Project 5Teeezy.........A Pharaoh's 510.....
Busta Nut
  • Replies 2.4k
Bolted the back head rest down......
.......I didn't have enough time before Canby to really dial in the mounts for the back seat so I just wedged everything in for the trip......
This is pretty much what it's gonna look like......
567D5100-DD58-48A3-93B3-4303403DA145_zps
A0A93ECE-CD6D-4A37-945A-3301FA8978E7_zps
3 things need to be done......
-the back needs to be mounted up correctly.....
-the bench needs to have some kind of support made.......
-seatbelts back in.....
Stereo time......
I don't want a fancy deck ruining my nice old dash....... :sick:
.............so just an amp straight to the ipod is what I'm doing......
Had this amp for a while.....something like 100-150wx2.....good enough for now.....
........i don't think the speakers can even handle it but we'll find out..... :sneaky:
0F7ACD4C-F379-47E8-8F75-2D200620FF8C_zps
Makin sure it all still works....
AC8B2E8C-4E7A-4C85-9DB5-099AB5ABBCE1_zps
Don't want the amp visible.....so we are using the old mounting spot for the parcel shelf in the trunk....
.....I cut a piece of plywood the size of the amp....found some brackets that I cut and bent....
........using the existing mounting spots for the shelf also....
7FC57073-B1CA-4F1D-8817-FD3A7516BF97_zps
3E844F41-2A16-4B3C-85DB-935562258A70_zps
1332422B-9622-4B84-B792-E11ADA3A2847_zps
7F0CB7DB-D8C8-42B0-B792-D2F7719BD8D6_zps
There were a couple holes in my trunk so I cut the tip off a vacuum cap to feed the wire through......
600FC37D-EF15-48D0-860D-FCDC6A0CEA36_zps
4842F256-A65D-47C9-81FA-1B1D5F01564D_zps
One up top...one on the bottom.....
B0EC3754-3448-4137-8FC0-561283703DA0_zps
E00D3275-EF56-4642-A2B8-32B2E044CD45_zps
I did have to make a new hole and used some plumers tape to hold up the other end of the amp.....
F5893B79-F3D3-496F-BFFB-E5017D0BD392_zps
Kalani wasn't gonna use his trunk mat so I washed it and dropped it in mine......
8BA6C6D3-F674-4BD0-9DD0-AD69A5E9D088_zps
  • Like 4
I was running out of time before Canby so I just put a switch in the trunk to turn the amp on and off.....
.....I will run this to the front along with a cleaner run audio cable......
I did test to see what would happen if I left it on somewhere also......
.........played music for about 5 hours at full volume while cleaning and packing the car.....
....started right up.....battery still had over 11v in it...... :thumbup:
919242C9-83E1-4EFA-8D78-868FCA274864_zps
.....and a track accent to the interior......
ED186D99-C95F-407A-82A1-06205D8404A0_zps
Here she was.....ready for Canby.....
0B9484D6-70DF-4897-AD52-75DD05982997_zps
  • Like 7
Maaaaaaaan.......
I wasn't even driving this time......
520C01C0-D5E4-4B3B-BBE9-1629FBB11580_zps
:rofl:
  • Like 4
That's not a cop. Looks like aqmd or some state regulated dick. No politics though.lol
County Sheriff......said I wasn't low enough and gave me a ticket........
  • Like 7
