Scatoty Posted February 16, 2010 Report Share Posted February 16, 2010 Just curious what is your favorite engine for a 510? Personally my favorite is the stock L16 Quote Link to comment
sssr20det510 Posted February 16, 2010 Report Share Posted February 16, 2010 Are you looking to get flamed, you might want your first post to be a liitle more like an introduction not this Quote Link to comment
datzenmike Posted February 16, 2010 Report Share Posted February 16, 2010 What, not a SBC!!!! Quote Link to comment
INDY510 Posted February 16, 2010 Report Share Posted February 16, 2010 A twin turbo V12 is the best 510 engine: Quote Link to comment
MicroMachinery Posted February 16, 2010 Report Share Posted February 16, 2010 Monstrosity.. 1 Quote Link to comment
Duke Posted February 16, 2010 Report Share Posted February 16, 2010 I agree with the OP, L-16 is where it is at, with a little side note. My ideal L-16 would have a twin cam head of the OS Giken or Nissan LZ variety. That would be nearly perfect in my book. Quote Link to comment
LeX Posted February 16, 2010 Report Share Posted February 16, 2010 my personal choice would be a FJ20e with sidedrafts . yum Quote Link to comment
Jesse C. Posted February 17, 2010 Report Share Posted February 17, 2010 I love a hard running L motor, but, I am going VG30 and later VG33. And oh yeah, who are you? Intro? Quote Link to comment
HRH Posted February 17, 2010 Report Share Posted February 17, 2010 Hartley V8, would do it in a second if I had the cash. * 75° odd fire V8 * 2.8 LITER, 170 cu. in. displacement (3.0 liter optional) * 84mm Bore X 63mm Stroke (67 stroke optional) * 4 cams, 32 valves via internal silent chain * 530mm wide x 485mm long x 530mm high * 400HP @ 10,000 rpm with stock street cams (higher spec. is available) * 245 ft-lbs torque @ 7500 rpm * 200 lbs engine weight * Billet nitrided steel 180° crank * 4340 H-beam con-rods with ARP bolts * Billet 6061-T6 aluminum crankcase * Dry sump 0il system with 4 stage pump * 7.25" or 5.5" Twin disc clutch * DTA S80 full sequential ECU * Unique cylinder offset and cam drive arrangement yields a compact design- Patent No. 7,168,405 What's not to like? Quote Link to comment
HRH Posted February 17, 2010 Report Share Posted February 17, 2010 Z-OMG.... This is the awesomest thread ever!!! I agree the L16 is the ultimate 510 engine... But I think Datzenmike is right,,, a SBC would be even awesomer.... If I was building a drag 510 I would probably just go with a simple clean V12 swap: I only see 5 intake runners per side, does it go under the cowl through the firewall? Quote Link to comment
Duke Posted February 17, 2010 Report Share Posted February 17, 2010 Hartley V8, would do it in a second if I had the cash. * 75° odd fire V8 * 2.8 LITER, 170 cu. in. displacement (3.0 liter optional) * 84mm Bore X 63mm Stroke (67 stroke optional) * 4 cams, 32 valves via internal silent chain * 530mm wide x 485mm long x 530mm high * 400HP @ 10,000 rpm with stock street cams (higher spec. is available) * 245 ft-lbs torque @ 7500 rpm * 200 lbs engine weight * Billet nitrided steel 180° crank * 4340 H-beam con-rods with ARP bolts * Billet 6061-T6 aluminum crankcase * Dry sump 0il system with 4 stage pump * 7.25" or 5.5" Twin disc clutch * DTA S80 full sequential ECU * Unique cylinder offset and cam drive arrangement yields a compact design- Patent No. 7,168,405 What's not to like? Oh yeah, the Hartly V8 is an amazing piece. Such an awesome engine. Have you seen the DP-1 from www.palatov.com? Quote Link to comment
datzenmike Posted February 17, 2010 Report Share Posted February 17, 2010 Z-OMG.... This is the awesomest thread ever!!! I agree the L16 is the ultimate 510 engine... But I think Datzenmike is right,,, a SBC would be even awesomer.... WHAT? What I said was: What, not a SBC!!!! I was being factious. :D It would definitely be a VK56VD. :lol: Quote Link to comment
INDY510 Posted February 17, 2010 Report Share Posted February 17, 2010 Sorry Mike,,, I was just trying to be funny And,, uh,, ... the V12 is a photochop My dream 510 engine would be a CA18DET.... My dream Datsun 1200 motor is the Hartley H2: http://www.youtube.com/watch?v=5dLft3fLtKs About half the price of the Hartley H1 V8....... custom billet lower case for a 1300cc or 1400cc Hayabusa motor..... or the big bore kit for 1600cc Allows for a custom bell housing for a RWD car transmission.....weighs 140lbs...250hp.... 11k rpm Quote Link to comment
510love Posted February 17, 2010 Report Share Posted February 17, 2010 if i could put any motor in a 510 i would put a rb30dett. talk about one helluva motor.....makes me wanna cry 1000hp at the wheels hes working on another motor to hit the 2000hp mark. Crazy Australians always doing it BIG lol. im mean look at this fuggin turbo!!! gt45r OMG you could fit ur head into the darn thing!! Quote Link to comment
rzrdisco Posted February 17, 2010 Report Share Posted February 17, 2010 Hartley V8, would do it in a second if I had the cash. * 75° odd fire V8 * 2.8 LITER, 170 cu. in. displacement (3.0 liter optional) * 84mm Bore X 63mm Stroke (67 stroke optional) * 4 cams, 32 valves via internal silent chain * 530mm wide x 485mm long x 530mm high * 400HP @ 10,000 rpm with stock street cams (higher spec. is available) * 245 ft-lbs torque @ 7500 rpm * 200 lbs engine weight * Billet nitrided steel 180° crank * 4340 H-beam con-rods with ARP bolts * Billet 6061-T6 aluminum crankcase * Dry sump 0il system with 4 stage pump * 7.25" or 5.5" Twin disc clutch * DTA S80 full sequential ECU * Unique cylinder offset and cam drive arrangement yields a compact design- Patent No. 7,168,405 What's not to like? Think the Hartleys could use some direct injection? :cool: Quote Link to comment
Spades Posted February 17, 2010 Report Share Posted February 17, 2010 hrm...if I was going to make it a drag car and didnt want to go to the work involved to put a large motor in....chevy 4.3 v6 with a supercharger on it. if I didnt mind munching into the sheetmetal...would be fun to see a big block 502 in a datsun for sh-ts and giggles. if I was looking at a better engine than what I had now for a daily driver... CA18DET... p.s. yes, it is kind of a lame introduction post, especially given the fact he put the "stock l16" as his personal favorite...but, cut the noob some slack I guess and just have some fun with theoretical swaps :D Quote Link to comment
sssr20det510 Posted February 17, 2010 Report Share Posted February 17, 2010 if i could put any motor in a 510 i would put a rb30dett. talk about one helluva motor.....makes me wanna cry 1000hp at the wheels hes working on another motor to hit the 2000hp mark. Crazy Australians always doing it BIG lol. im mean look at this fuggin turbo!!! gt45r OMG you could fit ur head into the darn thing!! Did you see what happened to the 510 with the rb25det on the realm, check it out Quote Link to comment
jefe de jefes Posted February 17, 2010 Report Share Posted February 17, 2010 Did you see what happened to the 510 with the rb25det on the realm, check it out was it the one that was wrecked? Quote Link to comment
Gensaiken Posted February 21, 2010 Report Share Posted February 21, 2010 an L series with a Twin Cam head. :hyper: Quote Link to comment
Guest kamakazi620 Posted February 21, 2010 Report Share Posted February 21, 2010 HEMI POWER!!!!!!!! MOPAR!!!!! is short for More power!!!!! hahahahahaha :lol: :lol: :o :lol: :lol: :lol: Quote Link to comment
DARIN 510 Posted February 22, 2010 Report Share Posted February 22, 2010 i like the OS Giken TC-16. beyond rare. also fucken expensive. Quote Link to comment
bonvo Posted February 22, 2010 Report Share Posted February 22, 2010 i like the OS Giken TC-16. beyond rare. also fucken expensive. if i remember correctly that is just an l16 with a custom head so the lock isnt rare just the head? Quote Link to comment
DARIN 510 Posted February 23, 2010 Report Share Posted February 23, 2010 no shit, that's what i was talking about.no its an L18.still a different motor. Quote Link to comment
freekwonder Posted February 23, 2010 Report Share Posted February 23, 2010 Gallo 12 the Gallo 24 is just to big for a dime. 1 Quote Link to comment
