted September 5, 2017 As it sits right now... We unfortunately are on hold again... Life is taking me and the 510 back east again - Boston here we come! So there will be some more updates, but mostly likely mostly reposting preferred old photos... There are a few issues that still need to be dealt with. --- Something is draining the battery... as its not holding a charge The TPS sensor will calibrate fine, but once the engine is started, it doest read.... Exhaust desperately needs to be done Will need new tires soon--- these are getting worn and two of them sat in oil for a bit as well needs some sort of trans tunnel repair or cover to seal that back up Going to need to do some serious 3m adhesive tape/foam to deal with rattles... installed the T3 rear firewall and deck lid... but with the poly engine mounts and trans mounts the car vibrates... Something might not be right with the trans... cant tell if its just the hacked exhuast rubbing the trans crossmember bolts or if its the trans itself... but its loud in 4th and 3rd especially on decel. It also unfortunately seems I failed at RTV and the oil pan seal is leaking a bit too.... Lots of work to still be done.... Ill do my best to keep it all updated. 1 Quote Link to comment
datsunfreak Posted September 9, 2017 Report Share Posted September 9, 2017 So what happened to the intake you decided not to use? B) Quote Link to comment
demo243 Posted September 9, 2017 Author Report Share Posted September 9, 2017 So what happened to the intake you decided not to use? B) Hanging on to it for now.... Quote Link to comment
datsunfreak Posted September 10, 2017 Report Share Posted September 10, 2017 Hanging on to it for now.... Crud. ^_^ Quote Link to comment
mattyhacks71 Posted September 13, 2017 Report Share Posted September 13, 2017 That is sweet I want one for my car. Is it really necessary to quote an entire post like that just to give a compliment? 1 Quote Link to comment
Draker Posted September 14, 2017 Report Share Posted September 14, 2017 I usually edit out pics and vids when I quote. Quote Link to comment
datsunfreak Posted September 17, 2017 Report Share Posted September 17, 2017 Is it really necessary to quote an entire post like that just to give a compliment? For some of us, it certainly seems to be... :rofl: Quote Link to comment
Lozer Posted September 21, 2017 Report Share Posted September 21, 2017 FYI on the odd thermostat problems you were having. The hose behind the thermostat goes up to the intake and the heated water is pushed to the back of the thermostat causing it to open. I, like you, did a clean up of the hoses and found this out the hard way. 1 Quote Link to comment
demo243 Posted January 18, 2018 Author Report Share Posted January 18, 2018 Not much too update... Car made it back east! Was a bit nerve racking... Unfortunately I couldn't use the same trucking company I did to ship it out west since my wife's company was paying for it (yea full relo package... I am working in the wrong industry... but at least I married someone who is!) so they farmed it out... talking to the company the promised it would only go on one truck... well sure enough I guy shows up with a small 3-4 car trailer and obviously that wasnt going across the country... short for time I had to just load it and deal with it. Then it got loaded on a bigger truck to make the full trip. I was a bit nervous due to it not holding a battery charge and needing a jump and also that it needs to crank a bit after sitting since the oil pressure switch doesnt let fuel flow till there is oil pressure. Made it fine.. with only one decent dent in the lower portion of the megan header... I figured this will get replaced when I get the exhaust done... so no big deal. Getting picked up - Untitled by Devon Mitchell, on Flickr Dropped off- Untitled by Devon Mitchell, on Flickr For some reason they never want to drive it off... so both times I have driven it off Untitled by Devon Mitchell, on Flickr Back east - Untitled by Devon Mitchell, on Flickr unfortunately for now the car is stashed in CT in my mom's garage, and will be for the next 16+ months... Ill still be down to drive it and work on it, and hopefully get it back out autocrossing in Bridgeport Ct this summer. The hard part is all my tools are up in Boston. The biggest issue now is getting it compliant with MA laws... I though Cali was bad... MA is worse... MUCH WORSE.... To reg it in Cali all I had to do was drive it to the DMV and get it VIN verified... the guy even commented on how good the engine looked and how much work I must have put into it... and it passed fine Massachusetts is a different story... being a '71 there is no emissions... but it does have to pass a saftey inspection every year and MA just added cameras to all their inspections bays so nothing can pass through.... Also side note---- All photos between page 2 and 25? have been removed... I did this before I realized there was a hack for the photobucket issue... either way I cant support a company the tries to screw over so many people... so I deleted all my photos off of photobucket and deleted my account. I have uploaded a bunch of them to Flickr and will move forward with them depending on how motivated I get I may try and reinstate some of the photos ... or just redo a few of my first posts with a overall ... will see... Quote Link to comment
demo243 Posted January 18, 2018 Author Report Share Posted January 18, 2018 Current to do list-- -Figure out battery draw/drain issue -Figure out throttle positions sensor issue and upload proper tuning Map -Exhaust work - header back (was hoping to get my spare rear crossmember exhaust opened and adjustable... but I dont think thats gonna happen... Ill just go full 2.5" or full 3" and have then do a smaller pipe through the x-member and replace it down the road) -Get a trans tunnel cover fabbed and welded -Fill or plug the random holes in the floor and firewall -Figure out whats needed to pass MA saftey inspection -New tires- these Falkens are getting old and beat... time for something new and sticky Eventually- -Redo motor mounts -Better trans mount -Adjustable LCAs, TC rods, ties rods --- possibly T3 GTX2s -Redo steering - all bushings etc --- possibly rebuilt box -Race seats --- Corbeau likely -New wheels --- 13x7 race wheels --- possibly 15x7ish Rota Grids for daily use -Rear Coilovers ... Im sure there is more Also getting the itch to get a 2nd 510... should have done this while I was in Cali... but year couldnt afford it. This is probably 2 years out pending on buying a house (2+ car garage required) Quote Link to comment
heywier427 Posted January 18, 2018 Report Share Posted January 18, 2018 Welcome back! Tits cold out here!!! Youll probably driving right by me everytime you come from mass, if you want to borrow any tools! Im at the bottom of I91, and right by harbor freight too! 2 Quote Link to comment
Crashtd420 Posted January 18, 2018 Report Share Posted January 18, 2018 Demo243.... where abouts are you in mass... ? I am north of Worcester in leominster... Quote Link to comment
demo243 Posted January 18, 2018 Author Report Share Posted January 18, 2018 Demo243.... where abouts are you in mass... ? I am north of Worcester in leominster... Everett just outside of Boston - Was just out your way- there is a 4 door shell for sale... but its pretty stripped and beat up. Went to check it out. Considered grabbing it and parting it, keeping the x-members and rear end.. but cant justify it right now -- https://worcester.craigslist.org/pts/d/1971-datsun-nissan-510-sedan/6435080805.html Welcome back! Tits cold out here!!! Youll probably driving right by me everytime you come from mass, if you want to borrow any tools! Im at the bottom of I91, and right by harbor freight too! Yea not too far away- Fairfield. Although I typically end up running down 84 and then 8. Quote Link to comment
Crashtd420 Posted January 18, 2018 Report Share Posted January 18, 2018 That's cool.... trying to keep tabs on datsuns I know that are close by.... I would love to get an east coast datsun show going some day.... or even start a local club for Sunday morning meets... Quote Link to comment
