Crashtd420 Posted February 2 Report Share Posted February 2 10 hours ago, Dusten said: I'm aware. Checked the 4 plugs 5.5 Kohms 5.7 Kohms 5.4 Kohms 1.9 Mohms Found the problem That's an interesting way to check plugs. Very effective.... Quote Link to comment
datzenmike Posted February 2 Report Share Posted February 2 BPR6ES with the R for resistor. These plugs have a built in resistance to suppress radio interference. Increased resistance will lower the ability to fire. Current flow is a function of V/R. 1.9 million ohms will reduce current to 1/4 what a 5k ohm plug will allow. Quote Link to comment
Dusten Posted February 2 Author Report Share Posted February 2 55 minutes ago, datzenmike said: BPR6ES with the R for resistor. These plugs have a built in resistance to suppress radio interference. Increased resistance will lower the ability to fire. Current flow is a function of V/R. 1.9 million ohms will reduce current to 1/4 what a 5k ohm plug will allow. Which is exactly why it idled fine. Rev'd fine. But got increasingly worse under load. Quote Link to comment
banzai510(hainz) Posted February 2 Report Share Posted February 2 good idea. I have never thought of ohm out the plugs 1 Quote Link to comment
datzenmike Posted February 2 Report Share Posted February 2 It's increasingly harder to jump the plug gap as the engine load increases. 1 Quote Link to comment
Dusten Posted February 3 Author Report Share Posted February 3 9 hours ago, banzai510(hainz) said: good idea. I have never thought of ohm out the plugs How else would you test them? Quote Link to comment
datzenmike Posted February 3 Report Share Posted February 3 Rather subjective but hold against the grounded head and turn engine with starter. Visually do they all look the same? Quote Link to comment
Dusten Posted February 4 Author Report Share Posted February 4 Maybe if it's almost completely failed. But these would pull to 3500+ in third. I really doubt you'd see a spark difference with cranking only. Quote Link to comment
datzenmike Posted February 4 Report Share Posted February 4 As stated, pretty subjective. If one is glaringly different then change it. 1 Quote Link to comment
banzai510(hainz) Posted February 4 Report Share Posted February 4 (edited) On 2/2/2024 at 5:41 PM, Dusten said: How else would you test them? place near ground and see if sparks with Acell SUPERCOIL. be honest I havent bought new plugs in 20 years. sand blast them. If plug is out its faster to put a new plug in then getting the volt meter to ohm out when all said and done Edited February 4 by banzai510(hainz) Quote Link to comment
Dusten Posted February 5 Author Report Share Posted February 5 11 hours ago, banzai510(hainz) said: place near ground and see if sparks with Acell SUPERCOIL. be honest I havent bought new plugs in 20 years. sand blast them. If plug is out its faster to put a new plug in then getting the volt meter to ohm out when all said and done I tested them to see why the repair worked. I work in aviation. Prior to that i worked in ships out to sea. Knowing why something failed is as important as knowing it failed. I tested them then next day before I threw them away to give myself the piece of mind id fixed it. Rather than it just running better. 2 Quote Link to comment
Dusten Posted February 5 Author Report Share Posted February 5 As a side note I'll be cleaning the truck up over the next few days and selling it. I bought it's replacement today. Quote Link to comment
banzai510(hainz) Posted February 5 Report Share Posted February 5 (edited) I worked Aviation too. Denmark me on wing Edited February 5 by banzai510(hainz) 2 Quote Link to comment
Stoffregen Motorsports Posted February 5 Report Share Posted February 5 Sniffing your armpit? Or just looking gangsta. Quote Link to comment
banzai510(hainz) Posted February 5 Report Share Posted February 5 RUN DMC was BIG at the time!!!!!!!!! 2 Quote Link to comment
datzenmike Posted February 6 Report Share Posted February 6 Wiping nose on shoulder. Learned from bow hunting pigs on Maui with Tad Nugent 1 Quote Link to comment
Stoffregen Motorsports Posted February 6 Report Share Posted February 6 RUN DMC was not gansta. They were hiphop lite. Quote Link to comment
