six2ohyea Posted July 25, 2023 Author Report Share Posted July 25, 2023 Found these online : https://www.speedwaymotors.com/Aluminum-6-Pin-Wheel-Spacer,3443.html?sku=91658220-1%2F8&utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&gclid=Cj0KCQjwwvilBhCFARIsADvYi7JlBIR0NKhzcaknpk11JDuRe_0dQT_tvhgaR04g6DP6Sr-EL3_Dv6caAj-gEALw_wcB Quote Link to comment
banzai510(hainz) Posted July 25, 2023 Report Share Posted July 25, 2023 just make sure they the right spacing. Datsun was same as the General Motors wheels what ever that is with stock steel rim I think 1/4 spacer would work. Was hoping soemone else would chim in in this Quote Link to comment
six2ohyea Posted July 25, 2023 Author Report Share Posted July 25, 2023 Yeah hopefully someone else can chime in. @banzai510(hainz)i think you’re right. These might be the wrong bolt pattern. Quote Link to comment
Stoffregen Motorsports Posted July 25, 2023 Report Share Posted July 25, 2023 (edited) 15 hours ago, six2ohyea said: Found these online : https://www.speedwaymotors.com/Aluminum-6-Pin-Wheel-Spacer,3443.html?sku=91658220-1%2F8&utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&gclid=Cj0KCQjwwvilBhCFARIsADvYi7JlBIR0NKhzcaknpk11JDuRe_0dQT_tvhgaR04g6DP6Sr-EL3_Dv6caAj-gEALw_wcB Toyota, Datsun, Chevy are 6x5.5 - https://www.summitracing.com/search/part-type/wheel-spacers?N=wheel-bolt-pattern-application%3A6-x-139-70mm_6-x-5-1-2-in&PageSize=25&SortBy=DisplayPrice&SortOrder=Ascending&keyword=wheel spacers&kr=wheel spacers Edited July 25, 2023 by Stoffregen Motorsports 1 Quote Link to comment
six2ohyea Posted July 25, 2023 Author Report Share Posted July 25, 2023 Looks like the thinnest they have is 1/4” Quote Link to comment
banzai510(hainz) Posted July 25, 2023 Report Share Posted July 25, 2023 (edited) more than a 1/4inch youll might need longer studs I think the stock rim youll have enought engagement. stud should go thru the nut I used to run chrome early Pathfinder wheels. But went back to stock as I like the look better Edited July 25, 2023 by banzai510(hainz) Quote Link to comment
six2ohyea Posted July 25, 2023 Author Report Share Posted July 25, 2023 I was hoping to find 1/8. I don’t think i need that much clearance since i most likely won’t be in any car chases in this thing. But just ordered. I’m sure they will work out. I agree. I’ve thought about every wheel possible but I like the stock wheels the best. nice truck! Do you have a build page? Always liked the 520/521’s 1 Quote Link to comment
Crashtd420 Posted July 25, 2023 Report Share Posted July 25, 2023 2 minutes ago, six2ohyea said: I was hoping to find 1/8. I don’t think i need that much clearance since i most likely won’t be in any car chases in this thing. But just ordered. I’m sure they will work out. I agree. I’ve thought about every wheel possible but I like the stock wheels the best. nice truck! Do you have a build page? Always liked the 520/521’s I was gonna suggest marking the caliper and just clearancing the caliper alittle at the closest point to the wheel.... you shouldn't have to take to much off.... Not sure if that's a good idea or not, my guess would be you would wanna see where the material needs to be removed first... But you have spacers on the way ..... Quote Link to comment
Stoffregen Motorsports Posted July 25, 2023 Report Share Posted July 25, 2023 Clearancing the caliper is not hard. Usually a few hits with a flap wheel on a 4" grinder is all it takes. Don't go too far though. 1/4 spacers will probably require longer studs. I don't have extras laying around, but if you have a plasma shop in town, they can cut them out in no time. Where in the bay are you? I think I asked you before, but can't remember. Quote Link to comment
six2ohyea Posted July 25, 2023 Author Report Share Posted July 25, 2023 Damn.. didn’t read I needed longer studs. just canceled my order. what am I grinding away? The wheel or the caliper? I'm in East Bay. Oakland/Hayward area 1 Quote Link to comment
Crashtd420 Posted July 25, 2023 Report Share Posted July 25, 2023 1 hour ago, six2ohyea said: Damn.. didn’t read I needed longer studs. just canceled my order. what am I grinding away? The wheel or the caliper? I'm in East Bay. Oakland/Hayward area The caliper.... 1 Quote Link to comment
six2ohyea Posted July 26, 2023 Author Report Share Posted July 26, 2023 3mm should work? 1 Quote Link to comment
Stoffregen Motorsports Posted July 26, 2023 Report Share Posted July 26, 2023 4 minutes ago, six2ohyea said: 3mm should work? Perfect. The ones I found on SUmmit and Jegs were all cast, and those can crack. The ones you pictured look like good quality. 1 Quote Link to comment
iceman510 Posted July 26, 2023 Report Share Posted July 26, 2023 Hate those old cast versions. 1 Quote Link to comment
six2ohyea Posted July 26, 2023 Author Report Share Posted July 26, 2023 On 7/21/2023 at 12:55 PM, six2ohyea said: So I’m good? Lol messing with the torsion bars to help fix my crooked stance. Ended up reindexing my torsion bars. Looked like the the ends were hanging a little low. Quote Link to comment
six2ohyea Posted July 27, 2023 Author Report Share Posted July 27, 2023 Spacers came in. Seems like good quality. However didn’t give much clearance. Kind of hesitant about grinding calipers. 😅 Maybe I should wait to see if the appropriate year rims come along. Quote Link to comment
six2ohyea Posted July 27, 2023 Author Report Share Posted July 27, 2023 Thought the might have been after market brakes but look to be Nissan. 1 Quote Link to comment
EDM620 Posted July 28, 2023 Report Share Posted July 28, 2023 6 hours ago, six2ohyea said: Thought the might have been after market brakes but look to be Nissan. That is definately the Nissan logo there. Those spacers do look like good quality. Use something at hand to "fill" the space - kitchen scrubber or like - and tape it into the inside of the rim. Roll the rim and let the scrubber show you exactly where to grind. You won't need to do much, just reducing the high points. 2 Quote Link to comment
six2ohyea Posted August 1, 2023 Author Report Share Posted August 1, 2023 On 7/26/2023 at 12:40 PM, six2ohyea said: Ended up reindexing my torsion bars. Looked like the the ends were hanging a little low. I lowered the truck to allow the suspension to settle. Didn’t think it was going to drop this low. Did I reindex too much? I removed bump stops and 3 notches on the torsion bar. now do I lift back and tighten nuts to apply pressure on the torsion bars? 1 Quote Link to comment
shlammed Posted August 2, 2023 Report Share Posted August 2, 2023 looks great, just add a little camber, get going on your overs and lower the rear to match. Quote Link to comment
six2ohyea Posted August 2, 2023 Author Report Share Posted August 2, 2023 I’m at 2.5” in the front. How much do you think it will settle? 1 Quote Link to comment
datzenmike Posted August 2, 2023 Report Share Posted August 2, 2023 Only a matter of time till you hit something and wreck those fenders. Stuck out like that the body will get dirty from the tires slinging crap up. Seen lots of cars in the '70 with wide tires and a groove cut all the way round from rubbing. Quote Link to comment
six2ohyea Posted August 3, 2023 Author Report Share Posted August 3, 2023 1 hour ago, datzenmike said: Only a matter of time till you hit something and wreck those fenders. Stuck out like that the body will get dirty from the tires slinging crap up. Seen lots of cars in the '70 with wide tires and a groove cut all the way round from rubbing. I know. I’m ordering some 78-79 stock rims. These are temporary Quote Link to comment
EDM620 Posted August 3, 2023 Report Share Posted August 3, 2023 IMO the revised ride height is better, too low is useless unless you only drive around on pool tables and not real roads. Any body lean while cornering will have the fenders cutting into the rubber, nevermind speed bumps etc. Quote Link to comment
datzenmike Posted August 3, 2023 Report Share Posted August 3, 2023 1 hour ago, six2ohyea said: I know. I’m ordering some 78-79 stock rims. These are temporary Phew! As you go lower increase the spring rate. It will reduce suspension travel and the potential to bottom out. Leaf springs are easy, torsion bar choices are limited. Some good HD shocks also. Quote Link to comment
