Kytoaster Posted September 29, 2015 Report Share Posted September 29, 2015 Well, I was getting no real odors or anything, and went to fill up with gas. When I did, I accidentally overfilled, and a little gas shot out of the filler neck. Since then....there's been an OVERWHELMING smell of gas fumes?I washed the truck off, and it looks like any hoses under the filler neck are still attached...it just smells like gas....reeeally bad, and I can't figure it out? 1 Quote Link to comment
datzenmike Posted September 29, 2015 Report Share Posted September 29, 2015 Datsun or Suzuki? Truck= Suzuki? You can edit your title by selecting EDIT then FULL EDITOR at bottom of every post. The tank on a 610 is above the rear axle and goons are under the cargo space and behind the axle. A Suzuki forum might know. 1 Quote Link to comment
Dolomite Posted September 29, 2015 Report Share Posted September 29, 2015 He's talking about a datsun, a suzuki intruder is a motorcycle. 1 Quote Link to comment
Kytoaster Posted September 29, 2015 Author Report Share Posted September 29, 2015 I was talking about my 620, sorry. I had to replace the filler neck as it was dryrotted/cracked badly, but once I did that I had no gas smell. Once I filled up with gas and accidentally overfilled it, the gas fume smell is just constant?I also swapped to a weber carb, but I don't think that would have anything to do with it? I didn't notice the smell until I accidentally overfilled? 1 Quote Link to comment
distributorguy Posted September 29, 2015 Report Share Posted September 29, 2015 A new Weber carb could have the float out of adjustment, and that WILL spill fuel all the time. Google "DGV float level" and reset your float. That will solve the smell, and run better. 2 Quote Link to comment
DanielC Posted September 29, 2015 Report Share Posted September 29, 2015 Your 620 is over 40 years old. There are probably several hoses connected to the gas tank, and the evaporative emission system, and any one, or more, of then could be bad. On a 521, there is a 5/8 or so diameter hose that goes from the top of the filler neck to theopposite end of the gas tank, from where the filler hose drops in to the tank. i have seen that hose jusat crack from old age. It would be a good idea to replace all the fuel system hoses on any vehicle that old. Remember, in the 1970's they did not plan onalcohol being mixed with gasoline. 1 Quote Link to comment
bilzbobaggins Posted September 29, 2015 Report Share Posted September 29, 2015 what do 620 gas caps look like? I cut a cork one for my 521 cap to kill the gas smell. Maybe gas ate the rubber seal up? dunno good luck 1 Quote Link to comment
datsunaholic Posted September 29, 2015 Report Share Posted September 29, 2015 You probably managed to fill the vapor tank (up under the wheelwell) and those tend to be rusted out. Plus gas got into all the dirt in the surrounding area and that takes forever for the smell to go away. 1 Quote Link to comment
datzenmike Posted September 30, 2015 Report Share Posted September 30, 2015 He's talking about a datsun, a suzuki intruder is a motorcycle. Wa ha ha ha ha. WTF do I know about bikes? lultz. 2 Quote Link to comment
Kytoaster Posted October 26, 2015 Author Report Share Posted October 26, 2015 Well, I checked all the hoses, and they are actually in decent shape. The gas cap still has (what appears to be) rubber gasket on it. It only happens when I fill COMPLETELY up. Put $10 in last week, put the cap on and went on my way. Filled completely up today, and it smells like there is a cup of gasoline sitting in the bed of my truck.No leaks, but it's definitely coming from around the gas cap/vapor tank area. I wonder if by completely filling up with gas, I'm somehow getting some in the vapor tank, and it's just sitting there? 1 Quote Link to comment
bilzbobaggins Posted October 26, 2015 Report Share Posted October 26, 2015 Do 620 have a leather gasket to seal the sending unit? Po of my 521 tried silicon as a gasket. Got the same result with more than half a tank. Made a cork one and problem gone 1 Quote Link to comment
Doctor510 Posted October 26, 2015 Report Share Posted October 26, 2015 Rubber "O" ring like the 510. 1 Quote Link to comment
datzenmike Posted October 27, 2015 Report Share Posted October 27, 2015 Go to NAPA and look through their O rings for the right thing. Probably $0.50 1 Quote Link to comment
banzai510(hainz) Posted October 27, 2015 Report Share Posted October 27, 2015 my accell pump was leakin on the carb,smell went in carb, dripped on exhaust manifold. Got a new accel pummp and installed smell went away 1 Quote Link to comment
mhub91 Posted February 24, 2016 Report Share Posted February 24, 2016 You say you just installed a Weber carb......... I had this same issue after I installed a Weber too. I Somehow I over looked that I left thw fuel return line wide open and uncapped. Every time I filled up, gas would literally pour out everywhere from under the hood, passenger side, near frame rail / fuel filter area. Simply capped it, allok now 1 Quote Link to comment
Robsorangedatsun Posted February 24, 2016 Report Share Posted February 24, 2016 I had the same issue with my 77 620. Strong fuel smell even with the back slider shut. Pulled my tank and the return line was badly dry rotted. I replaced all hoses and hose clamps. No more problems. Also have a 720 4x4 that just jerked you out of your seat upon acceleration. Found that the feed line going to the fuel pump was dry rotted just enough to lose fuel pressure. Any Datsun I have had I always end up pulling the tank! :) 1 Quote Link to comment
Kytoaster Posted February 26, 2016 Author Report Share Posted February 26, 2016 I had the same issue with my 77 620. Strong fuel smell even with the back slider shut. Pulled my tank and the return line was badly dry rotted. I replaced all hoses and hose clamps. No more problems. Also have a 720 4x4 that just jerked you out of your seat upon acceleration. Found that the feed line going to the fuel pump was dry rotted just enough to lose fuel pressure. Any Datsun I have had I always end up pulling the tank! :) I'm really just considering replacing all of the fuel hoses under the truck, the smell is SO strong. Quote Link to comment
