gene knight Posted September 7, 2015 Author Report Share Posted September 7, 2015 Worked on truck (grimace) today with my 2 nephews. Proceeded to bleed brakes but had leaking issues at the proportioning valve. I guess I need to figure out what the problem is 1 Quote Link to comment
gene knight Posted September 19, 2015 Author Report Share Posted September 19, 2015 No updates on grimace yet, been dealing with rib injury and daddy issues(tires, radiator leaking on his minivan) 1 Quote Link to comment
gene knight Posted September 26, 2015 Author Report Share Posted September 26, 2015 no updates but still having brake bleeding issues 1 Quote Link to comment
mklotz70 Posted September 26, 2015 Report Share Posted September 26, 2015 Worked on truck (grimace) today with my 2 nephews. Proceeded to bleed brakes but had leaking issues at the proportioning valve. I guess I need to figure out what the problem is Do you have the adapters on both sides for the inverted flare? Most of the ones I've seen do not allow you to mount the brake line directly to the valve body without an adapters. 1 Quote Link to comment
gene knight Posted September 26, 2015 Author Report Share Posted September 26, 2015 The lines that are leaking are at the tee valve for the front brakes. Me and Charlie decided to use some 620 lines cuz of the loops 1 Quote Link to comment
cruznude Posted September 26, 2015 Report Share Posted September 26, 2015 Gene, its all looking good. Keep it going bro, Next time in Phoenix I will stop by and see you and charlie. You guys take care. 1 Quote Link to comment
gene knight Posted October 10, 2015 Author Report Share Posted October 10, 2015 Well me and Charlie69 worked on grimace today, hopefully we finally got the brake fluid leaking issues fixed now I gotta sweet talk the mrs. bail n chain to help with $$ that way I can get it painted and ready for the severed ties show here in Phoenix on Dec. 5th, at the castle n coasters playland 2 Quote Link to comment
Charlie69 Posted October 10, 2015 Report Share Posted October 10, 2015 Gene you best get to the gym before you go back to work! LOL Quote Link to comment
gene knight Posted October 11, 2015 Author Report Share Posted October 11, 2015 Yeah I know 1 Quote Link to comment
gene knight Posted October 30, 2015 Author Report Share Posted October 30, 2015 Worked on the brake issues last week after finding brake fluid on my garage floor, it seems that the wheel cylinder on the left rear leaks, I have had trouble with that side for some time, even though I put new brakes, hardware and new lines, cylinders back in 2006 and drove it a few times and took it to shows, the manufacturer's who make the dust boots for the wheel cylinders need to read do the molds cuz they don't look right or seem to seal up in the groove properly. I bought everything when I worked at BAP IMPORT PARTS, I have since then bought a new wheel cylinder from Napa and sprayed brake cleaner on shoes, hardware, backing plates and reassembled the brakes now I have to adjust and rebleed the rear brakes again 1 Quote Link to comment
mklotz70 Posted October 30, 2015 Report Share Posted October 30, 2015 The boot on the outside is just a dust cap and not meant to seal in the fluid. If it's leaking, the cup inside is the problem. 2 Quote Link to comment
gene knight Posted October 30, 2015 Author Report Share Posted October 30, 2015 Charlie69 inspected the rubber seals and it looks like it has a cut on the seal that is on the piston, and it looks like they are reman wheel cylinders cuz piston/seal coated in gray/aluminum material 1 Quote Link to comment
mklotz70 Posted October 30, 2015 Report Share Posted October 30, 2015 Yep....that sounds right. 1 Quote Link to comment
banzai510(hainz) Posted October 30, 2015 Report Share Posted October 30, 2015 buy new if possible even if its made in Taiwan Quote Link to comment
Draker Posted October 31, 2015 Report Share Posted October 31, 2015 Rockauto.com should have em. Quote Link to comment
gene knight Posted October 31, 2015 Author Report Share Posted October 31, 2015 I bough 1 from Napa with the same issue with the dust boot not being formed/made right but I installed it now going to bleed and check for leaks again 1 Quote Link to comment
Charlie69 Posted October 31, 2015 Report Share Posted October 31, 2015 Gene, take the good dust boot off the bad wheel cylinder and use it on the good wheel cylinder. Quote Link to comment
gene knight Posted November 2, 2015 Author Report Share Posted November 2, 2015 Well double checked brake shoes/hardware installation and adjusted shoes to make sure that the drum doesn't turn then loosened the up to wear drum turns and has slight drag 2 Quote Link to comment
gene knight Posted December 8, 2015 Author Report Share Posted December 8, 2015 Grimace is just sitting in garage with left rear on jack stand and is being neglected 1 Quote Link to comment
gene knight Posted January 12, 2016 Author Report Share Posted January 12, 2016 Got to get motivated again and get back on grimace, but with my work schedule and trying to get my nephew's 620 drivable and the rain we have been getting plus to many other projects there is no free time. I need help 1 Quote Link to comment
gene knight Posted January 19, 2016 Author Report Share Posted January 19, 2016 Went to pick n pull with Charlie got some parts 2 Quote Link to comment
Pacific coast Datsun Posted January 20, 2016 Report Share Posted January 20, 2016 2 Quote Link to comment
gene knight Posted February 1, 2016 Author Report Share Posted February 1, 2016 nothing to update Quote Link to comment
gene knight Posted February 9, 2016 Author Report Share Posted February 9, 2016 Yesterday me, charlie69, my nephew went to bullhead city to meet up with some of our SWDP DATSUN BROTHERS and drop off some much needed tools to 1 of them and also pick up a GT Spoiler fiberglass she'll for grimace. It was on an old School ford courier back in the day. The pictures of it are on a post under trucks listed as SWDP saves the leprechaun (sortof) 2 Quote Link to comment
Pacific coast Datsun Posted February 10, 2016 Report Share Posted February 10, 2016 "1 of them" checking in here LoL ! Post a few pics of the shell on Grimace asap... 1 Quote Link to comment
