datsunfreak Posted June 27, 2015 Report Share Posted June 27, 2015 300psi to lock a drum, 5000+psi to lock a rotor. This actually sounds bad for the drum. :rofl: Owned a few 4 wheel drum cars. When it's raining, they don't work at all, until you hold down the pedal to dry them off. A freeway panic stop? Forget about it. Never had this problem with disc brake cars. Quote Link to comment
Draker Posted June 27, 2015 Report Share Posted June 27, 2015 This actually sounds bad for the drum. :rofl: Owned a few 4 wheel drum cars. When it's raining, they don't work at all, until you hold down the pedal to dry them off. A freeway panic stop? Forget about it. Never had this problem with disc brake cars. You mean.. disk brake with booster? ;) OK back to antony's interior conversion. Go! Quote Link to comment
freetheoranges Posted June 27, 2015 Report Share Posted June 27, 2015 The wood which holds your seat higher compels me to ponder if there was some sort of wood related joke especially relating to Busta Nut. Quote Link to comment
edekalil Posted June 28, 2015 Report Share Posted June 28, 2015 Wet shoes...... ....doh...... .....more shit I don't have time for..... I don't really enjoy this part......I enjoy upgrading...... I think my shoes are backwards too.......I don't think I put them together when I was putting the car together a few years ago...... .......I had some assistance....could be some of my ebrake/brake pedal issues..... I believe my 72 has the same thing going on with it. I have the parts just have to get the time to do the work. Good luck. 1 Quote Link to comment
edekalil Posted June 28, 2015 Report Share Posted June 28, 2015 The wood which holds your seat higher compels me to ponder if there was some sort of wood related joke especially relating to Busta Nut.What was that old joke in grade school? If you don't tell anyone I have a wooden d?&)"! I won't tell anyone you have splinters in your mouth. I'm sorry I shouldn't have done that. 1 Quote Link to comment
Busta Nut Posted June 28, 2015 Author Report Share Posted June 28, 2015 I believe my 72 has the same thing going on with it. I have the parts just have to get the time to do the work. Good luck. Story of my life....... Quote Link to comment
Busta Nut Posted June 30, 2015 Author Report Share Posted June 30, 2015 OK.....onward...... We're doin' it up..... 2 Quote Link to comment
Busta Nut Posted June 30, 2015 Author Report Share Posted June 30, 2015 Driver's seat is a little different...... ...has a rod that goes across.... 3 Quote Link to comment
mrbigtanker Posted June 30, 2015 Report Share Posted June 30, 2015 Yea man custom all the way. 1 Quote Link to comment
The Taterhead Posted June 30, 2015 Report Share Posted June 30, 2015 Is that one of the clips Kalani was bragging about getting cleaned up for his rocker trim :poke: 1 Quote Link to comment
r0p0doe Posted June 30, 2015 Report Share Posted June 30, 2015 Is that one of the clips Kalani was bragging about getting cleaned up for his rocker trim :poke: :rofl: 1 Quote Link to comment
jrock4224 Posted June 30, 2015 Report Share Posted June 30, 2015 Is that one of the clips Kalani was bragging about getting cleaned up for his rocker trim :poke: lol kalani strikes again ... seems like there similar 1 Quote Link to comment
Busta Nut Posted June 30, 2015 Author Report Share Posted June 30, 2015 Is that one of the clips Kalani was bragging about getting cleaned up for his rocker trim :poke: I thought the same thing when I saw it...... :rofl: :rofl: .....but no.......big copper staple...... Quote Link to comment
r0p0doe Posted June 30, 2015 Report Share Posted June 30, 2015 I thought the same thing when I saw it...... :rofl: :rofl: .....but no.......big copper staple...... I say you should still blame him and make him buy you some new rubber or dab you out, since you guys are into that sort of thing lol 2 Quote Link to comment
Busta Nut Posted June 30, 2015 Author Report Share Posted June 30, 2015 I say you should still blame him and make him buy you some new rubber or dab you out, since you guys are into that sort of thing lol Dabs are a given...... ......Firstdime supplies beer for me...... Price of having a shop to do what you please at....... .............seems fair to me....... B) 2 Quote Link to comment
Busta Nut Posted June 30, 2015 Author Report Share Posted June 30, 2015 Back to the seats......... When I flattened this one......same issue hitting the lever...... ........so......moar cutting and grinding....... 1 Quote Link to comment
Busta Nut Posted June 30, 2015 Author Report Share Posted June 30, 2015 Moar clearance issues on the other end..... 1 Quote Link to comment
Busta Nut Posted June 30, 2015 Author Report Share Posted June 30, 2015 This is how I wnna mount it..... To do that.....I took one of these HD brackets and trimmed it.... Quote Link to comment
Busta Nut Posted June 30, 2015 Author Report Share Posted June 30, 2015 Cut open a slit in my carpet to keep it tucked out of sight.... Gave it a slight bend to wrap around the tunnel.... 1 Quote Link to comment
Busta Nut Posted June 30, 2015 Author Report Share Posted June 30, 2015 Mocked up and gave it a quick ZAP...... 1 Quote Link to comment
Busta Nut Posted June 30, 2015 Author Report Share Posted June 30, 2015 Forgot...... Had to ovalize the hole to get the bolt in once it's welded up...... 1 Quote Link to comment
Busta Nut Posted June 30, 2015 Author Report Share Posted June 30, 2015 Back Bench..... ....I knew going in it wasn't gonna be easy...... ..............turned out to be easier than I though....... I syked myself out :lol: Pulled back cover.... 1 Quote Link to comment
