MicroMachinery Posted November 4, 2015 Report Share Posted November 4, 2015 Never paid more than $30 for a resurfacing. 1 Link to comment
Dguy210 Posted November 4, 2015 Report Share Posted November 4, 2015 How crazy a process is it!? Can a regular lathe do the trick?I think it can be done on a lathe, or with a flycutter on a mill. Most regular lathes I think would be too small, I've heard it can be done on a brake lathe with an adapter. I've had good luck asking/looking around at VW shops/forums to see if someone knew a cheap source. Edit: Maybe time to get it lightened too? Is that the 220 or 240 mm flywheel anyway? Link to comment
TENDRIL Posted November 4, 2015 Report Share Posted November 4, 2015 should be 220 as the 240mm i thought was only hard body? Link to comment
flatcat19 Posted November 4, 2015 Author Report Share Posted November 4, 2015 $40 through my machine shop. Link to comment
Laecaon Posted November 4, 2015 Report Share Posted November 4, 2015 Go look up DIY if you are that worried about price. Back when I manual swapped my 510 in a time with no money, A block of wood and sandpaper made a nice surface, and my clutch grabbed... Link to comment
TENDRIL Posted November 4, 2015 Report Share Posted November 4, 2015 my fly wheel has heat spots and some surface cracks, from the PO, i didnt worry to much about it but since, the motor is out a second time i want to get it all done. Link to comment
KoHeartsGPA Posted November 4, 2015 Report Share Posted November 4, 2015 Good work is not cheap and cheap work is not good. Link to comment
Dguy210 Posted November 4, 2015 Report Share Posted November 4, 2015 should be 220 as the 240mm i thought was only hard body? Yep, Look up White Bunny mod if you're interested, not too pricey flywheel/clutch upgrade upto 240mm or even 250mm with some parts sourcing (350z and L28et stuff). 1 Link to comment
TENDRIL Posted November 4, 2015 Report Share Posted November 4, 2015 Profile Views20,532 3 Link to comment
Rhapakatui Posted November 4, 2015 Report Share Posted November 4, 2015 177 more and you'll pass Dirty Paws! 1 Link to comment
TENDRIL Posted November 4, 2015 Report Share Posted November 4, 2015 found a shop right down the street an old guy told me about, cheapest place that will do it. however they dont advertise it since they are mostly a specialty truck repair shop not really a public shop haha 2 Link to comment
TENDRIL Posted November 4, 2015 Report Share Posted November 4, 2015 https://youtu.be/VVVm9xGZgUE Link to comment
TENDRIL Posted November 5, 2015 Report Share Posted November 5, 2015 nice fail there,,,, boob.... 2 Link to comment
Rjawm Posted November 5, 2015 Report Share Posted November 5, 2015 nice fail there,,,, boob.... It was there when I posted it... Be awesome if the forum recognized LiveLeak vids too. Take 2 1 Link to comment
Rjawm Posted November 5, 2015 Report Share Posted November 5, 2015 I hope you remembered to install the other 4 bolts... Link to comment
TENDRIL Posted November 5, 2015 Report Share Posted November 5, 2015 https://instagram.com/p/9tw0zbxcPx/ Link to comment
a.d._510_n_ok Posted November 5, 2015 Report Share Posted November 5, 2015 make sure it's PURE cane too - that's the key! 3 Link to comment
DaBlist Posted November 5, 2015 Report Share Posted November 5, 2015 make sure it's PURE cane too - that's the key! Only works on Prius's 2007 or newer & Mini convertibles 3 Link to comment
