six2ohyea Posted August 3, 2023 Author Report Share Posted August 3, 2023 19 minutes ago, EDM620 said: IMO the revised ride height is better, too low is useless unless you only drive around on pool tables and not real roads. Any body lean while cornering will have the fenders cutting into the rubber, nevermind speed bumps etc. You think 2-2.5” is good? Quote Link to comment
six2ohyea Posted August 3, 2023 Author Report Share Posted August 3, 2023 1 hour ago, datzenmike said: Phew! As you go lower increase the spring rate. It will reduce suspension travel and the potential to bottom out. Leaf springs are easy, torsion bar choices are limited. Some good HD shocks also. …. How do you increase spring rate? 😅 also any recommendations on HD shocks? Quote Link to comment
datzenmike Posted August 3, 2023 Report Share Posted August 3, 2023 You can change the springs or add a leaf. 720 4x4 springs are not only stiffer but they also have less arch which will also lower. Torsion bars options are very limited. Quote Link to comment
six2ohyea Posted August 3, 2023 Author Report Share Posted August 3, 2023 (edited) 5 hours ago, datzenmike said: You can change the springs or add a leaf. 720 4x4 springs are not only stiffer but they also have less arch which will also lower. Torsion bars options are very limited. Interesting… stock or aftermarket leaf springs? And what years of 720? Edited August 3, 2023 by six2ohyea Quote Link to comment
EDM620 Posted August 3, 2023 Report Share Posted August 3, 2023 11 hours ago, six2ohyea said: You think 2-2.5” is good? Yes, depending on what the roads you are likely to travel on regularly. 1 Quote Link to comment
six2ohyea Posted August 3, 2023 Author Report Share Posted August 3, 2023 Found a gas leak.. 😐 IMG_8789.mov Quote Link to comment
banzai510(hainz) Posted August 3, 2023 Report Share Posted August 3, 2023 (edited) I think a gasket rebuild kit will have that for a stock carb if still made You getting stock rims!!!!!!!!!!thats great sell those one you have. I never got the rims past the fender look. But those tires still have lots of life left. Hate to so them go. but they just not right for the truck in my opinion. I think stock rims and stock type tires youll be fine with the ride height you got. I try not to hit huge bumps at 50mph. If theres a sign and says road contruction then slow down. I would have onley went one tooth on the torsion bar then use the anchor bolt threads to a drivable desired height As for the torsion bar. They made a stronger one sold thru motorsport. But havent bought from them in years if they still have any. Lowereing a truck down on torsion I dont think it stiffens anything it just reposition the clocking of the bar thats it. Edited August 3, 2023 by banzai510(hainz) Quote Link to comment
six2ohyea Posted August 3, 2023 Author Report Share Posted August 3, 2023 1 hour ago, banzai510(hainz) said: I think a gasket rebuild kit will have that for a stock carb if still made You getting stock rims!!!!!!!!!!thats great sell those one you have. I never got the rims past the fender look. I think stock rims and stock type tires youll be fine with the ride height you got. I try not to hit huge bumps at 50mph. If theres a sign and road contruction then slow down. As for the torsion bar. They made a stronger one sold thru motorsport. But havent bought from them in years if they still have any. Lowereing a truck down on torsion I dont think it stiffens anything it just reposition the clocking of the bar thats it. I’ll have to look into the carb rebuild kit. Yeah I messed up when ordering these wheels and back spacing. Really don’t want to cut and add fenders. However finding the later stock rims have been challenging. Cause they only made them for years 78-79. The ride height settled way more than I thought. I’m now at ~1” in front. Have to readjust 🫠 do you know if the torsion bar affects Camber? Quote Link to comment
six2ohyea Posted August 4, 2023 Author Report Share Posted August 4, 2023 (edited) Anyone have experience with autozone carb kit or rock auto? Edited August 4, 2023 by six2ohyea Quote Link to comment
Crashtd420 Posted August 4, 2023 Report Share Posted August 4, 2023 Does it need a rebuild? Looks like it's missing a bolt at the bottom on that front cover.... 2 Quote Link to comment
Crashtd420 Posted August 4, 2023 Report Share Posted August 4, 2023 14 hours ago, six2ohyea said: do you know if the torsion bar affects Camber? Yes adjusting the torsion bars up or down will affect the camber.... Quote Link to comment
datzenmike Posted August 4, 2023 Report Share Posted August 4, 2023 14 hours ago, six2ohyea said: Nice stance and ride height but not with those tires and rims. I like the raked look. You could even go lower on the back to match the front if you don't plan carrying heavy loads. All years of 720 had a 4x4 option. Quote Link to comment
banzai510(hainz) Posted August 4, 2023 Report Share Posted August 4, 2023 45 minutes ago, Crashtd420 said: it's missing a bolt at the bottom on that front cover.... good catch maybe all that is needed. Dont rebild it if you dont have to. To me a stock carb is a Jack in the box waiting to explode. I just go to Weber DGV but the stock carbs are nice and quiet and smooth if still good. stock rims from any Datsun truck will fit that I know of. 1970 Datsun 521 on up Quote Link to comment
six2ohyea Posted August 4, 2023 Author Report Share Posted August 4, 2023 7 hours ago, datzenmike said: Nice stance and ride height but not with those tires and rims. I like the raked look. You could even go lower on the back to match the front if you don't plan carrying heavy loads. All years of 720 had a 4x4 option. Yea just got 2/4 of the stock rims I’ll be powder coating and swapping out. I like the rake also. I’m thinking about lowering it more in he back. It’s def going to be used for house projects not necessarily a work truck. also found this truck at pick n pull but it’s 2 hours away. Thinking about picking the leaf springs. Not sure if I’ll have the time. 1 Quote Link to comment
six2ohyea Posted August 4, 2023 Author Report Share Posted August 4, 2023 6 hours ago, banzai510(hainz) said: good catch maybe all that is needed. Dont rebild it if you dont have to. To me a stock carb is a Jack in the box waiting to explode. I just go to Weber DGV but the stock carbs are nice and quiet and smooth if still good. stock rims from any Datsun truck will fit that I know of. 1970 Datsun 521 on up Have to pass smog unfortunately. Not sure if I can with a Weber. now trying to find a screw that fits will be challenging. Wonder if I can just buy a used carb off someone. Unfortunately the older stock rims don’t fit because I have disk brakes. I have a set that hit my calipers. Just bought 2 of the 620 78-79’ stock rims that are wider. left is newer and right is older 1 Quote Link to comment
six2ohyea Posted August 5, 2023 Author Report Share Posted August 5, 2023 Leaking stopped. also getting the headliner installed 2 Quote Link to comment
six2ohyea Posted August 5, 2023 Author Report Share Posted August 5, 2023 Headliner in! Looks way better! before: after: 2 Quote Link to comment
six2ohyea Posted August 5, 2023 Author Report Share Posted August 5, 2023 Also got a great deal on a Datsun Competition steering wheel replica. As much as I liked the look of the original steering wheel. This one is smaller and feels better. 3 Quote Link to comment
six2ohyea Posted August 5, 2023 Author Report Share Posted August 5, 2023 Way better clearance with the newer stock rims. 2 Quote Link to comment
banzai510(hainz) Posted August 6, 2023 Report Share Posted August 6, 2023 make sure you get all the same rims . I dont know if all years had the same 3 pop up things for the hubcaps to fit 1 Quote Link to comment
six2ohyea Posted August 8, 2023 Author Report Share Posted August 8, 2023 Bought a service manual book to try and find where these tubing/lines go. No info unfortunately. 🫠 anyone know? Quote Link to comment
datzenmike Posted August 8, 2023 Report Share Posted August 8, 2023 I advise watching for an actual FSM (factor service manual) from Nissan. That Haynes is not even 1/2" thick and covers all 7 years (very poorly) and that includes the supplement in the back for the '78-'79. The FSM is almost 2" thick and covers only and all aspects of the '78 620 including the emissions and vacuum lines. Every year had differences and up grades and then there was the over all differences between California emissions and everywhere else. Both connect to the altitude compensator inside the air filter housing and connect to the top front of the Californian carburetor. The stretched hose from the snorkel goes to the underside and up into the air temperature sensor. The hose you are holding comes from the sensor and through the small hose down to a vacuum supply fitting on the intake. The other part of that Y metal tube without a hose goes to the charcoal canister. The remaining hose goes to the fuel shut off control valve on the driver's inner fender. I think. 2 Quote Link to comment
metalmonkey47 Posted August 8, 2023 Report Share Posted August 8, 2023 This project is coming along nicely 🤠 1 Quote Link to comment
DARIN 510 Posted August 9, 2023 Report Share Posted August 9, 2023 On 8/5/2023 at 1:53 PM, six2ohyea said: Also got a great deal on a Datsun Competition steering wheel replica. As much as I liked the look of the original steering wheel. This one is smaller and feels better. How much? And where did you find it? I see them on eBay all the time for around $400-$500. Quote Link to comment
