hobospyder Posted February 24, 2016 Author Report Share Posted February 24, 2016 Must have missed it but what did you need this for? Spacer? took out the backing plate, had to make up for 5.5mm worth of material so, spacer yes 2 Link to comment
uberkevin Posted February 24, 2016 Report Share Posted February 24, 2016 I see, didn't think the plate was that thick. 1 Link to comment
hobospyder Posted February 24, 2016 Author Report Share Posted February 24, 2016 It is. I was thinking it was a quarter inch. Comes in just under at .217 of an inch 2 Link to comment
Rhino13 Posted February 24, 2016 Report Share Posted February 24, 2016 I'll have to check these out. Do they not rip after 30 seconds of wearing them? I've worn a pair for a few hours, but we deal with sticky stuff and pretty much only get rips from scissors or our trellising over the plants. 3 Link to comment
hobospyder Posted February 25, 2016 Author Report Share Posted February 25, 2016 :rofl: all because i get my hands dirty. y'all continue but i'm gonna interrupt with some progress so, this stuff was purchased by my mechanic when he found it somewhere because he thought i would like it and i do, it's blue, made me happy bench bled the master cylinder and installed it and that makes me realize just how nasty my engine bay is..... but that's for another day. started working on rebleeding the system. i think i got the drivers side rear bled, started working on the rear passenger as well, got frustrated with my mitivac though. it's a good idea, but man, my hand and wrist started hurting. that's it for progress until next week. tomorrow i have to do some prep work for friday and i'll be laying in bed with an icepack between my legs all weekend probably. she's safe enough to bring up to the house i'm sure but the system will get done properly. i have an issue with half assing important stuff and those spacers are bothering me even though i can't see them 4 Link to comment
hobospyder Posted February 25, 2016 Author Report Share Posted February 25, 2016 what in the hell do those two loose wire ends go to??????? they got plugs, but...... :confused: :confused: :confused: :confused: 1 Link to comment
hobospyder Posted February 25, 2016 Author Report Share Posted February 25, 2016 old master cylinder 1 Link to comment
q-tip Posted February 25, 2016 Report Share Posted February 25, 2016 Those wires on the master cylinder of for the brake fail system, but you should have that switch on the distribution block. It just turns the BRAKE light in the dash on if the brakes loose pressure. 2 Link to comment
uberkevin Posted February 25, 2016 Report Share Posted February 25, 2016 I want that blue shiiiit! 3 Link to comment
hobospyder Posted February 25, 2016 Author Report Share Posted February 25, 2016 Those wires on the master cylinder of for the brake fail system, but you should have that switch on the distribution block. It just turns the BRAKE light in the dash on if the brakes loose pressure. there aren't any wires on the master cylinder though. Was talking about the one by the distributor and the one on the fender well that comes off the headlight bundle 1 Link to comment
bananahamuck Posted February 25, 2016 Report Share Posted February 25, 2016 If you are running matchbox the wire from the resistor wouldn't be used any more,, or the resistor for that matter. Sorry for the thread jack about wire questions So back on track . Hey what kind of gloves would you guys use on blackberry stickers?? 3 Link to comment
hobospyder Posted February 25, 2016 Author Report Share Posted February 25, 2016 Points distributor. Last person to touch it was my mechanic. 1 Link to comment
q-tip Posted February 25, 2016 Report Share Posted February 25, 2016 If you are running matchbox the wire from the resistor wouldn't be used any more,, or the resistor for that matter. Sorry for the thread jack about wire questions So back on track . Hey what kind of gloves would you guys use on blackberry stickers?? Buy a goat 1 Link to comment
hobospyder Posted February 25, 2016 Author Report Share Posted February 25, 2016 Goat or torch for brambles. I hate brambles 1 Link to comment
KoHeartsGPA Posted February 25, 2016 Report Share Posted February 25, 2016 Looking good, Hobo!! 3 Link to comment
Rhino13 Posted February 26, 2016 Report Share Posted February 26, 2016 Chainsaw is the best for blackberry. I did restoration work for about 5 years and one place, that I ended up quitting because they didn't give me a raise a month past our meeting, had a cutting everything with chainsaws. We cleared 6 acres of reed canary grass in a day with some scotch broom and false brome mixed. Planting season is a whole other battle, fuck that noise. 2 Link to comment
Rick-rat Posted February 26, 2016 Report Share Posted February 26, 2016 Hobo, and those spacers are bothering me even though i can't see them I don't know how you can sleep at night with those spacers :rofl: 1 Link to comment
]2eDeYe Posted February 26, 2016 Report Share Posted February 26, 2016 I sell ravens to tons of shops (I work at oreilly). We also use them. We tested one once. I put one on and used a flat head screw driver to stretch the palm till it ripped. I got over 3 inches of stretch out of it. I usually throw them away because my hands are so sweaty, Not because they tore. The best hand cleaner is called Joe's hand cleaner. I've used all of them and it's far and away the best. It's nice because it's waterless, so it works in the same situations as those towellettes. Rub it on then wipe It off on a paper towel. As best of all, it smells just like a banana laffy taffy! Actually most hand cleaner is waterless, I am continually amazed by someone getting there hands wet before using hand cleaner. Scrub first, then rinse. If you are running matchbox the wire from the resistor wouldn't be used any more,, or the resistor for that matter. Sorry for the thread jack about wire questions So back on track . Hey what kind of gloves would you guys use on blackberry stickers?? Big thick ass leather ones gripping a machete. Hobo, and those spacers are bothering me even though i can't see them I don't know how you can sleep at night with those spacers :rofl: I can bring my band saw and you can trim those up a bit, :lol: Link to comment
Eagle_Adam Posted March 5, 2016 Report Share Posted March 5, 2016 there aren't any wires on the master cylinder though. Was talking about the one by the distributor and the one on the fender well that comes off the headlight bundle Should be marker lights on the fender Link to comment
hobospyder Posted March 5, 2016 Author Report Share Posted March 5, 2016 I'll check next time I'm out at the shop but I think they were working. Key word, think. Thanks adam 1 Link to comment
hobospyder Posted March 6, 2016 Author Report Share Posted March 6, 2016 Should be marker lights on the fender fronts work, not as blinkers but they do work. Now the rears on the other hand don't.... 2 Link to comment
hobospyder Posted March 6, 2016 Author Report Share Posted March 6, 2016 Also After being towed home from Erics place down the street. Not getting fuel, really don't want to go back through the fuel system. It's somewhere between the filter and carb so at least I don't have to drop the tank just yet. Need to eventually because it's still nasty inside. You don't even want to see my filter right now 3 Link to comment
q-tip Posted March 6, 2016 Report Share Posted March 6, 2016 If the tank is nasty I would say you need to replace the filter again, or the fuel pump went out. 1 Link to comment
hobospyder Posted March 6, 2016 Author Report Share Posted March 6, 2016 Or both. Just need time to pick up a filter and blow out lines. Again. Gonna try putting the original pump back on before buying a new pump I think 1 Link to comment
hobospyder Posted March 6, 2016 Author Report Share Posted March 6, 2016 Filter nastiness 2 Link to comment
