Dusten Posted November 17, 2023 Author Report Share Posted November 17, 2023 2 hours ago, datzenmike said: Thermostats don't last forever. Nope but I didn't want to replace it and find out that wasn't my problem, so I want to do at least a little looking into it before I swapped it out Quote Link to comment
datzenmike Posted November 17, 2023 Report Share Posted November 17, 2023 It's an under 410 part and up to 20 min work. Whenever I have a heating/cooling problem, which isn't often, I shoot from the hip and simply replace it. Quote Link to comment
Dusten Posted November 18, 2023 Author Report Share Posted November 18, 2023 (edited) 1 hour ago, datzenmike said: It's an under 410 part and up to 20 min work. Whenever I have a heating/cooling problem, which isn't often, I shoot from the hip and simply replace it. A good one from Napa is $20 plus coolant. And I'm an aircraft mechanic i don't shoot from the hip. I also finally replaced the starter. I installed a gear reduction unit but it doesn't want to engage every turn. So now I get to figure that out. Edited November 18, 2023 by Dusten Quote Link to comment
datzenmike Posted November 18, 2023 Report Share Posted November 18, 2023 Pull the small start signal wire off the starter solenoid and measure the voltage in the start position. I think you'll find that it's under 9 volts. This is normal from old 20ft long thin wires multiple connections and the ignition switch. The cure is to use this voltage to switch a relay that directly connected to the battery. It's called a hot start relay. My 620 did this and I threw another starter on and nothing changed. Made a hot start relay and never fails to spin the starter. Quote Link to comment
Dusten Posted November 18, 2023 Author Report Share Posted November 18, 2023 25 minutes ago, datzenmike said: Pull the small start signal wire off the starter solenoid and measure the voltage in the start position. I think you'll find that it's under 9 volts. This is normal from old 20ft long thin wires multiple connections and the ignition switch. The cure is to use this voltage to switch a relay that directly connected to the battery. It's called a hot start relay. My 620 did this and I threw another starter on and nothing changed. Made a hot start relay and never fails to spin the starter. It does il when I use my one man start button. It's not a power drop. Quote Link to comment
datzenmike Posted November 18, 2023 Report Share Posted November 18, 2023 It will drop if the solenoid is still connected but what does it read when disconnected? Should read battery. A new starter should not hit or miss though the state of replacement starter quality these days is pretty bad. What was the old starter doing that it needed replacing? Quote Link to comment
Dusten Posted November 18, 2023 Author Report Share Posted November 18, 2023 1 hour ago, datzenmike said: It will drop if the solenoid is still connected but what does it read when disconnected? Should read battery. A new starter should not hit or miss though the state of replacement starter quality these days is pretty bad. What was the old starter doing that it needed replacing? What I mean is with the wire disconnected and using my starter button going from battery to the solenoid it does it. So I know that it's not an issue of voltage drop because I'm not even using the key or factory wiring. The old start was beginning to crank slower and slower. Quote Link to comment
banzai510(hainz) Posted November 18, 2023 Report Share Posted November 18, 2023 (edited) https://www.maniacelectricmotors.com/aftermarket-brand-starter-16584-nissan-truck.html a guy on here swears by Wilson https://www.ebay.com/itm/386256354044?fits=Model%3A280ZX|Make%3ADatsun&epid=13037529131&hash=item59eeac3afc:g:s84AAOSwVvtiUprV&amdata=enc%3AAQAIAAAA0Dqg4nOLrcxlqr1N76%2FbSC1%2BID8FqWWB3Sr5IlocTVvX8hDpYH%2BP7j41Fnf2LsLUdWIRMXRelDVE4wBo4QHsemqxDhyRsQXwRCODbh87333QQNRPm%2FbaAuI81RJmw2ZJmEI7PENFh7Ptd5ehi87gElvb1xKPMRPTebmWCxeTNGWPkC8EV3vSgzFAdaQj15u1%2FyhkxjnjepedRWVJM78Dm%2FSFcIb3Vot9Ih1KWY%2FMvo%2FuSjgwDswaj82sdjfydd5iuA70kmSwYAEFqdtypVKFnLo%3D|tkp%3ABk9SR8jL-o38Yg Troy Ermish sells a GR Denso type that MrBigtankers says works dont know if clears a 620 frame but Tanker says he has on in his 521.. photo in link shows a 510 https://ermish-racing.com/engine-accessories scroll down till see starter let us know how it works if you get the Denso type NEW Edited November 18, 2023 by banzai510(hainz) 1 Quote Link to comment
Dusten Posted November 18, 2023 Author Report Share Posted November 18, 2023 30 minutes ago, banzai510(hainz) said: https://www.maniacelectricmotors.com/aftermarket-brand-starter-16584-nissan-truck.html a guy on here swears by Wilson https://www.ebay.com/itm/386256354044?fits=Model%3A280ZX|Make%3ADatsun&epid=13037529131&hash=item59eeac3afc:g:s84AAOSwVvtiUprV&amdata=enc%3AAQAIAAAA0Dqg4nOLrcxlqr1N76%2FbSC1%2BID8FqWWB3Sr5IlocTVvX8hDpYH%2BP7j41Fnf2LsLUdWIRMXRelDVE4wBo4QHsemqxDhyRsQXwRCODbh87333QQNRPm%2FbaAuI81RJmw2ZJmEI7PENFh7Ptd5ehi87gElvb1xKPMRPTebmWCxeTNGWPkC8EV3vSgzFAdaQj15u1%2FyhkxjnjepedRWVJM78Dm%2FSFcIb3Vot9Ih1KWY%2FMvo%2FuSjgwDswaj82sdjfydd5iuA70kmSwYAEFqdtypVKFnLo%3D|tkp%3ABk9SR8jL-o38Yg Troy Ermish sells a GR Denso type that MrBigtankers says works dont know if clears a 620 frame but Tanker says he has on in his 521.. photo in link shows a 510 https://ermish-racing.com/engine-accessories scroll down till see starter let us know how it works if you get the Denso type NEW I have a starter. Until it's proven defective I'm not getting another. It's a unit from Napa so I don't suspect it Quote Link to comment
Crashtd420 Posted November 18, 2023 Report Share Posted November 18, 2023 7 hours ago, Dusten said: I have a starter. Until it's proven defective I'm not getting another. It's a unit from Napa so I don't suspect it Next time it hangs up put the truck in gear rock the truck a little to see if it moves the flywheel a little.... Then try the starter.... I swear we are having 2 of the exact same issues..... I have a new starter too, but I noticed during replacement a couple teeth on the flywheel ring gear looked a little questionable.... It gave me same issue as my older starter but spins faster.... then oddly the hang seems to have gone away lately.... Quote Link to comment
datzenmike Posted November 18, 2023 Report Share Posted November 18, 2023 If it clicks and chatters or clicks and just spins but does not engage the flywheel or it takes several tries to get engagement it could be the start signal voltage is low. Could also be the solenoid and they can be swapped separately. It it engages with a clunk but fails to turn the engine or turn it slowly this could also be the electrical contacts in the solenoid or the brushes are worn out or battery low, or battery cables and contacts are poor. Quote Link to comment
Dusten Posted November 18, 2023 Author Report Share Posted November 18, 2023 Alright Mike maybe this will help visualize my issue First video is thenold starter cranking slow. And then the new starter cranking fast but having audible issues. These are both using the key This is 2 short clips of the starter engaging and failing. Both using my jump switch with no key and signal wire removed https://youtube.com/shorts/ryFVX3vHLU8?feature=shared Quote Link to comment
Crashtd420 Posted November 18, 2023 Report Share Posted November 18, 2023 3 hours ago, Dusten said: Alright Mike maybe this will help visualize my issue First video is thenold starter cranking slow. And then the new starter cranking fast but having audible issues. These are both using the key This is 2 short clips of the starter engaging and failing. Both using my jump switch with no key and signal wire removed https://youtube.com/shorts/ryFVX3vHLU8?feature=shared That is not the same start issue as me.... sounds like the bendix is disengaging the flywheel and just spinning.... Quote Link to comment
Dusten Posted November 19, 2023 Author Report Share Posted November 19, 2023 On the bench the Bendix would randomly not shoot out. Napa has another starter on the way. 1 Quote Link to comment
banzai510(hainz) Posted November 19, 2023 Report Share Posted November 19, 2023 NAPA has gone down the same road as the other parts stores in my opinion. cheapest made. China I actually had a selinoid go bad and it was a NIssan rebuild. I couldnt belive it. got new one from Summit for the Tilton/Hitachi Superstarters Quote Link to comment
datzenmike Posted November 19, 2023 Report Share Posted November 19, 2023 11 hours ago, Dusten said: On the bench the Bendix would randomly not shoot out. Napa has another starter on the way. Some starters use the spinning armature to fling the bendix out to the starter ring. The bendix on the Nissan starters is moved out to engage the flywheel by the solenoid. If not engaging, then likely the solenoid. Quote Link to comment
Dusten Posted November 19, 2023 Author Report Share Posted November 19, 2023 9 hours ago, banzai510(hainz) said: NAPA has gone down the same road as the other parts stores in my opinion. cheapest made. China I actually had a selinoid go bad and it was a NIssan rebuild. I couldnt belive it. got new one from Summit for the Tilton/Hitachi Superstarters Box said mexico on it lol Quote Link to comment
Dusten Posted November 19, 2023 Author Report Share Posted November 19, 2023 The old t-stat wasn't stuck open. But it opened with almost no pressure. New ones in. Tested it before install. She's good to go 3 Quote Link to comment
banzai510(hainz) Posted November 19, 2023 Report Share Posted November 19, 2023 7 hours ago, Dusten said: mexico Hopefully better! Quote Link to comment
Dusten Posted November 19, 2023 Author Report Share Posted November 19, 2023 34 minutes ago, banzai510(hainz) said: Hopefully better! Hope so Just for fun Mike I measured my solenoid signal. 12.66 at battery and 12.58 at the solenoid 1 Quote Link to comment
Dusten Posted November 27, 2023 Author Report Share Posted November 27, 2023 For the life of me I can't figure out that starter. I cleaned mine up and it spins over awesome. Swap in the new starter that we teated before I brought it home and.... Nothing. Not even a click. Swap mine back in and zoom. Fuck it. Threw in a new reverse switch to hopefully stop my last trans leak. 1 Quote Link to comment
datzenmike Posted November 27, 2023 Report Share Posted November 27, 2023 The state of remanufactured alternators and starters is dismal. Just way too many are what's called 'bad in the box'. A dealer starter is a few hundred bucks so you get what you pay for. These are taken apart cleaned and some parts replaced but to make money the replaced parts are crap and beyond cheap. No wonder they are sold with free replacement. OOoo free!!! I'll have starters for life! So you're on your third starter when it dawns on you that you have paid over $200 in towing bills and once were stranded in the hood. You had to get a ride to work for the rest of the week and a trip in to order the 'free' starter and another trip in the next day to pick it up. You get to take the old one out and put the 'free' one in. Times three... you should be good at this by now. Just take it back and get another. What do you expect for $60? Quote Link to comment
Dusten Posted November 28, 2023 Author Report Share Posted November 28, 2023 On 11/26/2023 at 5:05 PM, datzenmike said: The state of remanufactured alternators and starters is dismal. Just way too many are what's called 'bad in the box'. A dealer starter is a few hundred bucks so you get what you pay for. These are taken apart cleaned and some parts replaced but to make money the replaced parts are crap and beyond cheap. No wonder they are sold with free replacement. OOoo free!!! I'll have starters for life! So you're on your third starter when it dawns on you that you have paid over $200 in towing bills and once were stranded in the hood. You had to get a ride to work for the rest of the week and a trip in to order the 'free' starter and another trip in the next day to pick it up. You get to take the old one out and put the 'free' one in. Times three... you should be good at this by now. Just take it back and get another. What do you expect for $60? Well 1 it was $120 not $60 And 2 i threw it in the shelf. I'm not taking it back. To much effort. 2 Quote Link to comment
Dusten Posted December 5, 2023 Author Report Share Posted December 5, 2023 Might be time to pull out the pressure washer on a dry day with a kid in the truck. Carpet was wet today after a particularly heavy rain fall. Time to figure out why Quote Link to comment
datzenmike Posted December 5, 2023 Report Share Posted December 5, 2023 Check the plenum below and in front of the windshield where the wiper linkages are. Pine needles, maple keys and small leaves get in there and can block the left and right side drains. Heavy rain can't drain and the level rises or swishes side to side driving and can over top the fresh air vent for the heater and the into the cab. Another source of wetness is the windshield gasket. Can even be at the top and run around the seal and leak out at the bottom near the dash. Rust can perforate the A pillar and run down the kick panel by the doors. 1 Quote Link to comment
