Lockleaf Posted February 19, 2016 Report Share Posted February 19, 2016 Look up lowering block shims, or go read through justjoels build thread, he discusses and builds angled blocks 1 Quote Link to comment
Anderson521 Posted February 20, 2016 Author Report Share Posted February 20, 2016 I'm beginning to really see the previous problems with the gears breaking being seriously attributed to the pinion angle This photo I'm not even holding my phone perfectly square but it's just jumps out at you how angled it is. Really appreciate all the input because I just had no idea about these things. Ratsun is the shit. 1 Quote Link to comment
datson4life Posted February 20, 2016 Report Share Posted February 20, 2016 Sweet. Sorry i suck at explaining things 1 Quote Link to comment
Anderson521 Posted February 20, 2016 Author Report Share Posted February 20, 2016 No way dude I'm so glad I met you, it's been super helpful in workin out some of the bugs in this truck 1 Quote Link to comment
Bory Posted February 20, 2016 Report Share Posted February 20, 2016 Keep in mind a few things You can obtain a 3" drop with a pretty good load of lumber, with out having to add degree of pinion. Blocks with degree added start at 4" and up. Even if your pinion is way off, say like a lifted 70's 4x4 chevy, with a super short front shaft, the angle is to great for the u joint not to bottom out, but if you get to that point, it would jack up the u joint way before the ring and gear, so if your u joint is not being forced to do more angle of deflection than designed, it would never damage ring gear. That has to do more with it being old as dirt. A 3" flat block would not attribute to that damage. Don't get me wrong, correct or perfect pinion angle is important, but it becomes that more when circle track racing with high hp with hard Exceleration, to pull out of the turn and hook up, and hard braking. 1 Quote Link to comment
Anderson521 Posted February 21, 2016 Author Report Share Posted February 21, 2016 Keep in mind a few things You can obtain a 3" drop with a pretty good load of lumber, with out having to add degree of pinion. Blocks with degree added start at 4" and up. Even if your pinion is way off, say like a lifted 70's 4x4 chevy, with a super short front shaft, the angle is to great for the u joint not to bottom out, but if you get to that point, it would jack up the u joint way before the ring and gear, so if your u joint is not being forced to do more angle of deflection than designed, it would never damage ring gear. That has to do more with it being old as dirt. A 3" flat block would not attribute to that damage. Don't get me wrong, correct or perfect pinion angle is important, but it becomes that more when circle track racing with high hp with hard Exceleration, to pull out of the turn and hook up, and hard braking. I hear what you're saying I have a coworker with a daily driven ram charger that's pretty high up and he's thrown three driveshafts but never damaged ring gear, transmission, or transfer case. Pinion angle is super foreign to me. I'm just gonna have to see how it goes and if the driveshaft starts humming or acting funny then I'll prollly change the angle, but then by that time I might even have the new beefy rear diff 1 Quote Link to comment
Bory Posted February 21, 2016 Report Share Posted February 21, 2016 You and I are kinda sim. with both running V8's I was running about 250 HP 1st time around. Not sure what your running in your Generous Motors, But if you run a stock 521 gear, it's gonna be way too low, you can buy some time, but save your self some grief and get yourself a 9" ford, they are all over the place cheap to narrow and plenty strong, with great gear selection. I'm running 3:90 gears, and was turning 2100 rpm At 70 mph with a 4 speed auto. not sure what your final ratio is in your Trans. Also don't put slicks on it, cus your reared will only give you 1/2 a run if get my drift. 1 Quote Link to comment
Anderson521 Posted February 21, 2016 Author Report Share Posted February 21, 2016 So I've currently got 4:88s in the rear which is lower than most, believe me when I say I want a beefier diff, I just don't get how the rear end shop came up with that price. It's cutting the tubes, rewelding them and cutting new splines on the axles. 1 Quote Link to comment
Anderson521 Posted February 21, 2016 Author Report Share Posted February 21, 2016 And as far as the horsepower goes Im sure it's in that ballpark, as for tires I want to run the stockers to give it a sleeper look. Did yours ever start slipping? I notice you were running what looked like 95 stang wheels at one point 1 Quote Link to comment
denmarkboy Posted February 21, 2016 Report Share Posted February 21, 2016 You and I are kinda sim. with both running V8's I was running about 250 HP 1st time around. Not sure what your running in your Generous Motors, But if you run a stock 521 gear, it's gonna be way too low, you can buy some time, but save your self some grief and get yourself a 9" ford, they are all over the place cheap to narrow and plenty strong, with great gear selection. I'm running 3:90 gears, and was turning 2100 rpm At 70 mph with a 4 speed auto. not sure what your final ratio is in your Trans. Also don't put slicks on it, cus your reared will only give you 1/2 a run if get my drift. Im running 400 + hp , and I'm running a stock datsun rear end with 295/50/15's , And I have been for years without any problems at all . I've changed gears from 485's to 355's and currently running 333's . And it loves to go sideways at any speed . Unless your going to drag race your truck and really put those 200+ ponies to the ground i would stick to the datsun rear end . They are easy to get gears for and cheap to . I've crossed this bridge and considered narrowing a 12 bolt chevy to handle the power. I figured I would wait until I broke it to upgrade . well that was 4 years ago , and everyone thats ever rode in my truck or has been around knows I am not easy on it . . never failed me . 1 Quote Link to comment
Bory Posted February 21, 2016 Report Share Posted February 21, 2016 Well an 8.8 is a little different to narrow, first of all it's a clip type axle, which means it has s c clip holding it in place at the end of the axle in the diff. So when you cut the axle even s little bit, not only do you cut the splines off, but your cutting the groove off where the clip goes, on top of that, you have to machine the end of the shaft down, cus it's bigger when the splines end. Most shops won't even attempt to do that axle, even curry, if you can believe that. One of the leaders in rear ends! So you have to re cut the groove, that's the hardest, then after machine down the shaft, cut the splines back in. The housing is easy, any pipe fitter can do that. Now a 9" ford is much easier, the splines on that shaft is really long, so a dimple cut and clean up the edge and that's it, then shorten the housing. Your done. So on an 8.8 your paying for a special skill very few can and will attempt. I did my own housing, but I paid 450 for axles. Shop in LA. 1 Quote Link to comment
Bory Posted February 21, 2016 Report Share Posted February 21, 2016 Im running 400 + hp , and I'm running a stock datsun rear end with 295/50/15's , And I have been for years without any problems at all . I've changed gears from 485's to 355's and currently running 333's . And it loves to go sideways at any speed . Unless your going to drag race your truck and really put those 200+ ponies to the ground i would stick to the datsun rear end . They are easy to get gears for and chap to . I've crossed this bridge and considered narrowing a 12 bolt chevy to handle the power. I figured I would wait until I broke it to upgrade . well that was 4 years ago , and everyone thats ever rode in my truck or has been around knows I am not easy on it . . never failed me . 1 Quote Link to comment
Bory Posted February 21, 2016 Report Share Posted February 21, 2016 Street tires are Not for all, you put a set of 9" slicks on that thing, after burn out it will do a cheap suit impersonation. You did a V8, don't weak link it with a stocker one legger. 2 Quote Link to comment
denmarkboy Posted February 21, 2016 Report Share Posted February 21, 2016 Street tires are Not for all, you put a set of 9" slicks on that thing, after burn out it will do a cheap suit impersonation. You did a V8, don't weak link it with a stocker one legger. LSD . . . . not one legged . . . it hooks up fine , but if you've got the money to blow by all means dropping a bunch of money so you can drive 55 is a waste. Drag racing his a whole different animal . 1 Quote Link to comment
Jester Posted February 21, 2016 Report Share Posted February 21, 2016 <embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf"flashvars="file=http%3A%2F%2Fvid25.photobucket.com%2Falbums%2Fc59%2Fjester02%2FStuff%2F20150516_124526_zpsk9kcdlg2.mp4&title="> 1 Quote Link to comment
denmarkboy Posted February 21, 2016 Report Share Posted February 21, 2016 woops . misfire Here is the video , but the audio and video aren't the best . But after about a truck length it goes full posi . 1 Quote Link to comment
Jester Posted February 21, 2016 Report Share Posted February 21, 2016 For some reason it didn't transfer to PB very well. It is perfect on my phone. 1 Quote Link to comment
Anderson521 Posted February 22, 2016 Author Report Share Posted February 22, 2016 For some reason it didn't transfer to PB very well. It is perfect on my phone.You got the video too?? Quote Link to comment
Anderson521 Posted February 22, 2016 Author Report Share Posted February 22, 2016 Picked up some tail lights over the weekend Quote Link to comment
bilzbobaggins Posted February 22, 2016 Report Share Posted February 22, 2016 Picked up some tail lights over the weekend they look good. Does your source have any more? Quote Link to comment
Anderson521 Posted February 22, 2016 Author Report Share Posted February 22, 2016 they look good. Does your source have any more? Are you in the Bay Area? 1 Quote Link to comment
Abe Froman Posted February 22, 2016 Report Share Posted February 22, 2016 is the license plate held on with zip tie's ? 1 Quote Link to comment
Anderson521 Posted February 22, 2016 Author Report Share Posted February 22, 2016 is the license plate held on with zip tie's ?Hell yeah, less wind resistance 1 Quote Link to comment
bilzbobaggins Posted February 22, 2016 Report Share Posted February 22, 2016 Are you in the Bay Area? Quite not. Im on the other coast. lol 1 Quote Link to comment
Anderson521 Posted February 23, 2016 Author Report Share Posted February 23, 2016 Oh that is a bit of a trek! 1 Quote Link to comment
