crew521 Posted July 23, 2016 Author Report Share Posted July 23, 2016 Finnied all link welds 1 Quote Link to comment
crew521 Posted July 23, 2016 Author Report Share Posted July 23, 2016 Platted inside and out both ends of frame 1 Quote Link to comment
crew521 Posted July 23, 2016 Author Report Share Posted July 23, 2016 gonna rock 3 mounts per side...strecthed total of 41.75 between front cabs rear mount and the rear cabs rear mount skipping the rear cab front mount all together 2 Quote Link to comment
crew521 Posted July 23, 2016 Author Report Share Posted July 23, 2016 Mounted fuel keg and compressor tank and battery all easy pull off stud status...ill postbthat mount work when i take pic of stuff off it.. only 1 wrench needed sucks when something is low and u gotta use 2 wrenches 1 Quote Link to comment
Lockleaf Posted July 23, 2016 Report Share Posted July 23, 2016 So you are pushing about 140" wheelbase now? Nice. Its coming together fast! 1 Quote Link to comment
crew521 Posted July 23, 2016 Author Report Share Posted July 23, 2016 Thanks yes rite at that buddy...like i said first post this will be at its first show on aug 20th ..lol busting my butt to make it happen;) so how do i get this out for more people to see?? this the 1st forum ive ever posted on..figured id show people how i role lol 1 Quote Link to comment
izzo Posted July 23, 2016 Report Share Posted July 23, 2016 well that escalated quickly . 1 Quote Link to comment
Charlie69 Posted July 23, 2016 Report Share Posted July 23, 2016 Just curious as to how many center support bearings are you planning on the drive line? Quote Link to comment
Datsunthug Posted July 23, 2016 Report Share Posted July 23, 2016 crew521. Keep up thus project. Looking bad ass 1 Quote Link to comment
crew521 Posted July 23, 2016 Author Report Share Posted July 23, 2016 1 for now 1 Quote Link to comment
crew521 Posted July 23, 2016 Author Report Share Posted July 23, 2016 Thanks guys enjoying it every second cant wait for finsihed result...strait hand built line 4 now at this 1st show then revize to a 2 peice line soon after for 2nd run:) think about crew cab mega cab cummins they have a 1 peice often built insted of 2 piece so we will see all my angle are dialed 1 Quote Link to comment
Stoffregen Motorsports Posted July 24, 2016 Report Share Posted July 24, 2016 This is cool. Honestly though, I would plate those frame extension joints a bit more than you did. I would overlap the joint by at least the width of the tubing. In other words, if it's a 2x3 rectangular steel frame rail, go 3 inches on both sides of the welded joint, and taper the joint to disperse the shear loading. I'm really curious how your going to finish the roof. That's going to be massive. 1 Quote Link to comment
crew521 Posted July 24, 2016 Author Report Share Posted July 24, 2016 Its sliped inside by 3.5 inches on both ends and welded the plated in and out ...roof prb never lol... 2 Quote Link to comment
Stoffregen Motorsports Posted July 24, 2016 Report Share Posted July 24, 2016 You could get a roof off a large SUV and section it. I did a bunch of metal work on a FJ45LV Toyota a couple years ago, and the roof panel, from the factory, was made out of 9 different pieces, all welded together. Or, using original 521 pieces, and a little added along the top of the doors, make a soft top like on a 32 Ford Tudor. 1 Quote Link to comment
crew521 Posted July 28, 2016 Author Report Share Posted July 28, 2016 Morning guys here ya go..core suport drop flip frame..front lower arms now have adjustable links paint and brake fuel and air lones works under her own air...now cab on and body drop wire and make her run and drive by August 20th..no prob lol o and start a new job after 11 years of the old one quite last week now heading to a big toyota deal in my home toen as a parys guy there.... 2 Quote Link to comment
Stoffregen Motorsports Posted July 28, 2016 Report Share Posted July 28, 2016 Low. Love it. 1 Quote Link to comment
Stoffregen Motorsports Posted July 28, 2016 Report Share Posted July 28, 2016 Anybody else seeing what I'm seeing? 2 Quote Link to comment
uberkevin Posted July 28, 2016 Report Share Posted July 28, 2016 If you mean drum brakes all the way around yes.. 1 Quote Link to comment
bilzbobaggins Posted July 28, 2016 Report Share Posted July 28, 2016 Single plate on the front crossmember drop where the torsion bars hook up? 3 Quote Link to comment
Stoffregen Motorsports Posted July 28, 2016 Report Share Posted July 28, 2016 Single plate on the front crossmember drop where the torsion bars hook up? Right. No triangulation there. Considering this monster has the weight of a V8 to carry, I would add some strength there. 1 Quote Link to comment
