edekalil Posted July 15, 2015 Report Share Posted July 15, 2015 Running the little cars all over. Quote Link to comment
shacks510 Posted July 15, 2015 Report Share Posted July 15, 2015 :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:-_- Quote Link to comment
edekalil Posted July 16, 2015 Report Share Posted July 16, 2015 Took a pic of my car with my brother as we whent to eat lunch. Quote Link to comment
edekalil Posted July 18, 2015 Report Share Posted July 18, 2015 Ceaned up all the trash in the back and got water re hooked up. Thanks to brother Dave. Cars out the garage and got the motors moved so I can get one together for the wagon. This 1600 that was rebuild with low mileage will go into the wagon. Also gota clean up and move a couple of transmissions where the motors once sat. Quote Link to comment
edekalil Posted July 19, 2015 Report Share Posted July 19, 2015 Airing out the wagon, it's been dry for the last week. Got to put a couple of tarps to keep it dry I hope till I can get back on it now that the back aera is cleaned up and I got the motor where I can get a clutch and trans on it easier to gut it in the wagon. Here is the motor that will be put in the wagon, I had rebuilt it way back then later took it out. Not sure if it had some oil seeping out where head mated to the block but I will put it in, get it running and then refigure it out. The lower end of the motor should be fine. Also got the two sedans out to run some. Gotta get that funky gas out and get em running better. So far they have been running fairly consistent. Overall Enjoying the ride. 1 Quote Link to comment
DUBL ZERO Posted July 21, 2015 Report Share Posted July 21, 2015 I Installed a New Trunk Emblem !! Quote Link to comment
ByStickel Posted July 21, 2015 Report Share Posted July 21, 2015 '68 Camaro mirrors. About $16 each. Smooth, vs ribbed base. Quote Link to comment
Son_of_a_Datsun_Guy Posted July 21, 2015 Report Share Posted July 21, 2015 '68 Camaro mirrors. About $16 each. Smooth, vs ribbed base. Are those metal or plastic? And if you don't mind sharing, where'd you pick them up and how do you like the manufacturing quality? Quote Link to comment
edekalil Posted July 21, 2015 Report Share Posted July 21, 2015 Been digging driving the 70/510 all week. Quote Link to comment
DUBL ZERO Posted July 21, 2015 Report Share Posted July 21, 2015 edekalil, Its Time for you to post engine and interior pics Quote Link to comment
edekalil Posted July 21, 2015 Report Share Posted July 21, 2015 When I get back next week I will do. Quote Link to comment
ByStickel Posted July 22, 2015 Report Share Posted July 22, 2015 Metal. Decent quality from Partsgeek.com. GM offers their own, for 3x+ the price, but I'm pleased with these. No telling how they'll hold up. If you mount them in the concave channel, as I did, they don't fit perfectly, but are still pretty good. They'd fit a little better on a flatter surface. I trimmed a small portion of the rubberized trim base plate and just figured that a $16 solution wasn't going to be factory engineered. I'm happy with them. Are those metal or plastic? And if you don't mind sharing, where'd you pick them up and how do you like the manufacturing quality? Quote Link to comment
Lockleaf Posted July 22, 2015 Report Share Posted July 22, 2015 '68 Camaro mirrors. About $16 each. Smooth, vs ribbed base. Mirrors look really good. Is that a dually 620 in the background? Quote Link to comment
hobospyder Posted July 22, 2015 Report Share Posted July 22, 2015 Since we're questioning the 620 in the background, what the hell is going on with the front tires? I didn't even notice that there Quote Link to comment
Tristin Posted July 22, 2015 Report Share Posted July 22, 2015 It just looks like a 620 with an extra set of wheels leaning up against it. Probably seeing what it would look like with new rims. Quote Link to comment
hobospyder Posted July 22, 2015 Report Share Posted July 22, 2015 Or storing like that. Los weird but I think someone needs to do dually on all four Quote Link to comment
Lockleaf Posted July 22, 2015 Report Share Posted July 22, 2015 Haha wow, I did not even notice the front tires. That's great. I think tristin is likely correct, but I agree with you hobo, someone needs to build a 4 wheel dually just for the Hell of it :) Quote Link to comment
q-tip Posted July 23, 2015 Report Share Posted July 23, 2015 8 tires are better than 4 Quote Link to comment
edekalil Posted July 26, 2015 Report Share Posted July 26, 2015 edekalil, Its Time for you to post engine and interior pics OK I am back home now and will get some pics of the motor and inside of the 70/510 but it is just as I got it way back. It is stock and very messy. My main issue at this time due to no time is to run, run ,run and run this car to get all the funky gas out of it then put some fresh gas in it with some more Seafome in it. It is running very consistently now just got to keep it going. Next is to get some new tires, the old ones are old and not sure how far they will go before exploding. Quote Link to comment
datsunfreak Posted July 27, 2015 Report Share Posted July 27, 2015 My main issue at this time due to no time is to run, run ,run and run this car to get all the funky gas out of it then put some fresh gas in it with some more Seafome in it. Why not just pull the drain plug on the tank? Then drop in fresh gas and you're good to go? Quote Link to comment
edekalil Posted July 27, 2015 Report Share Posted July 27, 2015 Why not just pull the drain plug on the tank? Then drop in fresh gas and you're good to go?Well being downtown and nouthing to drain a mostly full tank of gas in is a problem. But it's getting better as I keep running her. If I still was in the country it would be different. Quote Link to comment
edekalil Posted July 27, 2015 Report Share Posted July 27, 2015 Here are som oics of the 70/510. I do have to clean her up just real busy with very little time. But drove her around yesterday. 2 Quote Link to comment
edekalil Posted July 27, 2015 Report Share Posted July 27, 2015 Drinking coffee with the 72/510. Quote Link to comment
edekalil Posted July 27, 2015 Report Share Posted July 27, 2015 Wondered why she was running a bit ruff, the front cylinder was not getting any spark made sure the wires where all connected. Fired it up and all was good. Probably time to get a new set. Now I have to figure out getting that Weber 32/36 DGV on. Quote Link to comment
DUBL ZERO Posted July 27, 2015 Report Share Posted July 27, 2015 Where did you get the ratsun grill badge. Quote Link to comment
