I 'also' scored a 510 wagon!!! :)
71DIMER
  • Replies 203
I also got around to cleaning the door/hatch jambs and door parts.
I used simple green to get the crud off, then steel wooled it to get the rough patches and put a little wax on it...still will redo it all once the weather clears up.
Left side is cleaned up, right side is grubby
Right side is cleaned & waxed, left is still grubby
Right side has been steel wooled, left side only simple greened.
Both sides simple greened and steel wooled.
Old rusty screws were replaced with new ones.
Strips that hold the door panels were removed and sanded
Strips painted
All this crap was in my doors....leaves and the lining from the door...yuck!
Edited by 71DIMER
  • 1 month later...
Just a small update. Finally got around to cleaning up my carbs, linkage, air cleaner assembly, and got a year correct valve cover. :)
Before:
Now:
  • 3 months later...
It's been awhile since my last post but I got a new set of wheels last week, check it out...:)
Here's my goon with the Watanabes
Time to swap :)
Nice work on this! Man how did all those leaves get in there? I've heard of going 'green' with automobiles, but making a compost pile in the door is taking it to the extreme!:lol::lol:
Thanks guys...yeah I know still debating to go with vw or mr2 inserts with my lowering springs...decisions decisions.:P
Edited by 71DIMER
Ratsun Mechanic at work
One is a Aeronautical Engineer in Mehico and the other a Junk Yard guru.
Neither one can figure out negative and positive.
So had to help them, red is ground and black is positive.
How's the car running now Mario?
Edited by pl521sss
er
Hahaha...man if they trust me working on satellites, you'd think you wouldn't have to check my battery connections...LOL...but hey it's all good....trust but verify is a good motto. It's running good just need to fine tune it as I heard some pinging (rattle can sound) on the highway when I stepped on the gas...timing must be a bit retarded so I have to advance it a bit. Too bad I don't have a timing gun to just do it right from the get go. Thanks for helping out...and we'll hit the rest up sometime soon.
P.S. it's aerospace engineer man...get it right or I'll be forced to show the 'begging on the knees' picture! :P
Thanks Mklotz, swapped in an electric distributor today with help of Hector (thatsoon510) and Abraham (PL521sss).
Also added some cool arm rests to my goon...its top flips up and it forms a pocket with the door panel when installed.
Edited by 71DIMER
Jeez! My wheel arches used to look like that?! Weird! Right now they look like someone hit them with a hammer to widen them out... I need to learn how to smooth them out, now..
The 'Goon is looking bitchin, man! Gotta bring IT to a meet one of these days! But I can't get tired of looking at the sedan...
Hey Sean, I would but I just upgraded my ignition (EI dizzy) to *hopefully* fix the stumbling/cutting issue when I drive it. It seems to misfire and I've tried changing plugs/wires/dist cap/rotor/fuel filter etx and it still did it. I just swapped the EI dizzy in today so I'll try driving her around to see if it's still doing the same thing. I barely felt comfortable driving it 20 miles from my place over to PL521SSS but it made it there and back like a champ. :)
We'll see if I can make it out to Sac...we're having our local meet this coming Thursday so I'll hope to see lots of guys there and if possible make it out to Sac's. If I go I'll be looking for some shortened strut assemblies and/or shorter struts since according to PL521SSS my strut assemblies are not stock 68 ones...they're 11.5" tall while the stock 68 ones should be 10" tall (he has some so we measured). So it's sitting really tall...yuck.
It's 10.5
Convince Hector to give you those MR2 inserts
  • 4 months later...
Ok time to resurrect this thread since I haven't updated it a while. I've made more progress with the old tired interior.
Before: Old nasty carpet that came with it.
After Carpet: New and clean (well still needs a vacuum)
Seats Before: These came with the wagon and while they were headress-less like true 1968 Datsun seats, they weren't stock and sat higher due to the little feet it had on them. Sold them on CL, only to find out later they were actualy from a old school Camaro/Firebird and worth some $$$...oh well.
Seats After: Got these from a local guy with a old man golfer upholstery :P
After Ratsunizing them:
Before: Original blue door panels and rear seat were pretty thrashed
After: Replaced all 7 busted door panels and seats with black ones
Before: Cargo (yuck)
After: Cargo After cleaning up and slapping in the newer panels and carpet:
Surprise find inside one of the cargo panels: Set of tire chains! This goon was supposed to take on the snow? :P
