Jester Posted February 20, 2009 Report Share Posted February 20, 2009 (edited) Damn Klotz, Love the mirror. Hey, if you don't want Fisch, I'm up for adoption too.:D EDIT: Oh, BTW, I'm garage trained too. I only pee on the floor once in a while now. Only when I see shiney stuff come off the mill do I still loose control. Edited February 20, 2009 by Jester 2 Quote Link to comment
mklotz70 Posted February 20, 2009 Author Report Share Posted February 20, 2009 Thanks! LOL...you guys are funny. I'm still waiting for Driven, Datrod, and Bobmx3 to adopt me!!! :) I keep thinking, "Dang....if I fix a couple more things on the NL, I can sell it for enough to buy a full size mill :) ....of course I don't have the power in the shop to run it, so I'll stick with this one :) 1 Quote Link to comment
mklotz70 Posted February 21, 2009 Author Report Share Posted February 21, 2009 (edited) I actually got something done today too! :) I've been dieing to try the wrinkle black PC. My gun was giving me fits....which I'm sure was operator induced!! I was going to use caps on the mounting bolts, but since I decided to put it on the tray with AL foil.....I needed it to have the bolt ends bare.....then I could clip the ground to the foil instead of the box :) Anyway.......I love the wrinkle finish!!!! I kinda wish I'd done the front in it too. I didn't prep the inside very well, but I wasn't worried about how it came out at all...and I didn't spray much powder in there. The backside was WAY heavy on the powder...gun prob. The knob is just sitting there. I'll be able to put it all together soon :) Of course, I'll have to finish the interior before I mount this baby in there!! :( Edited February 21, 2009 by mklotz70 2 Quote Link to comment
510er Posted February 21, 2009 Report Share Posted February 21, 2009 wow Mike that krinkle finish looks awesome!. i noticed that sometimes with my PC gun if i give it a good shake before i start i get more consistent coverage... dont know why 1 Quote Link to comment
mklotz70 Posted February 21, 2009 Author Report Share Posted February 21, 2009 Thanks :) Normally, I hang the parts and the gun doesn't give me grief because I'm aiming up. This time, I was shooting down and it was dumping powder out. I got it adjusted a bit better toward the end, but I still had to aim it up. I've already got a couple of other parts in mind for this finish :) Man...I sure wish I had an oven big enough to do a whole dash board!!! 1 Quote Link to comment
fisch Posted February 21, 2009 Report Share Posted February 21, 2009 Thanks :)Man...I sure wish I had an oven big enough to do a whole dash board!!! Do what my uncle did Mike. I kid you not he took two crappy electric kitchen ovens, cut holes in their sides, built a metal tunnel between them, insulated that tunnel, viloa! I questioned whether it was colder in the tunnel, he said nope, the insulation distributes the heat pretty well and I think he uses an oven thermometer in the tunnel to make sure he is up to temp. You're freakin MacGyver after all, make one! BTW, this heater looks GREAT! Better be careful or this rig will outshine your NL! 1 Quote Link to comment
Creepy Cruiser Posted February 21, 2009 Report Share Posted February 21, 2009 (edited) We did something similar with an old pizza oven. Just took the elements and conltrols from an old free home oven and put them in the free pizza oven case. Worked killer and it was almost free. You can find that stuff all the time for free on CL, lol. I've also seen, (but never tried), surface heating with infrared heaters. They just move the heat along the surface (every 20 minutes after flow) and it seems to work. That's how guys are doing motorcycle frames and such at home. If you look around on the web, you'll see what I mean. One of these days, I want to try it just because, lol. Edited February 21, 2009 by Creepy Cruiser 1 Quote Link to comment
510er Posted February 21, 2009 Report Share Posted February 21, 2009 Mike i used a heat lamp and it worked pretty good, i left it on one side at about 10 inches for about an hour than i moved it to the other side and repeated... I was just playing around though to see if it would work so i didnt watch the clock as closely as i do when stuffs in the oven 1 Quote Link to comment
mklotz70 Posted February 21, 2009 Author Report Share Posted February 21, 2009 MacGyver....I loved that show!! :) Great ideas on the ovens! I've actually looked into it a bit and I can do it, I just don't have the room. I just may try the heat lamps.....they wouldn't take up any room when I was done. They'd heat up the garage nicely too :) I would need to run the fan because of the fumes. I think it would probably work fine on the dash....the thin sheet metal flows out really quickly!! Gee.....I've only got 3 or 4 dashes to play with....uumm...521's that is.... :) There's at least one 320 dash in the shed too. 1 Quote Link to comment
72240z Posted February 21, 2009 Report Share Posted February 21, 2009 Mike i used a heat lamp and it worked pretty good, i left it on one side at about 10 inches for about an hour than i moved it to the other side and repeated... I was just playing around though to see if it would work so i didnt watch the clock as closely as i do when stuffs in the oven Any result pics? 1 Quote Link to comment
mklotz70 Posted February 26, 2009 Author Report Share Posted February 26, 2009 Okay....so not everything turns out hunky-dorry around here :( I thought I'd try the Liquid 2 Powder fluid and see if I coudl PC the lettering. I should have went and read the instructions online again. Not only did I manage to burn the nice gloss black, but the letters were really spotty. I mixed by volume and it should have been by weight. Not sure if I'll try to fix this, do another front, or just PC over it with the wrinkle :) I was glass beading this to PC it...but I may just leave it :) 1 Quote Link to comment
]2eDeYe Posted February 26, 2009 Report Share Posted February 26, 2009 Polish it up to match the mirror housing :D Dig that krinkle 1 Quote Link to comment
mklotz70 Posted February 27, 2009 Author Report Share Posted February 27, 2009 that probably would fit the best. ...you and your d*mn polishing!!! Isn't this RATSUN??!!! :) 1 Quote Link to comment
]2eDeYe Posted February 27, 2009 Report Share Posted February 27, 2009 :D It's all these guys and their buffing out 40 year old paint jobs :lol: Really, I just got a thing for raw metal ;) 1 Quote Link to comment
bonvo Posted February 27, 2009 Report Share Posted February 27, 2009 sweeeet i want to learn to powdercoat :( 1 Quote Link to comment
510er Posted February 27, 2009 Report Share Posted February 27, 2009 BONVO! its easy man 50 dollar gun from harbor freight and free CL oven got me going :D 1 Quote Link to comment
Phlebmaster Posted February 28, 2009 Report Share Posted February 28, 2009 Nice work Mike! :D 1 Quote Link to comment
Jester Posted February 28, 2009 Report Share Posted February 28, 2009 Not sure if I'll try to fix this, do another front, or just PC over it with the wrinkle :) I vote for doing it again. That way you can learn to make it right the first time for future projects. 1 Quote Link to comment
watsonius Posted March 2, 2009 Report Share Posted March 2, 2009 My first post. I'm the other PO (Yellow Wheels is my wife). It is really satisfying and pretty amusing to see Mike dealing with all these things that annoyed me for years. I never wanted to tackle the heater box because I figured I would never get it back together, or that I would have to destroy it to get it out and apart. So I left it in the last position where it was stuck. Heat partly on all the time works pretty well in Seattle. Mike- have you looked at the fan motor yet? It must be pretty corroded too. I love the mirror mount- I presume it is the one I saved? The mirror just crumbled to the floor one day so I ended with that worthless stick-on job. More later- I have plenty of stories about "Mend". Brian 2 Quote Link to comment
Phlebmaster Posted March 2, 2009 Report Share Posted March 2, 2009 My first post. I'm the other PO (Yellow Wheels is my wife). It is really satisfying and pretty amusing to see Mike dealing with all these things that annoyed me for years. I never wanted to tackle the heater box because I figured I would never get it back together, or that I would have to destroy it to get it out and apart. So I left it in the last position where it was stuck. Heat partly on all the time works pretty well in Seattle. Mike- have you looked at the fan motor yet? It must be pretty corroded too.I love the mirror mount- I presume it is the one I saved? The mirror just crumbled to the floor one day so I ended with that worthless stick-on job. More later- I have plenty of stories about "Mend". Brian Welcome to Ratsun, we hope to see you around often. :D 1 Quote Link to comment
mklotz70 Posted March 3, 2009 Author Report Share Posted March 3, 2009 Hi Brian, Great to see you here!!! I've sold cars to guys that told me of all the plans they had for it....but I never got to see any of them again. :( I think it's really cool that you get to see this. I enjoy sharing it. Just wish I could get off my lazy rear and do more work on it!!! The fan motor wiped off nicely. I washed the fan. Ran just fine when I put some juice to it. It's above any of the fluid stuff and if the fan was running, it blew the moisture away before it got close to the motor. I'm looking forward to the stories!! :) 1 Quote Link to comment
72240z Posted March 3, 2009 Report Share Posted March 3, 2009 It's nice the PO gets to follow but also that it went to someone with talent. Its a gratifying combo for all parties. 1 Quote Link to comment
mklotz70 Posted March 3, 2009 Author Report Share Posted March 3, 2009 :) Thanks! ......you take paypal or do I need to send a money order? :) 1 Quote Link to comment
mklotz70 Posted March 9, 2009 Author Report Share Posted March 9, 2009 (edited) Not much of an update, but if I can keep up with small ones, I won't end up spending half a day trying to get caught up. So, I thought I'd see if the molasses was still doing it's thing. I made it up over a year and a half ago!!! Still seems to be working. I don't want to turn this into a molasses or rust removal thread.....there's a dedicated rust removal thread on here already if I remember right. Reminder of how they started...... Here's the nicer of the two after about 3 days in the molasses. The tub of mix still in the same spot. Every couple of days you want to pull the item out(easier with wire attached) and brush it to loosen the rust up...helps it get to more rust and work quicker. It's certainly not as fast as acid, but it's a ton safer!!!! I sprayed these off on the lawn with the hose. I'm gonna watch this screw and see if it will take enough off to loosen it up :) Edited March 9, 2009 by mklotz70 1 Quote Link to comment
Phlebmaster Posted March 9, 2009 Report Share Posted March 9, 2009 Wow! Mike, I never knew about the molasses thing. That works like a charm. Let Paula know that I will be there for pancakes in the morning. :D 1 Quote Link to comment
