Skib Posted May 24, 2022 Report Share Posted May 24, 2022 Shenaniganas are afoot........ lets get the body started... there.... are so many hours ahead of me. 😑 fitting the G-nose headlight buckets flush to the fenders... 8 Quote Link to comment
Tank. Posted May 25, 2022 Report Share Posted May 25, 2022 Awesome! I love my vq swap, it’s soooo much fun to drive. Quote Link to comment
Lockleaf Posted May 26, 2022 Report Share Posted May 26, 2022 Very cool. Those VQs look hilarious in those engine bays. Like there's 3 feet of empty space to the rad. Looks like an it makes it a legit mid engine though. Gotta be a great base for hooning. Quote Link to comment
Aaron Datsun Posted May 26, 2022 Report Share Posted May 26, 2022 This looks very fun! Going to be happy to follow along. Quote Link to comment
Skib Posted May 26, 2022 Author Report Share Posted May 26, 2022 36 minutes ago, BrothersGarage said: GNose ❤️ Its actually an OEM fairlady nose, not a repop. just putting lots of hours into fenders atm... the corner was torn and partly missing all together, someone just jammed a bunch of body filler in there. so naturally it was crumbling off. bent up a tiny little patch to remake the corner. and a bit of stud repair on the G nose headlight bucket 3 Quote Link to comment
Icehouse Posted May 26, 2022 Report Share Posted May 26, 2022 To save some time on fit up, you should just give me the ZG nose 🙂 Quote Link to comment
Skib Posted May 27, 2022 Author Report Share Posted May 27, 2022 19 hours ago, Icehouse said: To save some time on fit up, you should just give me the ZG nose 🙂 Here is some comparison between the oem and the repop. The bumper is actually that same sort of foam over metal material like the GTO judge or firebird noses are made from. 3 Quote Link to comment
Skib Posted June 4, 2022 Author Report Share Posted June 4, 2022 fixin some door shit door and g-nose headlight buckets all repaired. the entire underside of the hood was paint cracked affecting it all the way down to bare metal. so it needed to be stripped and cleaned to bare metal. chemically stripping coming alone pretty decent ... 5 Quote Link to comment
Skib Posted June 7, 2022 Author Report Share Posted June 7, 2022 Lots of fitting and re fitting lol parts go on, they come off... they go on lol Also got some brand new tail lights in for later 3 Quote Link to comment
Skib Posted June 10, 2022 Author Report Share Posted June 10, 2022 Body work isn't that exciting, but its progress. Be shooting some color for jambs soon. 4 Quote Link to comment
Skib Posted July 11, 2022 Author Report Share Posted July 11, 2022 Finally got a squirt of color.... Hopefully get some of the same in the next day or two for the doors and door jambs. 3 Quote Link to comment
Skib Posted July 12, 2022 Author Report Share Posted July 12, 2022 Bit more color down. Its well over 100 every day here so I have to wait for evening to shoot, with the hour flash time before I could clear it I had to shoot clear under work lights lol 2 Quote Link to comment
Soundline Posted July 12, 2022 Report Share Posted July 12, 2022 First, the car looks super rad. Your body work is really great. I have a question though, what did you do to address the rust inside the door? Did you coat it with a rust covering product before paint? Quote Link to comment
Skib Posted July 13, 2022 Author Report Share Posted July 13, 2022 6 hours ago, Soundline said: I have a question though, what did you do to address the rust inside the door? Did you coat it with a rust covering product before paint? Good question 👍 So the rot is threw the outer skin, and the inner area was just surface rust. So I cleaned it with a wire wheel and by hand, try to get as much to bare metal as I can. Then treated it with a rust neutralizer, coated in a metal etch primer and then a sealer. The back sides of all the patch panels where coated in a metal etch primer before welding then I coat them in a sealer after as well. Actually, If you look at the first post you can see the same thing with the patch of the fender. That green behind the cut out rust is where it was rusted behind; treated and sealed with a metal etch. 2 Quote Link to comment
Skib Posted July 16, 2022 Author Report Share Posted July 16, 2022 Few things actually going back together.... 4 Quote Link to comment
Skib Posted August 4, 2022 Author Report Share Posted August 4, 2022 And a bit more jambing and going together. 5 Quote Link to comment
Skib Posted August 12, 2022 Author Report Share Posted August 12, 2022 Body work isnt fun, but its nice when its done lol both hatch hinge mounts where about to rip out but its nice in color, fresh rubber and some new hardware 1 Quote Link to comment
ShutterMeShort Posted August 12, 2022 Report Share Posted August 12, 2022 *drool* Nice body work! I'm excited to see the end product! VQ in a Z has got to be a serious blast! Quote Link to comment
Skib Posted August 15, 2022 Author Report Share Posted August 15, 2022 Its in triple digit temps for weeks on end, with a lot of it being anywhere from 104-115. So there's lots of evening and night time sanding lol 3 Quote Link to comment
Skib Posted August 15, 2022 Author Report Share Posted August 15, 2022 This sorta bullshit real fucks with my ability to get things done around here. Quote Link to comment
Ooph! Posted August 15, 2022 Report Share Posted August 15, 2022 (edited) 50 minutes ago, Skib said: This sorta bullshit real fucks with my ability to get things done around here. I live in the Fog belt on the coast, friends in Lincoln / Rocklin say I should move there but I've been there in the summer house sitting for them and had to douse myself with the hose just to make it across the yard. Its 72 here this afternoon. Edited August 15, 2022 by Ooph! Quote Link to comment
Skib Posted August 15, 2022 Author Report Share Posted August 15, 2022 23 minutes ago, Ooph! said: I live in the Fog belt on the coast, friends in Lincoln / Rocklin say I should move there but I've been there in the summer house sitting for them and had to douse myself with the hose just to make it across the yard. Its 72 here this afternoon. Stepping outside the garage mid day here like.... 2 4 Quote Link to comment
Skib Posted August 19, 2022 Author Report Share Posted August 19, 2022 Got the hatch and last of the smaller parts a jambed up, and getting weather stripping in. 2 Quote Link to comment
obrut Posted August 19, 2022 Report Share Posted August 19, 2022 nice job, I can't wait to see it painted in that color. Quote Link to comment
