banzai510(hainz) Posted December 9, 2015 Report Share Posted December 9, 2015 no i think it might hit when you gas it hard unless you got rock solid engine mounts. guys up here say I should put a V8 in my green 521 also. But I notice they are driving Hondas accords 1 Quote Link to comment
Anderson521 Posted December 10, 2015 Author Report Share Posted December 10, 2015 Shit then ill have to get me some torque straps! I haven't tested the theory yet but if the flywheel spins clockwise it'll move left to right and I got plenty of space on the passenger side. Quote Link to comment
Rick-rat Posted December 10, 2015 Report Share Posted December 10, 2015 Chevrolet motors torque to the left , initially, (drivers side) under acceleration Sorry my mistake, torque to the right Quote Link to comment
Anderson521 Posted December 10, 2015 Author Report Share Posted December 10, 2015 Well there it is, ill just have to see what possible damage it will do once I get it running at full potential, thanks for the insight Quote Link to comment
DaBlist Posted December 10, 2015 Report Share Posted December 10, 2015 Chevrolet motors torque to the left , initially, (drivers side) under acceleration Front North South mounted V8's will try and lift on the drivers side 1 Quote Link to comment
Rick-rat Posted December 10, 2015 Report Share Posted December 10, 2015 Yes, I was mistaken on the direction 1 Quote Link to comment
Boxcar Posted December 10, 2015 Report Share Posted December 10, 2015 Yea, just a bit. Keep up the good work. Truck looks fine. 1 Quote Link to comment
Anderson521 Posted December 11, 2015 Author Report Share Posted December 11, 2015 When I was googling Information I saw that car too, that things nasty 1 Quote Link to comment
paradime Posted December 13, 2015 Report Share Posted December 13, 2015 Here's the headers next to the steering column, it's got about 1/16-1/8 gap Could you weld a 1/2" steal rod in there to replace that section of the column? That would get you enough room to wrap the headers. 1 Quote Link to comment
sebpv Posted December 13, 2015 Report Share Posted December 13, 2015 Cut the column and the rod and incorporate joints to clear the manifold.. Its been done 1 Quote Link to comment
Anderson521 Posted December 13, 2015 Author Report Share Posted December 13, 2015 Yeah that datstang guy did it, certainly wouldn't be a bad idea it's just I'm evolving the truck as I go along. If i drive it and the clearance is too tight then ill get into it. I'm not a loaf I just got a lot of ground to cover on the build 2 Quote Link to comment
paradime Posted December 14, 2015 Report Share Posted December 14, 2015 Been there, sometimes you have to pick your battles, or a project like this can stall for months at a time. Hell, push comes to shove you can slightly ding the pipe at the point where it makes contact. Best of luck. 1 Quote Link to comment
Anderson521 Posted December 14, 2015 Author Report Share Posted December 14, 2015 Thanks man ill keep ya posted! And for those interested I just put a vid up on YouTube of the engine running 7 Quote Link to comment
datson4life Posted December 14, 2015 Report Share Posted December 14, 2015 Nice!!!!! 1 Quote Link to comment
Draker Posted December 14, 2015 Report Share Posted December 14, 2015 Looks like it's coming together! 1 Quote Link to comment
Anderson521 Posted December 31, 2015 Author Report Share Posted December 31, 2015 =http://s1190.photobucket.com/user/Anderson521/media/Mobile%20Uploads/image_zpsx93lubqc.jpg.html][/url] 1 Quote Link to comment
Anderson521 Posted December 31, 2015 Author Report Share Posted December 31, 2015 From a chevelle not sure where they'll go yet but couldn't pass them up for 8 bucks Quote Link to comment
Anderson521 Posted December 31, 2015 Author Report Share Posted December 31, 2015 1 Quote Link to comment
Anderson521 Posted December 31, 2015 Author Report Share Posted December 31, 2015 Since Im using a short water pump the standard alternator bracket doesn't allow the pulleys to line up so the solution is a header mount bracket. It's on a slider so if you have double groove pulleys you can choose front or back Quote Link to comment
Anderson521 Posted December 31, 2015 Author Report Share Posted December 31, 2015 Quote Link to comment
Anderson521 Posted December 31, 2015 Author Report Share Posted December 31, 2015 Here's one of the single groove short pulley, off of a pre 68 chevy. Quote Link to comment
fritzdixxon Posted December 31, 2015 Report Share Posted December 31, 2015 Here's the headers next to the steering column, it's got about 1/16-1/8 gap. This is a BIG PROPLEM hopefully you get that better or maybe the stock cast manifold might fit better dont throw away the datsun 521 manifold and the Y pipe with it, people can use them I could use the y pipe. What diffyou going with 8.8? Quote Link to comment
fritzdixxon Posted December 31, 2015 Report Share Posted December 31, 2015 =http://s1190.photobucket.com/user/Anderson521/media/Mobile%20Uploads/image_zpsx93lubqc.jpg.html][/url] They should go under the hood or in the cab, I hate it when a sleeper gets badges telling everyone its a sleeper. Quote Link to comment
Anderson521 Posted December 31, 2015 Author Report Share Posted December 31, 2015 I could use the y pipe. What diffyou going with 8.8? Quote Link to comment
Anderson521 Posted December 31, 2015 Author Report Share Posted December 31, 2015 I sold the engine and those parts like a week after I bought the truck. And yes most likely the 8.8 with a posi. I was even thinking a gm 12 bolt because it's 6 lug but it might be larger than the datsuns pattern haven't investigated. As far as the badges goes I was thinking fender well, firewall or dash Quote Link to comment
