210's UNITE!!!!!!!!!
Capital15
  • Replies 2k
Hater.
LMFAO.  All in good fun!
A Nissan with Toyota wheels…enough said.  Its like a Z with an LS, or Roadster with a Miata engine.
Not easy finding 14x7 wheels.
Will it be just as bad to put an L motor in it as well?
Nah, its like a Chevrolet with a Ferrarri engine ...
Nope, try a ford mustang with a chevy motor in it!
Seen my 14inch Advans yet and hell no, I'm about to do a NapZ swap in my 210 with a dual side draft set up. It will be sweet!
L18 with SUs for me. Just need to find a short L trans.
Already have the A10 crossmember.
Lucky! I was going to do an L16 til John traded me for the NapZ with dogleg 5 spd, best part is the motor and trans should be a straight drop, no holes to cut or mounts to mod.
Yeah, I know the A10 is a straight bolt in. You'd need to have it because the L motor is a rear sump, the A motor is front sump, just like the NapZ motor. Once Nismo fest passes, my A motor comes out along with all the drive train and the NapZ goes in. You should really be hunting for the A10 gauges with Tach, plugs up and is a perfect fit for our model 210's.
I have all of that.
The A10 is front sump and I have a front sump pan for the L.
I have the full gauge set from the later A10 also. It will work you say?
Links?
I hate you...but in a good way! XD That is sweet but from a latter year? Not sure where the links can be found but DatsunFreak is the one who told me all about this. You should hit him up for info because when it comes to the 79-83 210, he knows them well what will swap into them. I think it's certain year A10's that have direct fitment into the 79-80 round headlight 210. I'll check to see if I can find it for you.
The A10 and the B310 are the same platform, so are mechanical parts and suspension parts swap.
It's basically a bolt-in for the square headlight cars. So you may need to at least find a later dash (assuming yours is round eye, will go look in a minute) and maybe a later dash harness.
Then you should have PM'd me.   :rofl:
I may be desperate-but I ain't gonna beg. lol.
Cool to know about the A10 cluster. Glad I kept it.
Been lightly looking for a later 210 dash.
I would start "lightly looking" for an early A10 tach.   ;)
  • 1 month later...
