Project "Against the grain" turbo720 build
nis720
  • Replies 693
Update... working on the tranny.
Went to the dealer and picked up some goodies.
Throw-out bearing.
Just as I suspected... the guy who rebuilt my tranny the last time used silicone only to seal the front cover.
  • 4 weeks later...
  • 1 month later...
Nicest 720 I have ever seen, hope you are going to use a Centerforce clutch. I used to have a Mitsu GSX and a stock clutch will not last behind a turbo engine. Sure wish all those photos weren't deleted, so I could see all the progress. biggrin.gif
WAIT !!! before you install that pilot bushing for the trans...
do yourself a huuuge favor- go buy a 'needle bearing' style pilot bush instead of that brass one. The brass ones will eventually shred and make you think your throwout bearing is going out.
i think this one is for mazda, but they do make them for KA's http://www.frsport.com/Mazda-OEM-Replacement-Crankshaft-Clutch-Pilot-Bearing_p_8929.html
i did it and upgraded to Nismo bearing as well as Nismo fork pivot bearing. never have to fix it again...
Thanks, not using a centerforce. Went with Gripforce 300zx Stage III clutch.
Pilot bushing was already in... I used the Nissan pilot bushing instead of the one that comes with the kit. Same for the T/O bearing.
The pivot was fine. What is the difference between the Nismo one and the OEM one?
