twistedimages Posted April 11, 2012 Report Share Posted April 11, 2012 I ran those Universal Air strut bags on my Q45 at all four corners, and the front of my Mazda MPV, and they are really a great bag if you have the space for them. Because they are self-contained, they don't put the strut cartridge seals under pressure. I left a message with Air Lift to try to get some more information on their universal Macpherson air struts- I'll add that here when I get a hold of them! Quote Link to comment
jrock4224 Posted April 11, 2012 Report Share Posted April 11, 2012 So this is why everyone says its impossible to bag a 510..... Didnt some one mention a while back just swapping to a a arm front end ...... Tristan u can't have a squirrel fart rubbing on any part of the bag other wise it's impending failure...... Brislands mmmmmm thy were awesome .... They made me wish I was Canadian Quote Link to comment
Tristin Posted April 12, 2012 Report Share Posted April 12, 2012 I agree that you would want want rubbing on the bags. My design was assuming that the base plates were larger in diameter than the bags themselves at their widest point. Quote Link to comment
Z chopper Posted April 12, 2012 Report Share Posted April 12, 2012 Brislands mmmmmm thy were awesome .... They made me wish I was Canadian it seems like Brislands is closed. I'll do some investigating and see what I can come up with since they were only like 60 - 90 minute drive south of me. Quote Link to comment
twistedimages Posted April 12, 2012 Report Share Posted April 12, 2012 NOTHING is impossible. Impractical for reasons of cost or complexity? Absolutely! And that may be the case here... Okay, here's the ultimate solution in my head, with no measurements to back the idea up at all: Add brackets to front crossmember that provide upper control arm mounts. Use 84-89 Toyota Van spindles (only application I could think of that has upper and lower arms with disc brakes and a 4x114.3 lug pattern), but reversed left to right to provide behind-axle steering. Fabricate upper control arm with beefy balljoint and a plate for the airbag to mount. Mount airbag to strut tower with a cup spacer to set overall drop. Boom- no sweat, right? ;) if anyone can think of another spindle to use I'm all ears- I thought of 60s Mustang/Falcon, but I think all of the 4 lug cars were drum, or at best solid discs. The Van has decent sized brakes that will clear a 14" wheel... 1 Quote Link to comment
twistedimages Posted April 12, 2012 Report Share Posted April 12, 2012 And yeah- the guys at Brislands were way cool, and had a really good products. I think eai or chassistech stole their cylinder design, which may have contributed to their closure... Bummer. Quote Link to comment
Z chopper Posted April 12, 2012 Report Share Posted April 12, 2012 mustang II ifs and stock rim on Mustang II is 4 lug 13" and parts are very plentiful. Quote Link to comment
greengoon Posted April 12, 2012 Report Share Posted April 12, 2012 Carlos (72dyme) has his 2 door bagged quite successfully. He has used the Universal Aero Sport bags in the front and as far as I know, its relatively simple to put on existing coil over struts by replacing the coils with the bag and making a new mounting perch. I have thought about doing it myself on my goon. I'm happy with my ride height but could use just a little more clearance sometimes. I'll be watching to see where this goes. Spudly- when are you getting shorter tires? That's the real test of height. Quote Link to comment
spudly13 Posted April 12, 2012 Author Report Share Posted April 12, 2012 Itll be a bit before i get new tires, tire size in 14 is pretty limited so ill probally end up with a 55 sidewall. it kills me to buy new tires when these are basically new! haha oh well Quote Link to comment
DISLEXICDIME Posted April 12, 2012 Report Share Posted April 12, 2012 you can get a 195 45 14 Quote Link to comment
DRIVEN Posted April 12, 2012 Report Share Posted April 12, 2012 I run 195/45-14s on my 1200. They are available but can be tough to find. Quote Link to comment
WagDatto Posted April 12, 2012 Report Share Posted April 12, 2012 Oh, Phil... You are so bag savvy. What a smart and helpful guy! Good information being tossed around the past few pages, though! This'll be good for people to be able to run back through sometime when they want a dope ass dime! 1 Quote Link to comment
spudly13 Posted April 12, 2012 Author Report Share Posted April 12, 2012 toyo or falken? both make a 195/45 Quote Link to comment
spudly13 Posted April 14, 2012 Author Report Share Posted April 14, 2012 Does anyone have 2 generic bags for a reasonable price??? the time to do a new front end has come sooner then i had hoped Edit: also need two strut tubes/spindles 2nd Edit: i have two good cylinders and two blown cylinders you could have... if you can help me out with a decent price! Quote Link to comment
jrock4224 Posted May 6, 2012 Report Share Posted May 6, 2012 Hey u still need strut parts and I assume u mean 510 not 280. I got two sets of struts fully assembled and strut and brake lemme know if it's what your looking for Quote Link to comment
spudly13 Posted May 20, 2012 Author Report Share Posted May 20, 2012 Welp after to many long weeks i finally ordered tires! should be here next week, ill be sure to post pics, should drop my car about an inch and a half and give me an inch and a half more clearence up top (3 inches difference total) Gunna have to tuck my exhaust, lose the rear sway bar, and notch my frame a bit. any who wants to buy a rear sway bar shoot me a pm Quote Link to comment
spudly13 Posted May 25, 2012 Author Report Share Posted May 25, 2012 So, ive been lazy and the car still sits on the exuast up front, and i have another inch and a half to go lower, but i need bump stop spacers because at about an inch lower the steering hits the frame. The rear aird out sits on the sway bar, so its going to have to go. Over all, smaller tires did drop my car about an inch and a half (the front will drop that distance as soon as i find motivation to do the exhaust)... but i must say im bit disapointed with how it looks, i should have done some more research or something, they just look... to small? mexi flush? however you wanna say it. But if i space em out a bit and get it to drop the rest of the way itll be worth it. Hopefully ill have my flanges tomorrow to start on my r1 intake and my header. Quote Link to comment
Tristin Posted May 25, 2012 Report Share Posted May 25, 2012 Mexi-flush (or Mexi-poke) is with the wheels/tires sticking out of the fenders... yours are pretty sunk in and not flush at all. Quote Link to comment
spudly13 Posted May 25, 2012 Author Report Share Posted May 25, 2012 Alright so mexi flush is the wrong word, but they just look small, i dont know, itll probally grow on me Fronts are 165/55 rears are 195/45 Quote Link to comment
Tristin Posted May 25, 2012 Report Share Posted May 25, 2012 I think you need more rim and dish than what you currently have... too much tire. You dont have to go to a crazy stretch or anything, but I think it would help out some. That flat face rim just doesnt do it for me. You look at a bunch of mini trucks and they look similar to yours: even though they run 20 or 22 inch rims, their wheel wells are giant (especially in the rear) so it doesnt look like its completely full. 510 wells are pretty small, so it should be easy to fill it up with rim. Quote Link to comment
spudly13 Posted May 25, 2012 Author Report Share Posted May 25, 2012 hmm, meybe 14x8 rear and 14x7 or 7.5 front, a little dish, get it a little more flush, and not use spacers....? Quote Link to comment
Tristin Posted May 25, 2012 Report Share Posted May 25, 2012 Probably would look better. I have 15x8s in the rear and I think (possibly) that I could dump the rear without any issues... I am rolled and could use a pull if I did that, but I think I can manage. Ill check clearances on my way home (Im about to leave work now) and let you know what I come up with. Quote Link to comment
Tristin Posted May 25, 2012 Report Share Posted May 25, 2012 Looks like with my 185, I would be able to dump the rear about 1/2 of what I would need to in order to get as low as you (with a fender pull). With a 175 I would say I would be about 3/4 as low as you (with the pull)... And just as low with a slotted crossmember or Byron's brackets. Quote Link to comment
