CEL3 Posted February 13, 2015 Report Share Posted February 13, 2015 Like the title, what headlights will work in a 620? I've been researching and have found little to no info. I found a picture of a black 620 with what I believe are jaguar lights? But what model? Anyway, any lights that will fit or any of your mods, please share! 1 Quote Link to comment
red13 Posted February 13, 2015 Report Share Posted February 13, 2015 You can,mod projector lights in from a bmw. And for the brights u can get some yellow lights from a Mercedes 500d 1 Quote Link to comment
Guest Rick-rat Posted February 13, 2015 Report Share Posted February 13, 2015 Are you looking for something aside from the stock replacements? 1 Quote Link to comment
banzai510(hainz) Posted February 13, 2015 Report Share Posted February 13, 2015 http://www.deltalights.com/?q=store#!/5-3-4-Headlights/c/2483197/offset=0&sort=normal will need a H4 harness. if you run the 55/60 watt bulbs 1 Quote Link to comment
datzenmike Posted February 13, 2015 Report Share Posted February 13, 2015 You can,mod projector lights in from a bmw. And for the brights u can get some yellow lights from a Mercedes 500d The amber Mercedes lights are fog lamps and no good for actually seeing anything. Amber lamps are a Ratsun fad. If your aim is to be safe and actually see at night you will need clear driving lamps. 4 Quote Link to comment
CEL3 Posted February 13, 2015 Author Report Share Posted February 13, 2015 Yes, I'm wanting something other than stock. 1 Quote Link to comment
CEL3 Posted February 13, 2015 Author Report Share Posted February 13, 2015 http://www.minitruckinweb.com/features/0807mt_1979_datsun_620/photo_17.html I like these. Any ideas? I like the clear look Quote Link to comment
]2eDeYe Posted February 13, 2015 Report Share Posted February 13, 2015 Those are Ebay projecters. Any 5.75" light will usually work, the BMW halos required modifications. http://www.ebay.com/sch/Headlights-/33710/i.html?mvsub=1&_mcatda=true&selfil=1%2C2&selvel=1973~Nissan~-~-~-&_nkw=1973%20Nissan 1 Quote Link to comment
CEL3 Posted February 13, 2015 Author Report Share Posted February 13, 2015 So if I get a 5.75 light it should work? I've been doing work to the truck but I haven't checked on this. I do very little custom work. I do restorations and collision repair for a living but I don't really want to get into alot over headlights you know? Not trying to sound like a newb. And are there any wiring mods I'll have to do or anything? Just don't want to get into anything with all the projects I'm into right now. Quote Link to comment
5t341tH Posted February 14, 2015 Report Share Posted February 14, 2015 most of them i've bought wont work. i've had 2 of 3 pairs of lights and the stock headlight retaining ring doesn't fit over the bulb. Those are Ebay projecters. Any 5.75" light will usually work, the BMW halos required modifications. http://www.ebay.com/sch/Headlights-/33710/i.html?mvsub=1&_mcatda=true&selfil=1%2C2&selvel=1973~Nissan~-~-~-&_nkw=1973%20Nissan 1 Quote Link to comment
banzai510(hainz) Posted February 14, 2015 Report Share Posted February 14, 2015 Look like Chinese made crap if you got to do it Bosche Hella Cibie lamps with the H4 bulb with a harness. You should know this if you redo cars. a harness will be triggered from you stock harness pass side low/beam 3 prong wiring plug and play 1 Quote Link to comment
ohmrchristopher Posted February 14, 2015 Report Share Posted February 14, 2015 Go to (part store) Buy a H4 head light conversion kit. Mine was a Xtreme Vision or something 9007 kit. (Comes with H4/9007 pig tales. Buy Hella H1 motorcycle lights for your inside beams. Buy the 80w/100w 9007 bulbs by the same company that makes the headlights *most important* buy the Painless H4 relay quad headlight wiring harness. (Or try making your own) otherwise you melt your headlight switch, overwork your charging system and cause grief. Install and BAM!!! LAZER BEAMS. All in it was about $800 but I now have modern bright lights that aren't HIDS and super annoying all powered off the battery by a new GM style harness. Quote Link to comment
Charlie69 Posted February 15, 2015 Report Share Posted February 15, 2015 Mod in the 720 headlights. There is tons of stuff on the web. Google is your Friend! ASK, Yahoo and the others suck! Quote Link to comment
CEL3 Posted February 15, 2015 Author Report Share Posted February 15, 2015 I appreciate it guys, I'm going to check out some of the stuff you mentioned. And I can do mods but I prefer not get into more than I have to you know? Quote Link to comment
Z-train Posted February 15, 2015 Report Share Posted February 15, 2015 Anything other than well aimed Halogen headlights is completely un-needed Quote Link to comment
DanielC Posted February 15, 2015 Report Share Posted February 15, 2015 What Z-train said. Except add "quality" before the word 'halogen". You will need a bigger alternator, and thicker, shorter wiring to the headlights, with better relays. This is a nice relay to use. Tt has two 87 pins, not a 87, and a 87A. 1 Quote Link to comment
banzai510(hainz) Posted February 15, 2015 Report Share Posted February 15, 2015 this helped me http://www.4crawler.com/4x4/CheapTricks/Headlights.shtml#OnLineOrdering I use a chines harness myself there are better ones VictoriaBritish sells them also you only need the outer 2 lamp(2 relay) set up as the inners are already 50watters If you want to use hiher inner lamps then you need the 4 lite system which will be 3 relays. olddatsuns.com the tech section bookmark this Quote Link to comment
