bananahamuck Posted March 16, 2015 Report Share Posted March 16, 2015 Could not want more.. 1 Link to comment
TENDRIL Posted March 16, 2015 Report Share Posted March 16, 2015 To prime the KA24de front cover oil pump, do you pack it with vasoline Link to comment
laotsu Posted March 16, 2015 Author Report Share Posted March 16, 2015 I just started my LZ without all that priming shit and it ran perfectly. Link to comment
datzenmike Posted March 16, 2015 Report Share Posted March 16, 2015 To prime the KA24de front cover oil pump, do you pack it with vasoline Only way to pack it with grease is to take it apart, fuck that. For the D-21 just pop it off and top it up with oil. Pull plugs and spin it over for 20 seconds. You should see oil oozing on the cam and the oil pressure light will go out briefly when the key is released from start.. Link to comment
HRH Posted March 16, 2015 Report Share Posted March 16, 2015 If you're priming ANY oil pump that runs off the crank gear via the drive spindle for a Nissan application, put regular motor oil in the big holes and rotate it around slowly. That's it. That just lubes the internals so they don't start dry and creates a suction that will prime it. As you turn, you'll see the oil rise and fall. Don't add very much, just enough to lubricate. 1 Link to comment
505plus5 Posted March 16, 2015 Report Share Posted March 16, 2015 So, I've checked out this site for a long time now and didn't notice a thread on it here on Ratsun, so I thought it was about time to do it. The neat thing about it is that you can do your searches specifically- like 20's cars, 70's cars, etc... Even by make/model. Really cool! :w00t: You can also click on the Home button and check it out your own way. Well, without any further word, here's the direct link I chose for you (or simply try www.jaxed.com): Get at it!!!: :baby: http://www.jaxed.com/cgi-bin/mash.cgi?cat=cp&fil=&loc= Link to comment
TENDRIL Posted March 16, 2015 Report Share Posted March 16, 2015 Is 175 pricy for a block decking, bore and cleaning, and honing con rods for wrist pins? Link to comment
laotsu Posted March 16, 2015 Author Report Share Posted March 16, 2015 Is 175 pricy for a block decking, bore and cleaning, and honing con rods for wrist pins? cheaper than what I paid Link to comment
TENDRIL Posted March 16, 2015 Report Share Posted March 16, 2015 Should have sent it to busts nut Link to comment
datzenmike Posted March 17, 2015 Report Share Posted March 17, 2015 Is 175 pricy for a block decking, bore and cleaning, and honing con rods for wrist pins? Z22 bored to 89mm @ $20 per hole ($80) and deck the block 1mm @ $85 so $165. I also had the head shaved 1mm which may have been included as I can't find the bill for it. Link to comment
laotsu Posted March 17, 2015 Author Report Share Posted March 17, 2015 Should have sent it to busts nut I already told you I didn't want south of the border quality. My guy comes extremely well recommended from all the local racers. 1 Link to comment
laotsu Posted March 17, 2015 Author Report Share Posted March 17, 2015 Those look about the same size as the rears on my truck Link to comment
flatcat19 Posted March 17, 2015 Report Share Posted March 17, 2015 Looks like a broken version of autotempest. Link to comment
505plus5 Posted March 17, 2015 Report Share Posted March 17, 2015 Looks like a broken version of autotempest. What happened with that site?... Funny: I just tried it and I thought somehow it had read some whack zip code, from my laptop or something, I use just for kicks (90210= Beverly Hills), but its there by default! Lol :rofl: Link to comment
TENDRIL Posted March 17, 2015 Report Share Posted March 17, 2015 Only way to pack it with grease is to take it apart, fuck that. For the D-21 just pop it off and top it up with oil. Pull plugs and spin it over for 20 seconds. You should see oil oozing on the cam and the oil pressure light will go out briefly when the key is released from start.. sorry, i should have mentioned, its for the 93 s13 ka, internal oil pump, i read you can pack it with vasoline or assy. lube just to create initial suction Link to comment
flatcat19 Posted March 17, 2015 Report Share Posted March 17, 2015 Yes. You can. I never did after taking the covers off. Link to comment
RatVonDude Posted March 17, 2015 Report Share Posted March 17, 2015 I already told you I didn't want south of the border quality. My guy comes extremely well recommended from all the local racers. hmmmmm, rebuild l 16????????? for RVD shoot me some numbers boss Link to comment
TENDRIL Posted March 17, 2015 Report Share Posted March 17, 2015 A woman rides an early electric scooter. [1916] Link to comment
flatcat19 Posted March 17, 2015 Report Share Posted March 17, 2015 I licked Troy's butt clean. 3 Link to comment
