Anderson521 Posted April 19, 2016 Author Report Share Posted April 19, 2016 Keeping the gas petal on the right.... I like it! :-) It'd be super akward to drive with it on the left but I'm sure it's been done Quote Link to comment
svo521 Posted April 20, 2016 Report Share Posted April 20, 2016 took me a week to get used to it. first time leaving driveway I spun it 180 because I was confused lol Quote Link to comment
Anderson521 Posted April 26, 2016 Author Report Share Posted April 26, 2016 Layin some bird turds Quote Link to comment
Anderson521 Posted April 26, 2016 Author Report Share Posted April 26, 2016 Pretty hideous at the moment but looks much better in person, my whole idea is once its all said and done I can unscrew and pull the sheet metal off the tranny if I need to pull it to do a clutch or something Quote Link to comment
Anderson521 Posted April 26, 2016 Author Report Share Posted April 26, 2016 Considering cutting the pedals and moving clutch and brake over half an inch, we'll see if it becomes necessary Quote Link to comment
Anderson521 Posted April 26, 2016 Author Report Share Posted April 26, 2016 Finally committed and bought these as well, should fit given I took my measurements correctly..fingers crossed Quote Link to comment
Anderson521 Posted April 26, 2016 Author Report Share Posted April 26, 2016 Got these babies comin in the mail too Quote Link to comment
Anderson521 Posted April 26, 2016 Author Report Share Posted April 26, 2016 Really really stoked off the users manual Quote Link to comment
Anderson521 Posted May 1, 2016 Author Report Share Posted May 1, 2016 Moved it around the driveway yesterday Quote Link to comment
Anderson521 Posted May 1, 2016 Author Report Share Posted May 1, 2016 Tunnel is coming along nicely, it's 2 pieces that'll lift out when you unscrew the shifter just to make it easy as possible. Still thinking of the best way to attach it, self tappers would work but be kinda jank, could weld nuts to the backside and drill clearance holes for bolts or maybe use those speed clips dragsters use on their body panels... Anyone have experience with those? 2 Quote Link to comment
svo521 Posted May 2, 2016 Report Share Posted May 2, 2016 the clips would be trick. Mine used to be removable but I got tired of sealing it every time I took it off and on. Now I just put the cab on the bed lmao maybe a reusable seal that slips over the metal like for doors? whatever you do you want it strong enough to keep the driveline out of your lap in a worse case scenario situation. Glad to see it move under power!!! sounds good on the video you posted on facebook. 1 Quote Link to comment
Anderson521 Posted May 2, 2016 Author Report Share Posted May 2, 2016 Thanks man! It was pretty nerve wracking it wasn't near as bad as I thought it would be, a little hard to steer but I've had vehicles with non power steering and it was pretty close. I was thinking for sealing I could get some glazing tape or gasket ing from the window shop I work at. And maybe getting a pipe hanger or something to use as a safety loop for the driveshaft Quote Link to comment
datson4life Posted May 3, 2016 Report Share Posted May 3, 2016 I bet steering was a bit rough with the added weight. But 15+ mpg steering is no biggie Quote Link to comment
Anderson521 Posted May 3, 2016 Author Report Share Posted May 3, 2016 Yeah it'll just help build up the guns! Haha. I think I lucked out and someone along the line replaced all the steering bushings too Quote Link to comment
datson4life Posted May 3, 2016 Report Share Posted May 3, 2016 Yeah it'll just help build up the guns! Haha. I think I lucked out and someone along the line replaced all the steering bushings too Sweet! They kinda a pain to obtain all. I have all new bushings and links and they came from all over the world lol Quote Link to comment
datzenmike Posted May 3, 2016 Report Share Posted May 3, 2016 Did you put a Disc brake residual valve in your master cylinder? If you have the drum one still in, it will keep 10-12 pounds of pressure in the front lines and a disc brake only needs about 3. They will drag and at the least, wear the pads sooner. Worst is over heating the front brakes. The willwood proportioning valve reduces rear line pressure variably up to about 60%. My 620 was raised about 16 inches with 31" tires. The weight transfer on braking was incredible and would easily lock the rears. If on a turn it would go into mad over steer and often when just pulling up to a stop sign. Having others drivers glare at you gets thin fast. I put that valve in line and dialed it back in stages by emergency stopping on pavement until the front just began sliding before the rears. Now I could brake hard with confidence rather than following 4 lengths behind someone. You have extra weight and traction on the front wheels so they are going to take more braking pressure input before locking up. The rears still think this is an empty 521. Quote Link to comment
Anderson521 Posted May 3, 2016 Author Report Share Posted May 3, 2016 Now would these inline residual valves work? I gotta tell you man you're extrememly knowledgable Quote Link to comment
Anderson521 Posted May 4, 2016 Author Report Share Posted May 4, 2016 Now if my research proves sound the 79 zx that master cylinder came from is a all disc car so I would only need a proportioing valve for the rear drums Quote Link to comment
