mrbigtankers 521
mrbigtanker
  • Replies 7.1k
Ray, If you have ran avation gas or race gas you will need to clean the inside before welding. Plus I like too purge the header with argon, you can use masking tape to block the flange(the argon will weld the inside for you). Even if it didn't break all the way off, I would cut it all the way off so you can get it clean before welding.
Thanks for the info, But I think I am going to just make a new Stainless Steel one. Something exoctic or with alot of bends in it.
