Ooph! Posted September 24, 2023 Report Share Posted September 24, 2023 looks and sounds like a very tall 1st gear Quote Link to comment
frankendat Posted September 24, 2023 Report Share Posted September 24, 2023 On 9/21/2023 at 12:48 AM, Dusten said: You can attempt to judge the situation all you want. Judge the situation? I'm trying to commiserate and relate, you know, find common ground. We are different and the same. My father passed in July and he was a machinist--different and same. But I understand if your guarded, posting (that you) live large, big house, five cars, you're in charge-Comin' up in the world-Don't trust nobody-Gotta look over your shoulder constantly-C. Hill Quote Link to comment
Dusten Posted September 24, 2023 Author Report Share Posted September 24, 2023 2 hours ago, frankendat said: Judge the situation? I'm trying to commiserate and relate, you know, find common ground. We are different and the same. My father passed in July and he was a machinist--different and same. But I understand if your guarded, posting (that you) live large, big house, five cars, you're in charge-Comin' up in the world-Don't trust nobody-Gotta look over your shoulder constantly-C. Hill Coming up lol. 43 yrs old and divorced and recovering is more like it. The comment about never getting towed and mocking my tools isn't finding common ground. 1 Quote Link to comment
Dusten Posted September 24, 2023 Author Report Share Posted September 24, 2023 5 hours ago, Ooph! said: looks and sounds like a very tall 1st gear Stock 280z five speed and stock gears. 1 Quote Link to comment
Dusten Posted September 27, 2023 Author Report Share Posted September 27, 2023 On 9/23/2023 at 11:29 PM, frankendat said: Judge the situation? I'm trying to commiserate and relate, you know, find common ground. We are different and the same. My father passed in July and he was a machinist--different and same. But I understand if your guarded, posting (that you) live large, big house, five cars, you're in charge-Comin' up in the world-Don't trust nobody-Gotta look over your shoulder constantly-C. Hill Now here's one that would almost be worth the money to go get simply because it's close https://m.facebook.com/marketplace/item/6049604128472951/?ref=newsfeed 1 Quote Link to comment
frankendat Posted September 28, 2023 Report Share Posted September 28, 2023 On 9/24/2023 at 3:08 AM, Dusten said: Coming up lol. 43 yrs old and divorced and recovering is more like it. The comment about never getting towed and mocking my tools isn't finding common ground. The written word, while convenient, will not express inflection. I know this, but forget when I get comfortable. It was not my intention to mock your tools or your tow. For the former, it is only envy, If I ever acquire a Snap-on anything (which is unlikely) it will be from some lucky trade or windfall. The retail prices for Snap-on tools are often 10X what I paid for mine. The latter is similar, only recently, has "short tow coverage" been included in my insurance. The majority of my life, being towed has been a luxury. Datsun has been synonymous with your buddy holding a flashlight out the window, because you don't dare turn on the headlights, because the alternator went out and you need to get home or a host of other sketchy shit. I don't think you're lacking. It is a good thing, no disrespect intended or implied. Sorry to hear of your split, it is always unpleasant. We are all "coming up", unless you're the lead dog the scenery never changes. https://www.youtube.com/watch?v=W4VpE-0zitU 1 Quote Link to comment
Dusten Posted September 30, 2023 Author Report Share Posted September 30, 2023 Well from my other thread I thought I had a failed coil or hei module. It turns out I failed to tighten the negative cable when I installed a new battery. This caused me to re-evalute my ignition system. I found the stock transistor box for the truck. I verified all the wiring was correct and in place and decided to remove the hei system. I'm a big fan of OEM parts when available. The coil is an ngk 1.5 ohm coil so no resistor. I also got tired of the pathetic horn that the previous owner had installed. I researched good OEM horns and settled on the gm 4 tone setup. Sadly when I pulled them from the wrecking yard only 3 worked. But they still sound better. The horns as mounted And the grill back in place The underhood now without the hei and horn. And the horns https://www.instagram.com/reel/Cx1bKgkvMhm/?igshid=MzRlODBiNWFlZA== 1 Quote Link to comment
Dusten Posted October 1, 2023 Author Report Share Posted October 1, 2023 Quick cold start now that everything works https://youtu.be/GioKjKKiT5Q?feature=shared Quote Link to comment
Dusten Posted October 1, 2023 Author Report Share Posted October 1, 2023 Gave it a bath. Cleaned off the engine a bit. Quote Link to comment
banzai510(hainz) Posted October 1, 2023 Report Share Posted October 1, 2023 usually the 1.5 or 1.6 ohm coils are for the point ignition with 1.6 ohm ballast. the EI coils are like .7 ohms remote box or matchbox ignitions(no ballast) just feel the coil when running it. if it feels HOT then its a point coil and in time the insulation melts and shorts out. 1 Quote Link to comment
Dusten Posted October 1, 2023 Author Report Share Posted October 1, 2023 11 minutes ago, banzai510(hainz) said: usually the 1.5 or 1.6 ohm coils are for the point ignition with 1.6 ohm ballast. the EI coils are like .7 ohms remote box or matchbox ignitions(no ballast) just feel the coil when running it. if it feels HOT then its a point coil and in time the insulation melts and shorts out. A 3 ohm coil is for points 1.5 is ei Quote Link to comment
datzenmike Posted October 2, 2023 Report Share Posted October 2, 2023 0.75-1.0 ohms is for EI system. Points are about 1.5 ohm coil plus 1.5 ohm ballast resistor adding to 3.0 running. This is likely a points coil which expects a 1.5 ohm ballast in line to cut the current flow down. It will work, but is letting too much current through it. The coil itself will run much hotter, possibly frying it. Can you grab onto the coil and hold it? If not it's too hot. You'll get more spark from a proper 1 ohm EI coil and it won't over heat. Quote Link to comment
Dusten Posted October 2, 2023 Author Report Share Posted October 2, 2023 8 hours ago, datzenmike said: 0.75-1.0 ohms is for EI system. Points are about 1.5 ohm coil plus 1.5 ohm ballast resistor adding to 3.0 running. This is likely a points coil which expects a 1.5 ohm ballast in line to cut the current flow down. It will work, but is letting too much current through it. The coil itself will run much hotter, possibly frying it. Can you grab onto the coil and hold it? If not it's too hot. You'll get more spark from a proper 1 ohm EI coil and it won't over heat. The coil literally says "use with electronic ignition on it" So I'll leave it alone. Quote Link to comment
datzenmike Posted October 2, 2023 Report Share Posted October 2, 2023 Good enough for me then on the over heating. Quote Link to comment
banzai510(hainz) Posted October 2, 2023 Report Share Posted October 2, 2023 (edited) 3 ohm is combined with he ballast and stock coil. been that way since 1970 then in 78 and after the .7 ohm coil used with EI. But if it dont get HOT and ignition module dont burn up in 3 years guess your good. ON point set up during start the ballast is bypassed so only the 1.5 ohm coil get the current thru so a bigger spark during COLD start up. then when key goes to ON it goes thru the ballast and then the coil to prevent the point/pertronix buring . If you have a EI dist in there then use a .7 ohm coil for bigger spark. If it runs call it good Edited October 2, 2023 by banzai510(hainz) Quote Link to comment
Dusten Posted October 2, 2023 Author Report Share Posted October 2, 2023 8 hours ago, datzenmike said: Good enough for me then on the over heating. Lol it's not overheating. Here ya go. This is before I started the truck Quote Link to comment
banzai510(hainz) Posted October 2, 2023 Report Share Posted October 2, 2023 yep I say it good. I had one guy hes coil was aburning HOT to the touch Quote Link to comment
Dusten Posted October 2, 2023 Author Report Share Posted October 2, 2023 And after 2 hours of errands. Including not being shut off forn45 minutes straight The coil The manifold For comparison of surrounding temps The fender and brake booster the coil is at a temp id consider acceptable. 1 Quote Link to comment
Dusten Posted October 2, 2023 Author Report Share Posted October 2, 2023 The meter when touching leads. Meaning we need to deduct that from whatever resistance I see And the coil The coil is approximately 1 ohm 1 Quote Link to comment
banzai510(hainz) Posted October 2, 2023 Report Share Posted October 2, 2023 when the due cal date on that Boeing Fluke Meter? Or your Rich$$$$ I got a 77 also Quote Link to comment
Dusten Posted October 3, 2023 Author Report Share Posted October 3, 2023 56 minutes ago, banzai510(hainz) said: when the due cal date on that Boeing Fluke Meter? Or your Rich$$$$ I got a 77 It's mine. I have an 87 too but after 25 years the screens starting to have issues Quote Link to comment
datzenmike Posted October 3, 2023 Report Share Posted October 3, 2023 4 hours ago, Dusten said: Lol it's not overheating. Yes. What I meant was I agreed with your comment that it's for electronic ignition so overheating is not an issue.. Quote Link to comment
Dusten Posted October 4, 2023 Author Report Share Posted October 4, 2023 Seat covers will be here Friday Im going to order the kd valve spring compressor and do valve seals. I'm getting a little puff on start up with the cooler weather and the truck is about a quart ever 1000 miles. Quote Link to comment
datzenmike Posted October 4, 2023 Report Share Posted October 4, 2023 Have a look round for oil leaks also. Stick cardboard under the front and check in the morning. Most common is the valve cover gasket. If wet, replace it when you do the seals. You may have to power wash the engine several times to get all crumbly stuff off then check regularly to see where it starts. Quote Link to comment
