Japrnoo 98 Posted July 20, 2019 Author Report Share Posted July 20, 2019 (edited) Hi guys. It's been a while, i'm sorry for a lack of posts here. (If you wanna see the progress real time check my instagram @japrnoo !) So whats been up? I finally got the front coilovers, they are ground control coils with Koni race shocks. On the same deal i got DPracing aluminium hubs, they are great because they got the centers for discs machined to the hub! Today I installed new bearings on them and APracing 267mm disc + they got ARP wheel studs. Now I just need to find the center washer and nut to install the hub. I'm sorry Banzai but this is the way that this car is going now, sneak peak of the +55mm fender flares that i got. I will show how they fit when they are fully installed. Installed the Ground control coilovers the "right way" (these are upsidedown coilovers) the assembly was a bit of a trick to make but managed to do it myself! Sorry for the crappy phone pics, forgot my camera to home couple times. First my friend made me new upper ends, these are made from aluminium with 10mm thread on top and 14mm on bottom for the strut. Then I made 20mm thick Nylon bushing on it. So when trying to install the coilovers the bottom end didn't fit on the control arm sleeve, the spring was also hittig the wheelwell if you forced the bottom end to fit on the control arm. I cutted the original rear shoc mounting point off. Then I made 10mm thread inside the rear control arm, now the problem was that the strut is too close to control arm. When the strut didn't fit on it's place i made 6mm thick sleeve on the control arm and welded it on. After this the rear strut fitted on it's place as wanted My summer vacation starts in the week, my plan is to get the car on it's wheel and fit the flares + possibly there is some changes coming on the roll cage. I will post more stuff soon! Edited July 20, 2019 by Japrnoo 1 Quote Link to post
banzai510(hainz) 4,719 Posted July 21, 2019 Report Share Posted July 21, 2019 I say NOOOOOOO on the flairs!!!!that car is too straight. Your going to cut the car Quote Link to post
datzenmike 38,471 Posted July 21, 2019 Report Share Posted July 21, 2019 10 hours ago, Japrnoo said: Installed the Ground control coilovers the "right way" (these are upsidedown coilovers) the assembly was a bit of a trick to make but managed to do it myself! Sorry for the crappy phone pics, forgot my camera to home couple times. Won't the compression rate be traded for the expansion rate by turning them upside down????? Expansion is usually stiffer than compression. What about the valving inside. If at the top now any bubbles will cause a loss of hydraulic damping. Quote Link to post
thisismatt 8,305 Posted July 21, 2019 Report Share Posted July 21, 2019 28 minutes ago, datzenmike said: Won't the compression rate be traded for the expansion rate by turning them upside down????? Expansion is usually stiffer than compression. What about the valving inside. If at the top now any bubbles will cause a loss of hydraulic damping. Mike...it's still compression no matter which way you face them. Quote Link to post
datzenmike 38,471 Posted July 21, 2019 Report Share Posted July 21, 2019 Ha ha.... yes, sort of. The rates are different usually for compression and rebound. Usually rebound is firmer. On the front shocks on the 620 it's twice as much. Quote Link to post
thisismatt 8,305 Posted July 21, 2019 Report Share Posted July 21, 2019 28 minutes ago, datzenmike said: Ha ha.... yes, sort of. The rates are different usually for compression and rebound. Usually rebound is firmer. On the front shocks on the 620 it's twice as much. Yeah, but I'm saying compression is compression, it doesn't matter which way the shock is flipped, it's still being compressed on bump and decompressed on droop, so the valving continues to work correctly. 1 Quote Link to post
datzenmike 38,471 Posted July 21, 2019 Report Share Posted July 21, 2019 AHHHhhh the light just went on. Thanks Matt. Quote Link to post
Japrnoo 98 Posted July 22, 2019 Author Report Share Posted July 22, 2019 Hi! Yeah I got the idea to flip them by reading this guys project topic on 510 realm(?) http://www.speedhunters.com/2016/09/datsun-time-attacker-gm-ecotec-power/ If i remember right he said something like ”they suck when they are upside down but when you flip them over they work better” Quote Link to post
Ranman72 4,278 Posted July 22, 2019 Report Share Posted July 22, 2019 On 7/20/2019 at 6:51 PM, banzai510(hainz) said: I say NOOOOOOO on the flairs!!!!that car is too straight. Your going to cut the car its a 4 door and a race car now so cut it up for flares just my opinion and dont get me wrong I love stock body lines and hate flares but this is a race car now so flare away Quote Link to post
Japrnoo 98 Posted August 16, 2019 Author Report Share Posted August 16, 2019 Couple photos, sorry flare haters. rear flares need massive modification, will post pictures when its ready. 1 Quote Link to post
Atomic 542 Posted August 16, 2019 Report Share Posted August 16, 2019 Could the flares be lower? Or how would that look? Or are we looking for longer suspension travel? The stance would be nice to see with flares lower Quote Link to post
banzai510(hainz) 4,719 Posted August 16, 2019 Report Share Posted August 16, 2019 don't look right Quote Link to post
datzenmike 38,471 Posted August 16, 2019 Report Share Posted August 16, 2019 Never cared for 510 flairs of any kind. At the moment those FU the super sonic line. Four door are really hard to do. Quote Link to post
Japrnoo 98 Posted August 18, 2019 Author Report Share Posted August 18, 2019 On 8/16/2019 at 4:29 PM, Atomic said: Could the flares be lower? Or how would that look? Or are we looking for longer suspension travel? The stance would be nice to see with flares lower This is a strong maybe, where the car sits now theres 10cm from the rear subframe to ground and 45mm from tire to fender. This is first racer for me so cant be sure is that 45mm enough suspension travel or not. On front theres 65mm from tire to fender but fronts need to turn. Atleast the stance looks good in my opinion but lets see what happens when i get to drive this thing. On 8/16/2019 at 5:19 PM, datzenmike said: Never cared for 510 flairs of any kind. At the moment those FU the super sonic line. Four door are really hard to do. Yes the car being four door caused extra trouble, hopefully the end result is good when we get this done. Quote Link to post
datzenmike 38,471 Posted August 18, 2019 Report Share Posted August 18, 2019 I assume the tires will hit the fenders on extreme suspension travel? With proper rims 8" tires will fit a 510. Nine inch is the absolute limit. Quote Link to post
Japrnoo 98 Posted August 18, 2019 Author Report Share Posted August 18, 2019 1 hour ago, datzenmike said: I assume the tires will hit the fenders on extreme suspension travel? With proper rims 8" tires will fit a 510. Nine inch is the absolute limit. These are 235/45/13 so they are 9,25" tires and I'm going to go with 240mm wide slicks in the future. Quote Link to post
datzenmike 38,471 Posted August 18, 2019 Report Share Posted August 18, 2019 Holy crap! Quote Link to post
Japrnoo 98 Posted August 20, 2019 Author Report Share Posted August 20, 2019 Yeah, i didn't want to go with the flares at the first point but fitting these tires into stock body with that ride height was hopeless. 1 Quote Link to post
BrothersGarage 2,766 Posted August 20, 2019 Report Share Posted August 20, 2019 I'm cool with the flares, and totally looks like you're going to need them in the back! 😄 Only thing I would mention is it looks like the front flare sits like 1" above the line in the front fender panel, while the rear mock-up appears to sit flush with it. I would consider mounting them both at the same height unless you're going to give the car a bit of a 'raked' stance. Quote Link to post
Japrnoo 98 Posted August 20, 2019 Author Report Share Posted August 20, 2019 6 minutes ago, BrothersGarage said: I'm cool with the flares, and totally looks like you're going to need them in the back! 😄 Only thing I would mention is it looks like the front flare sits like 1" above the line in the front fender panel, while the rear mock-up appears to sit flush with it. I would consider mounting them both at the same height unless you're going to give the car a bit of a 'raked' stance. That was my first idea but assembling them more down could have caused tire to hit the flare when wheels are fully turned in speed. Also in the original BRE race car the rears are flush and the front comes a bit over the the line. 1 Quote Link to post
Japrnoo 98 Posted October 5, 2019 Author Report Share Posted October 5, 2019 I'm not dead ! It's been quiet from my side for past two months but progress have been happening. Fitting the flares to the car is a big project but hopefully we will get the left side ready this saturday so I can share it with you guys! During the time I have made a transmission holder ( actually V1, V1,5) and V2 is now under progress. Will share photos of it on the weekend too! Some stuff for the engine arrived today and my new wheels will arrive in three weeks! Same volk rays mesh that i got now but 13" ! I need to get the crank balanced and then we can build the block! I'm doing the V1 engine with wet sump instead of drysump for two reasons. -Our teams other car got the same setup and it has been running good for the last two years so why it would not work on my engine? -Good wet sump system cost like 700euros compared to good drysump system which is 5000euro + I have bought all the fuel equipment (tanks,pumps, filters, fuel lines and AN fittings) ready so when we get the rear flare installation ready I will start to fit the fuel equipment and do small fitting stuff because soon it's time to move to new carage so dont want to start any other big project before it! Plan is to get the car to the paint shop next summer. Let's hope that i dont have anymore ideas that will ruin that plan hah! This time it was more text than photos but here's one photo from last Thursday when I modified the rear subframe to fit my new 2.5" exhaust. 1 Quote Link to post
Japrnoo 98 Posted October 12, 2019 Author Report Share Posted October 12, 2019 Hello! Idea of just fitting flares to four door escalated pretty badly, thanks to my friend who made 90% of these. So the body, door and wheelwell was modified to make those flares fit with fully functionable rear door. I think that these came out great, i have anyone else fitting flares to four door like this. It was maybe too much work for just a track day build but these are something to show in the car shows too. I will post photos how they look like when the car is on it's wheel next week when i get new parts to the rear axle. Till next week! -Jarno 1 Quote Link to post
thisismatt 8,305 Posted October 12, 2019 Report Share Posted October 12, 2019 Nice job. I've seen a couple/few done that way. If you've never used anti-splatter spray when MIG welding you should try it :) Quote Link to post
BrandonS 156 Posted October 19, 2019 Report Share Posted October 19, 2019 Those came out great! 1 Quote Link to post
Japrnoo 98 Posted March 1, 2020 Author Report Share Posted March 1, 2020 Hi! Life has been busy for a while so I have totally forgot to keep this topic posted ! Lately I've got new job, new garage last Friday and lots of another stuff has kept me busy but I've had some time to work with the 510 also ! Here's couple of Iphone pictures how to car looks like at the moment. I will post up better introduction about last 5months in couple of weeks when we get the renevation of the new garage done ! 1 Quote Link to post
